Memorex |
DVD-R |
4.7GB |
CMC MAG. AF1 |
4x |
Plays on 156 DVD Players
Plays not on 20 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is Good
Read 162 comments (949715 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
00 00 00 00 01 40 C1 FD 9E D8 52 00 02 87 0E 15 .....@....R.....
98 9A 90 00 03 43 4D 43 20 4D 41 00 04 47 2E 20 .....CMC MA..G.
41 46 31 00 05 CC C0 00 00 00 01 00 06 0B 10 11 AF1.............
or
00 00 00 00 01 40 C1 FD 9E D8 52 00 02 85 0E 15 .....@....R.....
41 46 31 00 05 CC C0 00 00 00 01 00 06 0B 11 11 AF1.............
Media color and text:
Silver Memorex 4X DVD-R recordable 4.7GB 120Minute Video UPC/EAN Code:
No
162 user comments
Showing
1 to
162 comments |
Comments posted by Fleuri from United States, February 25, 2007:
100% BAD burns at 4x, only works at 2x (most but not even all of the time), both with native Mac OS Backup or with Toast 7 application.
About the 1-year warranty: only worth trying if you kept your purchase receipt. If you started using after 1 year, or if you didn't save your receipt for this junk, then you're out of whatever you spent to buy it!
Additional information:
Date purchased: December -0001 Burnt with Plextor PX-708A2 at 4x using firmware 101.3 / MMC-3. Burning reliability is Mixed. PC reliability is Mixed. Media color is Silver. Media text is Memorex 4x DVD-R Recordable 4.7 GB. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Media UPC/EAN code is 034707055520. Authoring/Burning comments: Authored and burned with Apple Backup and Apple Mac OS X 10.4, also with Toast Titanium 7 |
Comments posted by schmidt from Germany, September 09, 2005:
Check your old media CMC MAG.AF1!!!
burning with lg gsa4040b ever OK.
After burning all OK. But after about 0.5 years many
reading errors and sometimes not recognizable even
at burner! and other DVD-ROM. Tryed to restore with
restoring tool isobuster, sometimes outputing many failures. I will never buy memorex!
Purchased from: www.amazon.de Date purchased: December 2004 Burnt with LG GSA-4040B at 2x using firmware A303. Burning reliability is Good. PC reliability is Poor. DVD reliability is Poor. Media color is Gold. Media text is 4.7 GB DVD-R 4x. Media package type is Jewel Case. Number of discs 10. Authoring/Burning comments: dvddecrypter Works fine on Cyberhome CH-DVD 402 |
Comments posted by paul from United States, August 17, 2005:
No comments
Burnt with Toshiba SD-R5112 at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is memorex recordable 4.7 gb 4x dvd. Media package type is Jewel Case. Number of discs 5. |
Comments posted by TheRealDeal from United States, July 10, 2005:
Suprising results for CMC media. Burns only at 2x in my Optorite DD1603
Burnt with OptoRite DD1603 at 2x using firmware 230I. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Authoring/Burning comments: DVDDecrtpter |
Comments posted by plinius from United States, April 07, 2005:
No comments
Purchased from: BestBuy Date purchased: December 2001 Burnt with Toshiba SD-R6472 at 4x Burning reliability is Poor. PC reliability is Poor. Media color is Silver. Media text is Memorex. Media package type is Cake Box. Number of discs 25. |
Comments posted by timmeh87 from Canada, March 22, 2005:
burnt though my whole spindle, only 1 coaster due to media failure (several due to stupidity). the one coaster, interestingly, had blotches on the recording surface after it was burnt where apparently no data had been burend into the dye. weird.
with GSA-4040b, these discs would only burn at 2x until I updated my firmware to A303. I think I had A301 before.
Purchased from: Future Shop Canada Burnt with LG GSA-4040B at 4x using firmware A303. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is White Pink. Media text is Memorex / Is it live or is it memorex?tm / 4X DVD R / R4.7 / www.memorex.com / DVD-R / RECORDABLE / 4.7GB 120 MINUTE VIDEO. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: nero 6 Works fine on Microsoft Xbox Works fine on Panasonic DVD-CV52 |
Comments posted by Per Svensson from Sweden, February 10, 2005:
Media does not work if burnt at 2x only 1x
Price: $30 Purchased from: www.siba.se Date purchased: December 2004 Burnt with Sony DRU-500A at 1x using firmware 2.1a. Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Silver. Media text is Memorex 4.7 GB DVD-R 4x 120 Minute. Media package type is Cake Box. Number of discs 25. Media UPC/EAN code is 5024460004373. Authoring/Burning comments: Ripped with DVD Shrink and burned with Nero 6.6.0.6 |
Comments posted by Antonio from Italy, January 31, 2005:
No comments
Burnt with NEC ND-3500A at 4x using firmware 2.18. Burning reliability is Good. PC reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex 4.7 GB DVD-R 4x. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: nero 6.6 Works fine on Microsoft Xbox |
Comments posted by alter k from Germany, January 24, 2005:
Does not work. Nero stops with error message.
Burnt with BenQ DW1620 (Pro) at 4x using firmware B7T9. Burning reliability is Poor. Media color is White. Media text is Memorex DVD-R 4.7GB PROFESSIONAL RECORDABLE DVD. Media package type is Jewel Case. Number of discs 5. Media UPC/EAN code is 024460541144. Authoring/Burning comments: Nero |
Comments posted by Joe from Canada, January 22, 2005:
No comments
Price: $3 Purchased from: futureshop Date purchased: December 2004 Burnt with LG GSA-4163B at 4x using firmware A101. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is 4X DVD DVD-R Recordable 4.7GB/120 Minutes. Media package type is Jewel Case. Number of discs 5. Media made in Taiwan. Authoring/Burning comments: Nero Express 6.6.0.5 Works fine on Homemighty DV-A1 |
Comments posted by Brad Tanner from United States, January 21, 2005:
Burned correctly, but I see a few glitches when I play it on my Broksonic DVCR810 DVD player.
Purchased from: Walmart Date purchased: October 2004 Burnt with NEC ND-2510A at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4.7 GB DVD-R 4x. Media package type is Jewel Case. Number of discs 5. Media made in Taiwan. Authoring/Burning comments: DVD Decryptor and Nero 6.6.0.6 Works fine on Broksonic DVCR810 |
Comments posted by Mark Kirchner from Sweden, January 15, 2005:
No comments
Price: $7 Purchased from: Walmart Date purchased: January 2005 Burnt with LG GSA-4163B at 4x using firmware 1.0. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is 4X DVD DVD-R Recordable 4.7GB/120 Minutes. Media package type is DVD Box. Number of discs 5. Media made in Taiwan. Media UPC/EAN code is 3470705583. Authoring/Burning comments: DVD Decrypter 3.5.0.2
DVD Shrink 3.2 |
Media image
 Click to enlarge |
Comments posted by Adelmo Silva from Portugal, January 12, 2005:
Great results on burning DVD video and Data!
Bons resultados em DVD Vídeo e Dados... Boa escolha!
Price: $10 Purchased from: www.fnac.pt Burnt with Teac DV-W50D at 4x using firmware 1.07. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Gray. Media text is Memorex DVD-R 4X. Media package type is Cake Box. Number of discs 10. Works fine on Sony Playstation 2 |
Comments posted by claudio from Sweden, January 09, 2005:
No comments
Burnt with Lite-On SOSW-852S at 2x Burning reliability is Good. PC reliability is Poor. DVD reliability is Poor. Media color is Silver. Media text is Memorex 4x DVD-R. Media package type is Cake Box. Number of discs 10. Media UPC/EAN code is 5024460003734. Does not work on Pioneer DV-717 |
Comments posted by Eric Lane from Canada, January 02, 2005:
fairly cheap.. $15 CAD for 25
was gonna get the best buy fujifilms but ran out by lunch on boxing day
Price: $0.6 Purchased from: best buy in kitchener, ontario Date purchased: December 2004 Burnt with BTC DRW 1016IM at 4x using firmware A07M. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex 4X DVDR R4.7 DVD-R Recordable 4.7GB 120 minute video. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Authoring/Burning comments: dvd decrypter mainly Works fine on Norcent DP 215 Works fine on Norcent DP 300 |
Comments posted by Lou Doucet from Sweden, December 25, 2004:
Burns well at 4X
Purchased from: Best Buy Date purchased: July 2004 Burnt with LG GSA-4160B at 4x using firmware A-302. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4X DVD DVD-R. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Authoring/Burning comments: Pinnacle Liquid Edition Pro Version 5.62 Works fine on Pioneer DV-434 Works fine on Toshiba SDV280 |
Comments posted by Lance Uppercut from United States, December 20, 2004:
No comments
Price: $1 Date purchased: March 2004 Burnt with Lite-On LDW-811S/851S at 4x using firmware HSOR. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver Gray. Media text is Memorex 4x DVD-R Recordable 4.7GB 120 Minute Video. Media package type is Jewel Case. Number of discs 10. Media made in Taiwan. Media UPC/EAN code is 034707055100. Authoring/Burning comments: Nero 6 Ultra Edition Reloaded Works fine on Emerson EWD-7003 |
Comments posted by jim from United States, December 18, 2004:
tried this media and whether it was burned with an iomagic drive or a maddog megastor it still was only recognized by some of my dvd players.
Price: $20 Purchased from: sears Date purchased: November 2004 Burnt with Mad Dog Megastor MD-16XDVD9 at 4x using firmware 2FA. Burning reliability is Good. PC reliability is Mixed. DVD reliability is Mixed. Media color is Silver. Media text is memorex. Media package type is Jewel Case. Number of discs 5. Media made in Taiwan. Authoring/Burning comments: shrink and nero Works fine on Cyberhome CH-DVD 300 Does not work on Sony DVP-NS715P |
Comments posted by jim from United States, December 16, 2004:
No comments
Burnt with Pioneer DVR-105 / DVR-A05 at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex is it live or is it memorex. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Works fine on Microsoft Xbox Works fine on Panasonic DVD-F65 Works fine on Sony Playstation 2 |
Comments posted by cgulka from France, December 06, 2004:
No comments
Burnt with BenQ DW1610 at 4x Burning reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4X DVD-R. Media package type is Cake Box. Number of discs 25. Works fine on Koss KD260 Works fine on Magnavox MRD250 |
Comments posted by Mike from Israel, December 06, 2004:
Great media!
I burned over 40 of these and no coasters! Great quality and even plays on the LG DVD/Video player (Which usually doesn't support DVD-/+R.
Plays on SEG DV637-S which isn't listed..
Burnt with Pioneer DVR-106 / DVR-A06 at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is White. Media text is Memorex 4x DVD-R (Is it live or is it Memorex? tm). Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: DVDCopy and Nero Works fine on LG DV1000 Works fine on Toshiba SD200E |
Comments posted by amg from Canada, November 15, 2004:
Only burnt at 4x, no problems encountered
Burnt with Plextor PX-708A at 4x using firmware 1.08. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R 4.7GB/120MIN. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Works fine on Panasonic DVD-RP62 |
Comments posted by ephur from United States, November 10, 2004:
No comments
Burnt with NEC ND-2500A at 4x using firmware 1.7b5. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R 4.7GB/120MIN. Media package type is Cake Box. Number of discs 50. Works fine on Philips DVD622 |
Comments posted by Red from Italy, October 17, 2004:
It works very well. Very good media.
Price: $30 Purchased from: Germany Date purchased: September 2004 Burnt with NEC ND-2500A at 4x using firmware 1.07b5. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media inkjet printable reliability is Good. Media color is Gray. Media text is Memorex "It is live or is it Memorex?". Media package type is Cake Box. Number of discs 50. Works fine on Elta 8883 Works fine on KiSS DP-1000 |
Media image
 Click to enlarge |
Comments posted by Dennis from United States, September 08, 2004:
Worked perfect the first time, making a backup copy of a dvd
Price: $2 Purchased from: Wal-Mart Date purchased: July 2004 Burnt with Plextor PX-708A at 4x using firmware 1.07. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex is it live or is it memorex, 4xdvd 4.7GB 120Min. Media package type is DVD Box. Number of discs 5. Media made in Taiwan. Media UPC/EAN code is 3470705581. Authoring/Burning comments: DVD Decrypter, ISO mode Read, ISO mode Write Works fine on Panasonic DVD-CP72S |
Comments posted by Alex from Sweden, August 30, 2004:
Media works great. Tested it on my Pioneer DVD-ROM (DVD-116, Firmware Ver. 1.22) and all my mpeg & avi movies seems to be intact.
Price: $3 Purchased from: Local SuperMarket Burnt with LG GSA-4120B at 2x using firmware A102. Burning reliability is Good. PC reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R 4.7 GB 120 Minute Video. Media package type is DVD Box. Number of discs 1. Authoring/Burning comments: Burned with Nero Burning ROM 6.3.1.20
I have the option to burn it in 4x. But since I can't afford to let my dvd-r gone to waste, I just use 2x to be on the safe side. |
Comments posted by Ted from United States, August 21, 2004:
No comments
Price: $0.8 Purchased from: Best Buy Date purchased: August 2004 Burnt with OptoRite DD0401 at 4x using firmware 120E. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex Is it Live or is it Memorex? 4x DVD-R 4.7GB. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Media UPC/EAN code is 034707055520. Authoring/Burning comments: Burned with Alchohol 120% Works fine on Magnavox MPD820 Works fine on Polaroid PDV-0800 Works fine on Sony DVP-S360 |
Comments posted by Mike from United States, August 09, 2004:
Several coasters.
Some have half inch sized dark spots on the DVD bottom, those are bad. Will not buy again.
Purchased from: Best Buy Date purchased: June 2004 Burnt with Pioneer DVR-106 / DVR-A06 at 4x Burning reliability is Poor. PC reliability is Good. Media color is Silver. Media text is Memorex Is is live or is it Memorex. Media package type is Cake Box. Number of discs 50. Media made in Taiwan. Media UPC/EAN code is 3470705572. Authoring/Burning comments: Toast |
Comments posted by luis Gaspar from Portugal, July 30, 2004:
not the same exact code
00 6A 00 00 01 40 C1 FD 9E D8 52 00 02 87 0E 15 .j...@....R.....
Price: $0.8 Burnt with LG GSA-4082B at 4x using firmware 206. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex is it live or is it memorex ? 4X DVD-R recordable 4.7GB 120Minute Video. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: CloneDVD 2.0.8.4 Works fine on Denver DVD-438 |
Comments posted by Watson McConnell from United States, July 27, 2004:
Media had different code by two bytes, code as follows:
Media worked in my picky Sony DVP-S550D and Sony PS2 SCPH 30001.
Comments posted by Jimmy from Belgium, July 23, 2004:
No comments
Burnt with Sony DW-U14A at 4x using firmware 1.0d. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media inkjet printable reliability is Good. Media color is Silver. Media text is Memorex 4X DVD-R recordable 4.7GB 120Minute Video. Media package type is Jewel Case. Number of discs 5. Media made in China. Authoring/Burning comments: Dvdshrink, burned with DVDDecrypter. Works fine on Philips DVP520 Works fine on Provision PRDVD172 |
Comments posted by apvm from Canada, July 09, 2004:
good
Burnt with BenQ DW822A at 4x using firmware B3IC. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is memorex. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: DVD Shrink Nero Works fine on Apex AD-1500 |
Comments posted by Chris C. from United States, July 01, 2004:
No comments
Price: $1 Purchased from: www.amazon.com Date purchased: June 2004 Burnt with Sharp DV-HR300 at 2x Burning reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R 4.7 GB recordable. Media package type is Cake Box. Number of discs 25. Works fine on Sharp DV-HR300 Works fine on Zenith DVB312 |
Comments posted by Fistandantilus from Canada, June 11, 2004:
Works great on my Dvd players,Xbox,Ps2.
Price: $10 Date purchased: May 2004 Burnt with I/O Magic Internal 4X DVD±RW/±R (IDVDRW4D) at 4x using firmware 2.60I. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex. Media package type is Jewel Case. Number of discs 5. Authoring/Burning comments: Dvdshrink 3.1 and Nero 6.0 Works fine on Cyberhome CH-DVD 300 Works fine on Philips DVD623 |
Comments posted by Peter from Sweden, June 06, 2004:
No comments
Price: $1 Burnt with Pioneer DVR-107 / DVR-A07 at 4x using firmware 1.05. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4.7GB 1x-4x. Media package type is Cake Box. Number of discs 10. Media UPC/EAN code is 5 024460 003734. Works fine on Philips DVD612 |
Comments posted by hbbq from Sweden, June 05, 2004:
Works great with NEC ND-2500a at 4x
Burnt with NEC ND-2500A at 4x using firmware 1.06. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex is it live or is it memorex? (tm) 4x DVD-R R4.7 www.memorex.com DVD-R Recordable 4.7GB 120 minute video. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: Video (DVD9) authored with DVD Shrink 3.1.7.6 and burnt with Nero 6.3.1.10
Video (DVD5) burnt from ISO with DVD Decypter 3.2.2.0
Data burnt with Nero 6.3.1.10 Works fine on Centrum Gemini 330 |
Comments posted by Tamás Németh from Hungary, May 29, 2004:
Very good media. The last 10 was written 4x speed, and there are playable JVC-XVN55 and SONY players.
Only one player could not play these DVD (about 50 percent): my friend's MAC built in DVD player .
Price: $1.1 Burnt with LG GSA-4081B at 4x using firmware A104. Burning reliability is Good. PC reliability is Mixed. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Instant copy 8 Works fine on JVC XV-N55SL |
Comments posted by dalton4life from United States, May 27, 2004:
Great media. I haven't had a bad one yet in over 100 burns. And the discs have played fine with no skips in many DVD players. I used some KHypdermedias that were CMC MAG. AF1 as well but they didn't play in some players while these did so I'm not quite sure what's going on there.
Price: $1 Purchased from: Compusa Burnt with Lite-On LDW-411S/451S at 4x using firmware FS0J. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4x. Media package type is Cake Box. Number of discs 50. Media made in Taiwan. Authoring/Burning comments: Nero 6.3.16 / DVD Decryptor Works fine on Apex AD-1100W Works fine on Apex AD-1225 Works fine on Apex PD-450 Works fine on Polaroid DV700 Works fine on Sony Playstation 2 |
Comments posted by Donald from United States, May 23, 2004:
Aparently CMC made some bad batches of memorex. I used a BTC 1008 like some other reviewer but his were all good and 90 of 100 were bad on mine. This is the only time memorex has not been reliable for me. I have never had DVDs this bad before. I have burned about 1500 discs.
Price: $1 Purchased from: Amazon.com Date purchased: March 2004 Burnt with BTC DRW 1008IM at 4x using firmware 1.06. Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media color is White. Media text is White printable. Media package type is Cake Box. Number of discs 100. Authoring/Burning comments: Nero and DVDdecrypter were used. |
Comments posted by tolaat01 from Sweden, May 22, 2004:
max x6
Burnt with NEC ND-2500A at 6x using firmware 1.06 harrie beta 7. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is memorex live. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: burned 20 so far.
backup dvd video and data only.
burn with sonic record now deluxe 6.5 at max speed.
checked Works fine on LG 3351P |
Comments posted by Raffaele from Italy, May 20, 2004:
Using firmware A303, the DVD is not leggibile to PC neither on the DVD Player.
On the disc it is possible to see directory and the files, but they are not usable.
With firmware A302 it works perfectly
Price: $1.3 Date purchased: April 2004 Burnt with LG GSA-4040B at 4x using firmware A302. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Blue. Media text is Memorex 4.7. Media package type is Cake Box. Number of discs 10. Works fine on Pioneer DV-454 |
Comments posted by Jerry from United States, May 19, 2004:
Ok Media. Not good as Ritek. Cant Play in cheap or older dvd players. Mostly used as computer to computer dvd-r media.
Comments posted by Marinus from Netherlands, May 15, 2004:
No comments
Price: $1 Purchased from: www.cdrwinkel.com Date purchased: May 2004 Burnt with Lite-On LDW-811S/851S at 4x using firmware DR8GS0H. Burning reliability is Poor. PC reliability is Mixed. DVD reliability is Poor. Media color is Silver. Media text is Memorex 4x DVD. Media package type is Cake Box. Number of discs 25. Media UPC/EAN code is 024460003741. Authoring/Burning comments: Nero 6 |
Comments posted by APVM from Canada, May 11, 2004:
burnt over 25, no coaster yet and all works fine.
Burnt with LG GSA-4081B at 4x using firmware A101. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4X DVD-R recordable 4.7GB 120Minute Video. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Media UPC/EAN code is 034707055520. Works fine on Apex AD-1500 |
Comments posted by Phillip Dampier from Sweden, May 02, 2004:
Media purchased 4/28 Officemax. Comes in blue colored box with "5PK" in red on top right of box - manufacturer code on bottom left of reverse 5395 5994R; Part Number 3202 5575; (c)2003. Frequently on offer for $9.99 sale price.
Media burned fine until the last 15 minutes when Nero DVD-Speed showed major flaws in the media; visual inspection of recorded program showed severe pixel, audio problems and freezing during playback of this portion. Flaw was consistent across samples drawn from three individual boxes purchased at different store locations. Media not acceptable, particularly for what is often considered "premium" media found in jewel cases.
This is apparently a new run of CMC AF1 media because its media code was not apparent here. It's no improvement.
Officemax will cheerfully refund 100% of your money on incompatible media.
Price: $2 Purchased from: Officemax Date purchased: April 2004 Burnt with Plextor PX-708A at 2x using firmware 1.06. Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media color is Silver. Media text is Memorex DVD-R Recordable R 4.7 4.7GB/120 minute video. Media package type is Jewel Case. Number of discs 5. Media made in Taiwan. Media UPC/EAN code is 034707055759. Authoring/Burning comments: DVD Shrink w/Nero burning engine 6.3.1.6 Does not work on Panasonic DVD-LV60 |
Comments posted by shimman from United States, May 02, 2004:
inconsistency in writing qualtiy from disks to disks even from the same spindle
Price: $1.1 Purchased from: staples Date purchased: April 2004 Burnt with Lite-On SOHW-812S at 4x using firmware US0J. Burning reliability is Poor. PC reliability is Mixed. Media color is Silver. Media text is Memorex 4X DVD DVD-R. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Media UPC/EAN code is 03470705552. Authoring/Burning comments: nero6.3.1.2 cd/dvd speed 2.11.4f |
Comments posted by Took our job from Sweden, April 30, 2004:
Good burning reliability and good compatability with stand-alone players. This media is easily confused with it's evil cousin with media ID MBI 01RG20 that looks exactly the same. DVD-R:s with that ID, however, sucks big time and should be avoided at all cost.
Burnt with Pioneer DVR-104 / DVR-A04 at 2x using firmware 1.41. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4X DVD R DVD-R Recordable 4.7GB 120 minute video. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: Images burned with DVDDecrypter Works fine on Philips DVD711 |
Comments posted by 338 from United States, April 29, 2004:
Is it just me? Doesn't it seem like the majority of complaints here are from people using SONY burners?.
I've burned flawless after flawless dvd's with this media(No coasters yet!). I think you die hard SONY people better get off the SONY bandwagon and open your eyes.
Price: $1 Purchased from: Staples Date purchased: April 2004 Burnt with Lite-On LDW-411S/451S at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Silver. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Authoring/Burning comments: DVD to DVD Copy(PRO DVD), DVD Shrink, DVD Decrypter,DVD X Copy Platinum, Nero 6 |
Comments posted by roadboy from Canada, April 24, 2004:
Media works great at 4X on the Toshiba SD-R5112
Price: $30 Purchased from: Future Shop Canada Date purchased: April 2004 Burnt with Toshiba SD-R5112 at 4x using firmware 1033. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media inkjet printable reliability is Good. Media color is Purple. Media text is Memorex 4X DVD-R Recordable 4.7 GB 120 Minute Video. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Media UPC/EAN code is 3470705552. Works fine on Panasonic DVD-RP56 |
Comments posted by Yuri from United States, April 18, 2004:
Very unstable with data and video.
Read errors at 2/3 of the disk.
Price: $1 Purchased from: Amazon.com Date purchased: February 2004 Burnt with Lite-On LDW-411S/451S at 4x using firmware GSB4. Burning reliability is Poor. PC reliability is Mixed. DVD reliability is Poor. Media color is Purple. Media text is Memorex DVD-R. Media package type is Cake Box. Number of discs 100. Media made in Taiwan. Authoring/Burning comments: Nero 9 |
Comments posted by fsadlf from United States, April 18, 2004:
No comments
Purchased from: ebay Date purchased: March 2004 Burnt with Memorex DVD+RW/+R at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media inkjet printable reliability is Good. Media color is Silver. Media text is Slver. Media package type is Cake Box. Number of discs 50. Authoring/Burning comments: It work great.. |
Comments posted by tt8ng from United States, April 16, 2004:
dye color: light purple
Price: $0.8 Purchased from: Office Depot Burnt with OptoRite DD0201/DD0203 at 2x using firmware 2.30. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4X. Media package type is Cake Box. Number of discs 50. Authoring/Burning comments: Decrypter, Nero 6, DVD shrink Works fine on Sony DVP-NS705 |
Comments posted by Jason from United States, April 13, 2004:
All 5 discs burned fine without any coasters.
However moving chapter menus seems to make the contents just a little more blurry than still chapter menus. But I don't think that's the discs' fault.
Price: $2 Purchased from: Circuit City Date purchased: April 2004 Burnt with Sony DRU-530A at 4x using firmware 2.0C. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is 4X DVD-R 4.7GB 120 Min Video. Media package type is Jewel Case. Number of discs 5. Media made in Taiwan. Authoring/Burning comments: Used bundled software - Sonic MyDVD Works fine on Sony DVP-NC600 |
Comments posted by Mike from United States, April 10, 2004:
I have been using this media to burn a DVD production I made from video and sill footage for a charity. The chairity has distributed over 100 of these dvd at fund raisers. So it has been played on several brands of DVD players and computers. I have noticed that it plays good to better on may set top dvd players. However, it has a poor track recored running on Laptop DVD-ROM/DVD-RAM/DVD+-R/RW drives. Tosiba drives seem to be the worst and I have found documents from Toshiba stating not to use memorex media on thier dvd drives. I have no problem burning or playing on set top plays though after burning over 200 I have had a few disk that have had problems when burned to capacity. I accounted to flawed media, for it is very few.
Price: $1.5 Purchased from: CDW.COM, OfficeMax, BestBuy Burnt with Sony DRU-510A at 4x using firmware 1.0f. Burning reliability is Good. PC reliability is Mixed. DVD reliability is Good. Media color is Gray. Media text is Memorex 4x DVD DVD-r Recordable 4.7GB 120Minute Video. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: I've used Adobe Encore DVD and Pinnacle Instant CD/DVD Does not work on Toshiba SD2550A |
Comments posted by Chargerdan from United States, April 08, 2004:
Burns well. A few have problems towards the outer rim. I would keep burns below 4gb. Burns at 4x on my TDK 440N but my Iomega Super DVD only allows it to burn at 2x.
Burnt with TDK 440N at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Mixed. Console reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: DVD Shrink, DVD Decrypter and Nero Works fine on Panasonic DMR-E80H Works fine on Sony DVP-S570D |
Comments posted by Doug from United States, April 06, 2004:
No comments
Burnt with OptoRite DD0201/DD0203 at 4x using firmware 2.17. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Purple. Media text is Memorex 4x DVDR4.7 DVD-R Recordable 4.7GB 120 Minute Video. Media package type is Jewel Case. Number of discs 5. Media made in Taiwan. Media UPC/EAN code is 034707055100. Authoring/Burning comments: TMPGEncDVD Author, DVDShrink, Nero Works fine on Toshiba SD1600 Works fine on Toshiba SD2700 |
Comments posted by SpeedBurner from United States, March 23, 2004:
Burns fine, worked on all players I've tried except the Fisher DVD-S1500. My troubleshooting showed that most DVD-R disks did not work with the S1500.
Purchased from: MacConnection Date purchased: March 2004 Burnt with Sony DW-U10A at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is silver. Media package type is Cake Box. Number of discs 50. Media made in Taiwan. Media UPC/EAN code is 3470705572. Authoring/Burning comments: Burned on iMac with Toast Titanium 6 Works fine on Sony DVP-NS315 Does not work on Fisher S1500 |
Comments posted by J from United States, March 20, 2004:
No comments
Burnt with Sony DRU-510A at 4x using firmware 1.0f. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD DVD-R recordable 4.7GB 120 minute video. Media package type is Cake Box. Number of discs 25. |
Comments posted by starsonic from United States, March 19, 2004:
Media burnt perfectly on 4X, 2X, 1X. No coaster whatsoever.
Price: $1.1 Purchased from: Best Buy Date purchased: February 2004 Burnt with NEC ND-2500A at 4x using firmware 1.06. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is None. Media package type is Cake Box. Number of discs 50. Media UPC/EAN code is 03470705572. Authoring/Burning comments: Authored with DVDShrink and burned with Nero 6.0.0.28 Ultra Edition Works fine on AMW V99 Works fine on Samsung DVD-S221 Works fine on Sony DVP-NS400D Works fine on Sony SLV-D100 Does not work on Toshiba SD1600 |
Comments posted by APVM from Canada, March 11, 2004:
Burn at 4X with LG 4040 A302 firmware, no problem and no coaster yet.
Burnt with LG GSA-4040B at 4x using firmware A302. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is DVD-R 4X. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Media UPC/EAN code is 034707055520. Authoring/Burning comments: Nero 6.3.0.3 and Tmpgenc DVD author Works fine on Apex AD-1500 |
Comments posted by duke13630 from United States, March 08, 2004:
came with jewel casing and inserts. Claims to be 4x and my burner claims to burn at 4x but I get 2x. Not sure why but everything works, about 20 rips so far and no coasters.
Price: $2 Purchased from: best buy Date purchased: February 2004 Burnt with Iomega Super DVD Writer 4x All-Format Internal at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is 4x 4,7gb dvd-r recordable. Media package type is Jewel Case. Number of discs 10. Media made in Taiwan. Media UPC/EAN code is 034707055100. Authoring/Burning comments: dvd shrink and encrypter Works fine on Sony DVP-NC665P Does not work on Toshiba SD3109 |
Comments posted by miR from Other, March 06, 2004:
No comments
Price: $50 Purchased from: www.futureshop.ca Date purchased: March 2004 Burnt with MSI DR8-A at 1x using firmware 1.30D. Burning reliability is Poor. Media color is Silver. Media text is Memorex. Media package type is Cake Box. Number of discs 25. |
Comments posted by QuiCo from Germany, March 05, 2004:
No comments
Price: $30 Purchased from: www.amazon.de Date purchased: February 2004 Burnt with NEC ND-1300A at 4x using firmware 1.0A. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is is it live or is it Memorex. Media package type is Cake Box. Number of discs 25. Media UPC/EAN code is 5024460003741. Authoring/Burning comments: Burned with CloneDVD 1.3.11.2 Works fine on Grundig GDV 130 Works fine on SEG Hollywood Works fine on Yamakawa 215 |
Comments posted by nk from United States, March 03, 2004:
Burnt at 4X using Nero 6.
Had no problem in reading the burnt media
Price: $1.5 Purchased from: staples Date purchased: March 2004 Burnt with Creative DVD±RW Dual 8x (DR8420E) at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4X. Media package type is Jewel Case. Number of discs 10. Media made in Taiwan. Authoring/Burning comments: Nero 6 Works fine on Sony DVP-NS300 |
Comments posted by Jim Bean from United States, March 03, 2004:
When burning this media in the recently released Sony DRU-530 with firmware 2.0a, at 2x or 4x it produces skipping at the end of the movies when burnt close to full capacity. It the total size of the file is less than 4GB the burns are flawless, however this is a very limiting factor and I would not recommend this media.
Price: $1.5 Purchased from: Wal-Mart Burnt with Sony DRU-530A at 4x using firmware 2.0a. Burning reliability is Mixed. PC reliability is Mixed. DVD reliability is Mixed. Console reliability is Mixed. Media color is Silver. Media text is Memorex "Is it live or is it Memorex?" 4x DVD-R Recordable 4.7GB. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: DVDShrink's 3.1.7b4 that uses DVDDecryptor to do the writing of the ISO images. Works fine on Daewoo DHC-XD350 Works fine on Daewoo DVD-S151 |
Comments posted by Dan Christensen from Canada, March 01, 2004:
Part number 3202 5510
Burnt with Sony DRU-510A at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD R R4.7 DVD-R RECORDABLE 4.7GB 120 MINUTE VIDEO. Media package type is Jewel Case. Number of discs 10. Media made in Taiwan. Media UPC/EAN code is 0 34707 05510 0. Authoring/Burning comments: growisofs to burn (under linux) Works fine on Koss KD270 Works fine on Malata DVP-393 |
Comments posted by glockjs from United States, February 29, 2004:
zero probs with this media. burned every dvd in under 15 min. even burned to the outer edge. highly recomendable.
Price: $1.6 Purchased from: wally world Date purchased: February 2004 Burnt with BTC DRW 1008IM at 4x using firmware 56. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is memorex 4x dvd r r4.7 dvd-r recordable 4.7gb 120 minute video. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: nero, dvdshrink Works fine on Philips DVD624AT |
Comments posted by Soultribes from France, February 29, 2004:
this media is bullsh**, buy 30 dvd-r and 21 coasters, this is the worst media i never test !
Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.30. Burning reliability is Poor. PC reliability is Poor. DVD reliability is Mixed. Console reliability is Poor. Media color is Silver. Media text is memorex dvd-r 4.7gb. Media package type is Jewel Case. Number of discs 10. Authoring/Burning comments: authored with dvdshrink and ifoedit
burned with instantdisc or alcohol |
Comments posted by Carmonte from Germany, February 28, 2004:
No comments
Burnt with NEC ND-1300A at 2x using firmware 1.08. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4.7 GB DVD-R 4x. Media package type is Jewel Case. Number of discs 1. Authoring/Burning comments: Clone DVD Any DVD Works fine on Pioneer DV-350 |
Comments posted by Dude from United States, February 26, 2004:
I'm able to burn at 4X all of the time and I have't had a bad disc in the first 100 I went through.
I did have issues with butning them in DVD Shrink which uses Nero Recode (only 1X), but I believe that to be a software issue. It worked on all of the other software packages at 4X
Price: $1 Purchased from: Wal-Mart Price Match on Office Max and Best Buy Date purchased: February 2004 Burnt with Memorex Dual-X at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is huh. Authoring/Burning comments: Clone DVD and DVD Shrink. |
Comments posted by Matthew Rorie from Sweden, February 26, 2004:
Haven't had any problems with these discs at all, save for burning a copy of an extremely scratched disc, which caused some audio problems on the copy (mismatched audio/visual; went away with a stop/play on my DVD player). So far I've done 6 or 7 discs at 2.4x speed with DVD Shrink and they all play fine on my DVD player. (Zenith DVB312.)
Price: $1 Purchased from: Compusa Date purchased: February 2004 Burnt with Lite-On LDW-411S/451S at 2.4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD DVD-R Recordable. Authoring/Burning comments: Ripped with DVDShrink and burned with Nero Burning ROM 6.0.0.11 Works fine on Zenith DVB312 |
Comments posted by mixxerr from United States, February 26, 2004:
bought a 25 pack and burned 16.i have had 100% success so far.
Price: $40 Purchased from: local walmart store Date purchased: February 2004 Burnt with NEC ND-1300A at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is White Silver. Media text is media text is dvd-r recordable 4.7gb 120min video. Authoring/Burning comments: authored with tmpgenc dvd author and burned with nero 5.5.10.42 . i used dvd-video mode and also dvd-rom (udf-iso) mode. both ways worked for me.
Works fine on Apex AD-1100W |
Comments posted by Francesco from Italy, February 24, 2004:
The surface is printable
Price: $1.1 Purchased from: ROme Italy Date purchased: February 2004 Burnt with LG GSA-4081B at 2x using firmware A100. Burning reliability is Good. PC reliability is Good. DVD reliability is Mixed. Media color is White. Media text is none. Authoring/Burning comments: Nero 6.3.0.2 Works fine on Daewoo S2122 |
Comments posted by Eric from United States, February 21, 2004:
Durned great in NEC 2500 and played well in Xbox Thomson drive.
Price: $1.5 Purchased from: Wal-Mart Date purchased: February 2004 Burnt with NEC ND-2500A at 4x using firmware 1.06. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is DVD-R Recordable 4.7 GB 120 Video. Authoring/Burning comments: DVD XCopy Works fine on Microsoft Xbox Works fine on Samsung DVD-M301 |
Comments posted by ladynka from Czech Republic, February 12, 2004:
No comments
Burnt with Lite-On LDW-811S/851S at 4x using firmware HS06. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Blue. Media text is Memorex 4x DVD-R General use data 4,7GB Video 120 min. Works fine on Samsung SV-DVD3E |
Comments posted by Michel Siegenthaler from Switzerland, February 10, 2004:
Medie works if burnt with Nero 6 at 2x speed. I used Nero Vision Express 2 but had to ad the "Audio_ts" file. Otherwise my United DVD 3151
wouldn't play the movie.
Price: $1.9 Purchased from: Interdiscount (Switzerland Date purchased: January 2004 Burnt with NEC ND-1300A at 2x using firmware 1.0A. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex Is it live or is it Memorex? 4xDVD R 4.7 DVD-R 4.7GB 120 MINUTE VIDEO. Authoring/Burning comments: Nero Vision Express, and burned it after coding with Nero Burning Rom 6. Works fine on United DVD 3151 |
Comments posted by richard from Puerto Rico, February 08, 2004:
No comments
Price: $30 Purchased from: sams club Date purchased: January 2004 Burnt with Sony DRX-510UL at 4x Burning reliability is Mixed. PC reliability is Good. DVD reliability is Mixed. Media color is White. Media text is silver. Works fine on GoVideo DV2130 |
Comments posted by Matt Hemsteger from United States, February 05, 2004:
I got this data after having good results with memorex CD-Rs and DVD-RWs. Burns went without error during burn process .. however the disks are horrible to play. In my Panasonic DVD-R31 at the TV and my MEMOREX Dual-X DVD player on my computer the media had pixilated images, messed up sound, and froze into the movie out of 4 movies all the time. Tried burning at 1x and 2x, same results. Data plays from HD fine, and I copied it to a RW to make sure and the RW played without a hitch. Im going to contact memorex and see what the deal is. Ive made 11 coasters with my first 11 tries.
Price: $1.3 Purchased from: www.pagecomputers.com Date purchased: February 2004 Burnt with Memorex 8x4 Dual-X Internal at 4x Burning reliability is Good. PC reliability is Poor. DVD reliability is Poor. Media color is White. Media text is Print DVD-R 4.7GB 4X. Authoring/Burning comments: Nero 6, DVDShrink, DVD X-Copy Platinum Does not work on Panasonic DVD-RV31 |
Comments posted by shonflare from United States, February 05, 2004:
I use a TDK 440N PC Burner and I Set Top Pioneer DMR-E50. I have had about a 40% failure rate with these Memorex DVDs. I bought 2 25pk spindles and 21 of them failed to burn without flaw. Ther is usually a 1/2 inch burned dot on the bad disks that appears only after the burn. I find these discs to be a total waist of money.
Price: $20 Purchased from: Staples Date purchased: January 2004 Burnt with TDK 440N at 4x Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Console reliability is Poor. Media color is Silver. Media text is Memorex 4X DVD R4.7. Authoring/Burning comments: Nero 6 / DVD X Copy Simple and Express / Adobe Encore |
Comments posted by Zack S from United States, February 04, 2004:
works fine in most of my players
Price: $1.4 Purchased from: Staples Date purchased: January 2004 Burnt with NEC ND-1300A at 4x using firmware 1.09. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R R4.7 4.7GB 120 minute video. Authoring/Burning comments: Nero 6 Works fine on Mintek DVD-1600 |
Comments posted by Michael Squitieri from Sweden, February 04, 2004:
No comments
Burnt with TDK 440N at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is White. Media text is 4x DVD-R 4.7 GB 120 minute video Memorex. Works fine on Sylvania DVC860D |
Comments posted by fdt from Sweden, February 04, 2004:
No comments
Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.07. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4X DVD-R Recordable 4.7GB 120 Minute Video. Authoring/Burning comments: Nero Burning Rom 6.3.0.2 Works fine on Yamaha DVR-S120 |
Comments posted by Mike from Sweden, February 01, 2004:
Media works MAYBE half of the time. There have been times where I had 3 good burns in a row but recently had 5 or 6 bad burns in a row. Bought a spindle of 50. I suggest a different media.
Purchased from: www.bestbuy.com Burnt with Toshiba SD-R6012 at 1x Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x dvd-r recordable 4.7gb 120 minute video www.memorex.com. Works fine on Apex AD-1110W Works fine on Apex AD-1130W |
Comments posted by vnp from United States, January 31, 2004:
Media does not work with the Matshita UJ-816 drive on the Apple PowerBooks aluminum.
Burnt with Panasonic UJ-815 at 2x using firmware UJ-816. Burning reliability is Poor. PC reliability is Mixed. DVD reliability is Mixed. Media color is Silver Purple. Media text is Memorex 4x DVD-R R4.7 DVD-R RECORDABLE 4.7GB | 120 MINUTE VIDEO. Authoring/Burning comments: System: Apple G4 PowerBook 1.25 with Matshita / Panasonic UJ-816 rev. DXJ3.
Software: DVD backed up to a 5.2k RPM IDE drive with DVDBackup, burned with Roxio Toast 6 Titanium in DVD-ROM (UDF) mode.
4 coasters out of a 5 box DVD set. But I do get to keep the jewel cases. Don't use Memorex with your PowerBook! Works fine on Panasonic DVD-RP56 |
Comments posted by Thierq from Switzerland, January 30, 2004:
No comments
at 4x Burning reliability is Good. DVD reliability is Good. Media color is Silver. Media text is MEMOREX DVD-R 4X. Works fine on JVC XV-N5 |
Comments posted by L-burna from Sweden, January 30, 2004:
5 discs with jewel cases at walmart for 11 bux
Price: $10 Purchased from: walmart Date purchased: January 2004 Burnt with NEC ND-2500A at 4x using firmware 1.6. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is dvd-r recordable 4.7gb 120min video. Authoring/Burning comments: nero 6.3.0.2, dvd shrink 3.1? Works fine on JVC XV-S300BK |
Comments posted by Damian from Germany, January 26, 2004:
Best -R/4x Media i've ever used
Price: $1.2 Purchased from: www.amazon.de Date purchased: January 2004 Burnt with Sony DRU-510A at 4x using firmware 1.0f. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex. Authoring/Burning comments: Nero 6.3.0... Works fine on Toshiba SD210E |
Comments posted by qweryt from United States, January 23, 2004:
No comments
Price: $1 Purchased from: CompUSA Date purchased: January 2004 Burnt with Pioneer DVR-104 / DVR-A04 at 2x using firmware 1.40. Burning reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4.7 GB DVD-R 4x speed. Works fine on Apex AD-600 |
Comments posted by Frank Slove from United States, January 23, 2004:
I have burned over 200 Memorex DVD-R's and have not had a single bad burn to date! I have no problems with playback on DVD-ROM or stand alone DVD players burning at 4x.
Price: $1 Purchased from: CompUSA, Best Buy Date purchased: January 2004 Burnt with Sony DRU-500A at 4x using firmware 2.0f. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media inkjet printable reliability is Good. Media color is Gray. Media text is Memorex 4X DVD-R. Authoring/Burning comments: Nero 6.0.23
DVDDecryptor 3.1.7.0 Works fine on Panasonic DVD-RP62 Works fine on Panasonic DVD-RP91 |
Comments posted by Bob from United States, January 19, 2004:
Burned 4 movies with no problems so far.
Price: $0.4 Purchased from: OFFICEMAX Date purchased: January 2004 Burnt with Lite-On LDW-411S/451S at 4x using firmware SF0F. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Purple. Media text is Memorex dvd-r 4.7gb 120 min. 4x. Authoring/Burning comments: DVD X-COPY XPRESS Works fine on JVC XV-S30BK Works fine on Toshiba SD2700 |
Comments posted by Michi from Germany, January 18, 2004:
No comments
Date purchased: January 2004 Burnt with LG GSA-4081B at 4x using firmware A100. Burning reliability is Good. PC reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R 4.7GB 120 Minute Video. Authoring/Burning comments: burned with Nero 6.3.0.0 and Alcohol 120% |
Comments posted by molle from Other, January 15, 2004:
These disc's are awesome, burns everything at 4x without a hitch.
i have always found Memorex discs great, used them for my cd-r and now for my dvd-r and will for sure keep on using them.
Purchased from: www.siba.se Date purchased: January 2004 Burnt with NEC ND-1300A at 4x using firmware 1.09. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Purple. Media text is Nothing (printable). Authoring/Burning comments: Stomp RecordNow Max 4.50 Works fine on Centrum Gemini 200 Works fine on Centrum Gemini 210 |
Comments posted by Mark from Other, January 15, 2004:
I have burned over 50 of these in past month without a single problem.
Price: $1 Purchased from: Office Depot Date purchased: December 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Purple. Media text is 4x DVD R DVD-R Recordable 4.7 GB 120 Minute Video Memorex Is It Live or Is It Memorex. Authoring/Burning comments: I have used DVD X COPY, NERO and ULEAD MOVIE STUDIO. Works fine on Panasonic SA-HT70 |
Comments posted by giant from Other, January 13, 2004:
Excellent results. Must have burned nearly 100 of these discs in the past 5 months and not a single coaster yet. 4x burn works perfectly.
Comments posted by dragn454 from Other, January 13, 2004:
I have had great luck with these and no coasters. I am using the Sony DRU-500A with the latest firmware upgrade and burning at 4x. Suffering NO pixalization as I do with the RITEKG04.
Burnt with Sony DRU-500A at 4x using firmware 2.0f. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4X 4.7. Authoring/Burning comments: Nero 5.5.10.7 Find that this is a easy to use program. Works fine on Microsoft Xbox |
Comments posted by Jason Anderson from Other, January 13, 2004:
No comments
Price: $1 Purchased from: Best Buy Date purchased: December 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R 4.7GB 120 Minute Video. Authoring/Burning comments: DVD Decrypter, DVD Shrink, CopyToDVD Works fine on Panasonic DVD-RV31 Works fine on Pioneer DV-363 |
Comments posted by Kyle Smith from Other, January 12, 2004:
No comments
Price: $10 Purchased from: Staples Date purchased: January 2004 Burnt with HI-Val HDVDRW4D at 4x using firmware 2.30. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R. Authoring/Burning comments: Burned with Nero 6.3.0.0 Works fine on GE Digital GE1101P |
Comments posted by SteveGuy from Other, January 10, 2004:
These Memeorex 4.7 DVD-R are pure crap...well almost pure. Over 20% failure rate. When they do burn successfully they play fine. I bought two 25-packs so far and had 7 fail in one pack and 5 on the other. The burner says they are already written to (they aren't) or that they are unrecordable. Don't waste your money on this brand. They also scratch too easily making them unplayable on some players. Hey Memorex, where's my $26.00 refund?
Burnt with Sony DW-U14A at 4x Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Purple. Media text is memorex dvd-r 4x. Authoring/Burning comments: burned on a Sony DW-U12A...not on pick list. |
No comments
Burnt with Sony DW-U14A at 4x Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Purple. Media text is memorex dvd-r 4x. |
Comments posted by k m from Other, January 09, 2004:
Media works great only 1 coaster out of 50 pieces, and that was my own fault.
Price: $1.1 Purchased from: Best Buy Date purchased: December 2003 Burnt with NEC ND-1300A at 4x using firmware 1.08. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4X. Authoring/Burning comments: Nero 6.0.0.0 Works fine on Sharp DV-S1H |
Comments posted by GasMeat from Other, January 08, 2004:
Media works at both 1x and 2x. Tested only with PSX2 with no issues whatsoever. Only 1 coaster so far and that was due to human error on my part.
Price: $1.4 Purchased from: Staples Date purchased: January 2004 Burnt with Sony DRU-510A at 2x using firmware 1.0d. Burning reliability is Good. PC reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4.7GB. Authoring/Burning comments: DVD Decrypter 3.1.9 |
Comments posted by Per from Other, January 07, 2004:
Burnt 22 dvds now and not a coaster yet. Never tested with older firmware than 302.
Price: $2 Purchased from: On off sweden Date purchased: January 2004 Burnt with LG GSA-4040B at 4x using firmware 302. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is 4x dvd-r, dvd-r 4,7 gb 120 minute video. Authoring/Burning comments: Neo dvd, b's recorder gold 5, nerovision express 2 Works fine on Centrum Gemini 200 Works fine on Centrum Libra Works fine on Sony Playstation 2 |
Comments posted by J. Alan Wall from Other, January 05, 2004:
Burned about three of these so far with no problems so far. Plays all right in all my DVD players. JAW
Price: $2 Purchased from: Wal-Mart Date purchased: December 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.05. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R Recordable 4.7GB 120 Minute Video. Works fine on Apex AD-1100W Works fine on Norcent DP 300 Works fine on RCA RC5215P |
Comments posted by Joe from Other, January 05, 2004:
No comments
Date purchased: December 2003 Burnt with Plextor PX-708A at 4x using firmware 1.04. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R. Authoring/Burning comments: DVD Decrypter
DVD Shrink Works fine on Apex AD-1010W Works fine on Coby DVD-515 Works fine on Toshiba SDK625 |
Comments posted by Xalky from Other, January 04, 2004:
Would not play in RCA player with a label applied but played fine with no label. Plays well in PS2 with or without label. I imagine that a small hub label would work OK.
Price: $1.5 Purchased from: Walmart Date purchased: December 2003 Burnt with Plextor PX-708A at 4x using firmware 1.02. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R 4.7GB. Authoring/Burning comments: ImgTool,burned with DVDdecrypter Works fine on RCA RC5215P Works fine on Sony Playstation 2 |
Comments posted by ST.Rage from Other, January 03, 2004:
I wish I had found this site before I wasted $50 on this media. As one of the other users stated this media is worthless with the Sony DRU-510A, I usually make 3 coasters before I get a successful burn. When using other media e.g fujifilm or Imation I burn successfully 100% of the time. However when it does burn succesfully it plays just fine in my DVD players.
Price: $1 Purchased from: Best Buy Date purchased: December 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0d. Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is memorex 4X DVD-R 4.7GB 120 Minute Video. Authoring/Burning comments: DVD Shrink-Nero 6 Works fine on Microsoft Xbox Works fine on Sony DVP-S435D |
Comments posted by Travis from Other, January 03, 2004:
Works Great with my Playstation 2, and all the DVD Players I have tried. Haven't had any coasters yet. Very big Plus!!
Price: $30 Purchased from: Best Buy Date purchased: January 2004 Burnt with Micro Advantage 4DVDRW at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Purple. Media text is Memorex DVD-R. Authoring/Burning comments: TMPGEnc Plus 2.5, Authored TMPG DVD Author, Burned Nero 6.0 Works fine on Memorex MVD-2027 |
Comments posted by Dicky from Other, January 02, 2004:
Media takes about 20 seconds to start actual burning then burns at 4.1x (5,706KB)
Price: $1.5 Purchased from: BestBuy Canada Date purchased: January 2004 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.07 RPC1. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver Purple. Media text is Memorex 4X DVD-R recordable 4.7GB 120Minute Video. Authoring/Burning comments: Authored with Prassi and burned with DVDDecrypter 3.1.9.0 Works fine on Daytek P871 Works fine on Magnasonic DVD803-2 Works fine on Norcent DP 300 Works fine on Toshiba SD1800 |
Comments posted by speedx from Other, January 02, 2004:
Works great no probs, burned 5 dvds so far at 4x
Price: $1.5 Purchased from: bestbuy Date purchased: January 2004 Burnt with LG GSA-4040B at 4x using firmware 302. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Purple. Media text is memorex/silver top. Authoring/Burning comments: dvdshrink/nero 6 Works fine on Pioneer DV-414 |
Comments posted by HiM from Other, January 01, 2004:
Works fine now with 10 diffrent dvd-player...burn i X4 then there was a little problem fore some players, but i now burn them at X2 and it work with all player that i have tested...
Comments posted by MPNX2 from Other, December 30, 2003:
Media works well in my DVR-A05. Burned at a speed of 4.1X and has worked well in my Panasonic S35, Tronics CMD100, and a Pioneer DVL-90 without problems.
Additional information:
Price: $20 Purchased from: Staples Date purchased: December 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.33. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4X DVD DVD-R Recordable 4.7 GB 120 Minute Video. Authoring/Burning comments: Authored with DVD Shrink and burned with DVD Decrypter. Works fine on Curtis Mathes CMD1000 Works fine on Panasonic DVD-S35 Works fine on Pioneer DVL-90 |
Comments posted by Eric from Other, December 29, 2003:
Have not had a single coaster with this media, it works great.
Date purchased: December 2003 Burnt with Plextor PX-708A at 4x using firmware 1.04. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R. Authoring/Burning comments: DVD Shrink
DVD Decrypter Works fine on Coby DVD-515 Works fine on Toshiba SDK625 |
Comments posted by john from Other, December 26, 2003:
Memorex DVD-R
Single Sided Version 2.0
Use only with
DVD-rw
DVD-ram
Price: $20 Purchased from: Staples Date purchased: December 2003 Burnt with Sony DRU-510A at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex 4.7gb/120 min video. Authoring/Burning comments: burntocd
Works fine on Apex AD-1100W Works fine on Apex AD-1200 Works fine on JVC XV-F85GD |
Comments posted by Vance Howard from Other, December 25, 2003:
Would not burn, bought a 5 pack and all of them I had write errors with. Changed to a different brand media (Sony) and had no problems.
Price: $2 Purchased from: Wal Mart Date purchased: December 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0d. Burning reliability is Poor. Media color is Silver. Media text is Memorex Is it live or is it Memorex 4x DVD-R Recordable 4.7 gb 120min video. Authoring/Burning comments: DVD X Copy Express to archive. |
Comments posted by RAS from Other, December 20, 2003:
No comments
Price: $1 Purchased from: Office Depot Date purchased: December 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0d. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is memorex dvd-r 4x. Works fine on AMW S99 Works fine on JVC XV-S300BK Works fine on Toshiba SD2710 Works fine on Toshiba SD2800 |
Comments posted by Steve F. from Other, December 16, 2003:
Just purchased new burner. Made 2 of 3 burns correctly. Only burned in 4x mode.
Price: $1.2 Purchased from: Local Staples Store Date purchased: December 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0c. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Good. Media inkjet printable reliability is Good. Media color is Silver. Media text is Memorex 4.7 GB DVD-R 4x speed. Authoring/Burning comments: Ulead's DVD Picture Show2 Works fine on JVC XV-S65GD |
Comments posted by ub215 from Other, December 14, 2003:
Works well at 4x
Price: $1 Purchased from: Office Depot Date purchased: December 2003 Burnt with TDK 440N at 4x using firmware 1.08. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4.7G DVD-R 4.x R4.7. Authoring/Burning comments: Copy using DvdxCopy Xpress Works fine on Cyberhome CH-DVD 300 |
Comments posted by Brice Hope from Other, December 11, 2003:
No comments
Price: $1.2 Purchased from: Staples Date purchased: December 2003 Burnt with Plextor PX-708A at 4x using firmware 1.03. Burning reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R. Authoring/Burning comments: TMPGEnc DVD Author Works fine on Panasonic DVD-RV27 |
Comments posted by Jeff from Other, December 10, 2003:
Burns on my Liteon-411s but won't play on my Sony DAV-c450
Price: $1.2 Burnt with Lite-On LDW-411S/451S at 4x Burning reliability is Mixed. PC reliability is Mixed. DVD reliability is Poor. Media color is Silver. Media text is n/a. Authoring/Burning comments: TMGEnc Does not work on Sony DAV-C450 |
Comments posted by Zell from Other, December 08, 2003:
I've used Memorex CD-RW's - bought a spindle of 25 and they were all crap. Was nervous about the Memorex DVD-R's but they work fine. Im buying another 10 pack tomorrow.
Price: $1 Purchased from: Wal-Mart Date purchased: December 2003 Burnt with Lite-On LDW-401S at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Green Blue. Media text is Memorex. Authoring/Burning comments: DVDDecrypter Works fine on Sony Playstation 2 |
Comments posted by DAVE from Other, December 08, 2003:
4.7gb 4x dvd-r worked great w/liteon ldw-411s
Purchased from: Circuit City Date purchased: December 2003 Burnt with Lite-On LDW-411S/451S at 4x using firmware FSOF. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex. Authoring/Burning comments: DVD-Shrink
Nero 5.5.10 Works fine on Toshiba SD1600 |
Comments posted by Psmith from Other, December 07, 2003:
I've burned 30 discs so fat with no coasters or unreadable discs.
Price: $1.3 Purchased from: Best Buy Date purchased: December 2003 Burnt with TDK 440N at 4x using firmware 1.06. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media inkjet printable reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-r. Authoring/Burning comments: Rip with DVD Shrink
Mastered with Maestro
Burn with Nero
also
DVD Xcopy Works fine on Panasonic DVD-F85 Works fine on Sony Playstation 2 Works fine on Toshiba SD2150 Works fine on Toshiba SD2600 |
Comments posted by Stoob from Other, December 06, 2003:
Excellent burning results at 4x with TDK 440N.
Burnt with TDK 440N at 4x using firmware 1.09. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex 4xDVD DVD-R. Authoring/Burning comments: Nero 6 and DVD Decrypter
DVD Decrypter is my preferred burning software. Works fine on Samsung DVD-E235 |
Comments posted by QuaiBoy from Other, November 28, 2003:
Burned 10+ on my Pioneer A06 - no coasters. All play through on my Panasonic S35S
Purchased from: Wal-Mart Date purchased: November 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.06. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex It is live or is it Memorex? - 4x DVD R4.7. Authoring/Burning comments: DVDDecryptor 3.1.7.0, DVDFab 0.17.0 (if applicable), DVD2ONE 1.3.0 (if applicable), Nero 6.0.0.19 Works fine on Panasonic DVD-S35 |
Comments posted by Rick Klein from Other, November 25, 2003:
Have burned 3 DVDs (movies) with only 1 successful. Two had skips near the outside of the DVD and were burned at 4x. The successful burn was done at 2x. I am quite disappointed as I had great success with the Memorex DVD+R media.
Price: $0.9 Purchased from: www.amazon.com Date purchased: October 2003 Burnt with Memorex Dual-X at 4x Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media color is Silver. Media text is Memorex 4.7 GB DVD-R 4x DVD. Authoring/Burning comments: DVD Shrink, DVD X Copy Works fine on JVC XV-S500BK Does not work on JVC XV-S500BK |
Comments posted by lstewart from Other, November 24, 2003:
A large percentage of this manufacturer becomes coasters with my Sony DRU-510A. I've found other DVD-R brands very reliable, and I've even had great success with the Memorex DVD+R media, but that media is manufactured at Ricoh Japan. I've had little success with this brand burning at any speed, 1x, 2x, 2.4x, and 4x. Sony confirmed this Memorex DVD-R media made by CMC Mag. is not supported in their drives.
Price: $1.2 Purchased from: Office Depot Date purchased: October 2003 Burnt with Sony DRU-510A at 2x using firmware 1.0d. Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4.7GB DVD-R 4x. Authoring/Burning comments: Burned with DVD Decrypter. Works fine on Sony DVP-NS715P |
Comments posted by Herve from Other, November 24, 2003:
No comments
Purchased from: www.cdrvierge.com Date purchased: November 2003 Burnt with Lite-On LDW-411S/451S at 4x using firmware FSOF. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is MEMOREX isit live ou is it Memorex ?. Authoring/Burning comments: Pinnacle Instant CD/DVD 8 Works fine on Toshiba SD22VE |
Comments posted by Henri from Other, November 24, 2003:
Memorex
No.1
Brand for digital Media Worldwide
DVD
R
R4.7
DVD-R
www.memorexlive.com
General use
Data 4.7GB
Video 120 Min
DVD-R 4.7GB Professional Recordable DVD
Burnt with Sony DRX-510UL at 1x using firmware 1.0D. Burning reliability is Poor. Media color is Silver. Media text is DVD-R Professional Recordable DVD, Single sided Single layer. Authoring/Burning comments: Nero |
Comments posted by Homer Simpson from Other, November 16, 2003:
only able to burn at 2x, even the disc claim to be 4x compatible
Price: $2 Purchased from: www.futureshop.ca Date purchased: November 2003 Burnt with LG GSA-4040B at 2x using firmware A301. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD-R. Authoring/Burning comments: Backup using DVD Shrink 3.0 Beta 5, Nero Ultra 6.0.0.23 and DVD Decrypter 3.1.7.0 Works fine on Samsung DVD-P331 |
Comments posted by Goku from Other, November 13, 2003:
No comments
Price: $1.9 Purchased from: www.mediashoponline.it Date purchased: November 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.33. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Gray. Media text is Memorex. Works fine on Microsoft Xbox Works fine on Sony Playstation 2 |
Comments posted by Josh Killebrew from Other, November 13, 2003:
Works pretty well and costs as much as generic media. Have had no problems at all using this media for all types of data and mulitmedia.
Price: $1 Purchased from: Best Buy Date purchased: October 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0d. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex Is it live or is it Memorex? DVD-R 4X Recordable 4.7GB. Authoring/Burning comments: CopyToDVD, DVDShrink, Nero Recode, DVD Decoder Works fine on Sony DVP-NS315 |
Comments posted by Rusty from Other, November 12, 2003:
Well. I was wrong. The Memorex media work fine. Application of a label to the disc caused all the problems. I see these problems affect many people with various burners and media.
I received the Ritek GO4 4X DVD-R's today and they exhibit the same skipping problem as the movie nears the outside of the disc if and only if there is a label applied.
Without labels, the Memorex and the Ritek work fine in my DVD player.
So, my apologies to Memorex on this one. My apologies to CMC Magnetics also.
I do have some "mylar" plastic types of labels. Discs almost work well with these. The disc will freeze for a moment, but, the player can eventually recover.
I've heard clear labels are available, but, they don't render ink jet ink very well. Maybe someone will come up with a textured white plastic label that is extremely well-balanced?
Some standalone console DVD players might be able to play these discs (Ritek and Memorex) if they have paper labels applied. However, it seems that to achieve compatibility with all players around, I've got to avoid standard labels and full face labels for now. I don't want to give a disc to someone only to find that their player skips and freezes. I've got to leave the labels off.
Actually, I'm going to try hub (also called core)labels. Many have said these work okay.
I wonder if printing directly to the disc will also throw the disc off-balance? Epson has a couple of ink-jets that print directly to disc. But, I don't want to have to maintain a supply of another type of ink cartridge. Maybe Canon will release a disc print adaptable printer in the near future (in the U.S.) that will use my present supply of Canon cartridges?
Hate to have to print directly on the disc, however. This limits the types of disc that I can use to only the printable discs. That makes it more difficult to shop for a really good price.
Price: $3 Purchased from: Staples Date purchased: November 2003 Burnt with NEC ND-1300A at 4x using firmware 1.08. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4X DVD-R Recordable 4.7GB 120min. Authoring/Burning comments: DVD Decrypter
Nero 6 Works fine on Daewoo DVG-5000N |
Comments posted by Nick from Other, November 11, 2003:
After trying Mirror disks (which failed to start writting with Power Calibration Error)and Unbranded disks (which failed to play back) these Memorex DVD-R (and also their DVD+R disks) worked first time on Sony Playstation 2 and Sony DVD-ROM DDU1612.
Purchased from: 10 for £14 from www.Staples.co.uk Date purchased: November 2003 Burnt with Sony DW-U14A at 4x using firmware 1.0c. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex 4X DVD-R Recordable 4.7GB 120 minute video. Authoring/Burning comments: Burned with Nero 6.0 Works fine on Sony Playstation 2 |
Comments posted by Viharnik from Other, November 11, 2003:
No comments
Burnt with LG GSA-4040B at 2x using firmware A301. Burning reliability is Mixed. PC reliability is Mixed. DVD reliability is Mixed. Media color is Silver. Media text is Memorex 4xDVD-R. Authoring/Burning comments: Nero 6.0.0.23 Works fine on Pioneer DV-464 |
Comments posted by Rusty from Other, November 08, 2003:
Daewoo DVG-500N standalone player freezes at chapters near the end of this disc. Others have reported this problem with these CMC Magnetics discs that are branded as Memorex. Those other people used burners different from mine and those other people used players different from mine. Therefore, I'm not going to blame my burner or player. I'm going to target the disc itself as the main problem.
I'm returning these to the store. My opinion? I've had troubles with some recently purchased CDRW that are made by CMC and are branded Memorex. Burning them in my Lite-On LTR-48125W has given me severe troubles. The Lite-On has been reliable many other media types.
I have even used CMC Magnetics CDR and CDRW discs branded by other companies in that Lite-On drive and the burns were perfect with reliable play on old drives that weren't even made to read burned discs.
But, when the Memorex brand name is placed on a CMC Magnetics disc, it seems there is a high probability that the disc is defective. My Lite-On CD burner has demonstrated this and now my NEC ND-1300A has demonstrated this.
I'm going to return these Memorex 4.7GB 4X DVD-R discs and proceed on the following presumptions:
1. CMC Magnetics discs are sometimes good sometimes bad.
2. If a CMC Magnetics disc is branded with the Memorex name, there's a high probability that it will be defective.
3. I'm going to avoid all discs branded with the Memorex name until such time that I see better reviews from other users.
As we all know, various disc factories produce some good product and some bad product. I am thinking that CMC Magnetics has sold some "B" grade DVD-R discs to Memorex. Maybe that's where this problem arises. Or, maybe, CMC Magnetics just hasn't developed their techniques to reduce flaws to an acceptable level on DVD-R discs?
I'm waiting on my shipment of Ritek GO4 DVD-R discs from Meritline.com. I think I can expect better results from those Ritek discs based on what I read here in the DVDRHelp forums.
Summary: Avoid Memorex discs if there are others available.
Price: $3 Purchased from: Staples Date purchased: November 2003 Burnt with NEC ND-1300A at 4x using firmware 1.08. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Poor. Media color is Silver. Media text is Memorex 4X DVD-R Recordable 4.7GB 120minutes video. Authoring/Burning comments: DVD DeCrypter 3.1.7.0
Nero 6 Does not work on Daewoo DVG-5000N |
Comments posted by Matt from Other, October 30, 2003:
Over 50 perfect burns with Memorex DVD-R's. Absolutely no problems at all. Would definately recommend the DRU-510A. The 8MB buffer makes a huge difference. Make sure to download sony's DSS software to increase Read speed. Makes a huge difference.
Price: $1 Purchased from: Officemax.com Date purchased: October 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0D. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4x. Authoring/Burning comments: Nero, DVD decrypter Works fine on Samsung DVD-V2000 |
Comments posted by dolbydigital from Other, October 29, 2003:
I am almost done with a 25 pack and no coasters. This media burns fine at 4x on my OptoRite DD0201. Have not experienced any problems with video... excellent quality. I would definately buy another pack.
Price: $2 Purchased from: Comp USA Date purchased: October 2003 Burnt with OptoRite DD0201/DD0203 at 4x using firmware 2.17. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4x 120min. Video. Authoring/Burning comments: Nero 5.x Works fine on GoVideo DVR4100 Works fine on Magnavox MDV411 Works fine on Pioneer DV-343 Works fine on Sony Playstation 2 |
Comments posted by Scott D from Other, October 28, 2003:
Purchased 2 spindles of 25 each. I have probably had 50% coasters burning at 4x and 25% coasters burning at 2x on my Sony DRX-510UL with Nero 6.x. Data seems to work fine but DVD video will lock up at chapter stops or repeat scenes (Sony DVD player). Power DVD will recongnize as a dirty disc most of the time with the burns.
Price: $2 Purchased from: BB Date purchased: October 2003 Burnt with Sony DRX-510UL at 4x using firmware c. Burning reliability is Mixed. PC reliability is Mixed. DVD reliability is Mixed. Console reliability is Poor. Media color is Silver. Media text is 4x. Authoring/Burning comments: Nero 6.x Works fine on Saba DSA 100E Does not work on Saba DSA 100E |
Comments posted by Sonny Eriksson from Other, October 25, 2003:
With firmware 1.06 i can only burn them in 2x. After i upgraded to 1.07 no problems.
Date purchased: October 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.07. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media inkjet printable reliability is Good. Media color is White. Media text is BLANK. Works fine on Sony SLV-D900 |
Comments posted by Pooch from Other, October 25, 2003:
Purchased a spindle of 25 at BB, created 2 coasters so far. 1 Trying @ 4x, the second @ 2x. This media is crap. I am going to try to get a refund from BB...
Purchased from: bestbuy Date purchased: October 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.31. Burning reliability is Mixed. PC reliability is Poor. DVD reliability is Poor. Media color is Silver. Media text is 4X DVD-R 4.7GB 120Min. Authoring/Burning comments: Nero 6 Ultra |
Comments posted by compbuilders2002 from Other, October 16, 2003:
I've used an array of media from 1x to 2x and 4x, I've bought generic media from Ebay sellers, and WalMart. This is the media I have chose to stick with. I've burned around 300 disks at 4x with maybe 10 bad burns, usually the bad burns were software oriented. I use Nero v6, and DVD2One to transcode. Many times the bad burns people get are related to hardware issue's or software problems, Never buy a cheap burner! It will cost you in the long run, buy name brand! This is the best media I have found yet.
Price: $2 Purchased from: Staples Burnt with Pioneer DVR-105 / DVR-A05 at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Mixed. Media inkjet printable reliability is Poor. Media color is Silver. Media text is 4X DVD 4.7 GB 120min DVD-R. Authoring/Burning comments: DVD Decrypter, DVD2One, Nero V6 Works fine on Apex AD-500w Works fine on Pioneer DV-260 Works fine on RCA RC5215P |
Comments posted by Syrinxx from Other, October 06, 2003:
Burns great at 4x, plays in Playstation, Xbox and set top DVD players.
Price: $2 Purchased from: Best Buy Date purchased: July 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.3. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex 4xDVD-R Recordable www.memorex.com. Authoring/Burning comments: Nero 5.5 / DVDShrink Works fine on Panasonic DVD-S35 |
Comments posted by abarth from Other, October 03, 2003:
Can only burns at 2X with the Optorite DD0201. It played on my 6X DVD-Rom, 4 yrs old RCA DVD player, and Sony DVD player.
Price: $1.6 Purchased from: Staples Date purchased: October 2003 Burnt with OptoRite DD0201/DD0203 at 2x using firmware 2.17. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is 4x DVD-R Recordable. Authoring/Burning comments: Nero6, DVDShrink, Clone DVD, and DVDXCopy Express. |
Comments posted by Chad Mohler from Other, September 22, 2003:
Media burns at 4x. Successfulness of burn depends on software used. Using Roxio 6.1.1.7 I was only able to be successful if I burned an image created by IMG Tool.
Price: $2 Purchased from: Staples Date purchased: September 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0c. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD DVD-R. Authoring/Burning comments: IMG Tool, Roxio 6.1.1.7 Works fine on Hitachi DVP305U |
Comments posted by DarkFoss from Other, September 22, 2003:
I have burned 6 out of the 10 pack so far at 4x speed, advertized as 2X media. No coasters.
Price: $2 Purchased from: CompUSA Burnt with Memorex Dual-X at 4x using firmware 1.05. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4.7gb 120 min video. Authoring/Burning comments: Shrink 3 beta, Nero 5.5.10.50 Works fine on JVC XV-M567GD |
Comments posted by IntelliQ from Other, September 21, 2003:
Works with my flashed (1.07 NEC ND-1300A) burner. Silver top/purple bottom. Raised surface text, no good for labeling.
Plays in APEX AD1200 and the APEX 3-carousel set top.
Burnt with NEC ND-1300A at 2x using firmware 1.07. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media inkjet printable reliability is Poor. Media color is Silver. Media text is Memorex DVD-R 4.7. Authoring/Burning comments: DVD X Copy Xpress 3.02 Works fine on Apex AD-1200 Works fine on Apex AD-5131 |
Comments posted by Shaun from Other, September 15, 2003:
This media writes fine but the last 5-10 minutes on all discs playback with major artifacts on my Panasonic CV52 (which does support DVD-R & plays Maxells fine). I am backing up using CloneDVD.
Price: $3 Purchased from: Futureshop Date purchased: September 2003 Burnt with LG GSA-4040B at 2x using firmware A104. Burning reliability is Mixed. PC reliability is Poor. DVD reliability is Poor. Media color is Silver. Media text is Memorex DVD-R Recordable 4.7GB 120 Minute Video. Authoring/Burning comments: CloneDVD Does not work on Panasonic DVD-CV52 |
Comments posted by Patchdb7 from Other, September 15, 2003:
Bought pack of 25. Using Pinnacle Studio 8.8 have toasted 4 coasters so far (tried all speeds). Switched media and burnt with no troubles. Will not choose Memorex again.
Burnt with NEC ND-1300A at 2x Burning reliability is Poor. Media color is Silver. Media text is Memorex DVD-R 4x Recordable. Authoring/Burning comments: Pinnacle Studio 8.8 |
Comments posted by cetacea from Other, September 14, 2003:
Worked fine for archiving. Movies copied using DVD Shrink 3.0 played fine on a computer, but wouldn't play on a Yamaha S520 DVD player.
Burnt with Sony DRU-510A at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Purple. Media text is Memorex 4.7GB DVD+R 4X. Authoring/Burning comments: Authored with DVD Shrink 3.0 beta and burned with Easy Creator 6.0 Basic. Does not work on Yamaha DVD S520 |
Comments posted by sven from Other, September 14, 2003:
Couldn´t burn this media with Toshina SD-R5112 at 4x. i can only burn with 1x speed.
The media works fine on a xbox.
Price: $2 Date purchased: August 2003 Burnt with Toshiba SD-R5112 at 1x using firmware 1031. Burning reliability is Good. Media color is Purple. Media text is Memorex 4.7GB 4x. |
Comments posted by rcottle1 from Other, September 11, 2003:
Looks (On top) almost like some Memorex CD-R media that I have. Burned fine at 4x but I notice very slight jitter in video, but not enough to really bother me. Surface quality was excellent.
Price: $1.3 Purchased from: Office Depot (On Sale) Date purchased: September 2003 Burnt with OptoRite DD0201/DD0203 at 4x using firmware 2.16. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is DVD-R recordable 4.7GB 4x DVD 120 minute video Is it live or is it Memorex. Authoring/Burning comments: DVD LAB, DVD Shrink, Nero6, TMPGenc Works fine on Apex AD-1500 Works fine on Apex AD-800 Works fine on Panasonic DVD-RV31 |
Comments posted by Jesse Safir from Other, September 03, 2003:
This media is advertised to burn at 4X. I found it to be less reliable than the Verbatim media I have used. It WILL burn at 4X, but it won't consistently work. Some disks fail during the write process and others simply freeze up while playing although they appeared to record fine. It does, however, seem to burn reliably at 2X on my Optorite DD0203 with fw 2.16.
Price: $2 Purchased from: Staples Date purchased: August 2003 Burnt with OptoRite DD0201/DD0203 at 4x using firmware 2.16. Burning reliability is Mixed. PC reliability is Mixed. DVD reliability is Mixed. Media color is Silver. Media text is Memorex 4X DVD-D Recordable 4.7GB 120 Minute Video. Authoring/Burning comments: Nero 6, DVDXCopy XPress 3.0.1, NTI CD Maker 6, B's Recorder Gold 5 Works fine on Cyberhome CH-DVD 500 |
Comments posted by psmyylie from Other, September 02, 2003:
Media burns fine, plays back fine everywhere I've tested them. No coasters yet. Strange thing is, it takes as long to burn a full-length disc at 4x on these Memorex discs as it does to burn a full-length disc on some TDK 2x DVD-Rs that I have. Thats why I paid extra for these, for the 4x writing capability....lame. I've successfully burned at 4x before on other media so I don't think it's me.
Price: $1.9 Purchased from: CompUSA Date purchased: September 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0c. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x DVD DVD-R Recordable 4.7GB 120 Minute. Authoring/Burning comments: Authored with TMPGEnc DVD author, burned with Nero 6 Works fine on Panasonic DVD-RV30 Works fine on Philips DVD724 |
Comments posted by Professor X from Other, August 18, 2003:
This is by far the worst media I've ever used. I bought a spindle of 25 at Best Buy and over one third of the discs had errors when burning. The ones that did burn played without any problems on my Apex 3201 DVD player but having burn errors on over a third of the discs is inexcusable. I will not be buying this garbage again.
Price: $2 Purchased from: Best Buy Burnt with Sony DRU-500A at 4x using firmware 1.0f. Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex DVD-R Recordable 4.7GB 120 Minute Video 4X DVD. Authoring/Burning comments: RecordNow Max 4.5 Works fine on Apex AD-3201 |
Comments posted by Chato from Other, August 17, 2003:
I've backed up over 10 dvd's and the media has worked perfectly. It was my first media with this dvd burner and it works! I'll try other, cheaper stuff, but for now, this works.
Price: $2 Purchased from: staples Date purchased: July 2003 Burnt with Cendyne CDICD00209 at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex DVD-R Recordable 4.7GB 120 Minute Video 4X DVD. Authoring/Burning comments: I've used DVD Decryptor and DVDXCopy, both with great success. Works fine on Philips DVDQ35 |
Comments posted by Chastity from Other, August 01, 2003:
1st brand I've tried that burns at 4x
Price: $2 Purchased from: Best Buy Date purchased: August 2003 Burnt with Sony DRU-500AX at 4x using firmware 2.0f. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4X DVD-R Recordable 4.7G 120 Minute Video. Authoring/Burning comments: Nero 6.0.0.9
DVD-Lab 1.15 Works fine on Sony DVP-NS715P Works fine on Sony DVP-S500D |
Comments posted by Jim from Other, July 28, 2003:
Only successful on 25% of my attempts. All other attempts created coasters. A 2mm write to the center of the disc was all that was written to the media. No problems with either Meritline 1X or Ritek 4X media using the same software and hardware.
Purchased from: Best Buy Burnt with Sony DRU-500A at 4x using firmware 2.0f. Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4X DVD-R Recordable 4.7GB/120 Minute Video. Authoring/Burning comments: DVD X Copy and DVD X Copy Express/Burned with both built-in burning software and Nero Works fine on JVC XV-FA900BK |
Comments posted by Bradley Patton from Other, July 23, 2003:
I'm very happy with this media, and the price is almost as good as the cheap 4x ritek and princo media I had been using. And when you figure in the amount of coasters I got with ritek and princo media the memorex ones are actually cheaper. Out of 75 of these discs burned, I haven't had one Memorex coaster to date.
Price: $2 Purchased from: cdw.com Date purchased: July 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.33. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex DVD-R 4.7GB 4x. Authoring/Burning comments: Apple iDVD 3.0.1 and Adaptec Toast Titanium 5.2.1 Works fine on Sony DVP-NS400D Works fine on Sony Playstation 2 |
Comments posted by groovespacer from Other, July 10, 2003:
No comments
Price: $3 Purchased from: Office Depot Date purchased: July 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 2x using firmware none. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex. Authoring/Burning comments: DVD Shrink
DVDXCopy Works fine on Toshiba SD3108 |
Comments posted by fiveamp from Other, July 10, 2003:
Media works fine
Purchased from: www.blankdiscshop.co.uk Burnt with NEC ND-1300A at 4x using firmware 1.05. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Memorex 4x dvd-r recordable 4.7 gb 120 minute video. Authoring/Burning comments: Authored with DVDShrink
Burnt with Instant CD/DVD 6 Works fine on Pioneer DV-350 |
Comments posted by hehehhehe from Other, July 09, 2003:
Do not nuy this junk. Demanding exchange tomorrow.
Price: $2 Purchased from: Best Buy Date purchased: June 2003 Burnt with Sony DRU-500A at 4x using firmware 1.0f. Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media color is Silver. Media text is MEMOREX 4X DVD-R. Authoring/Burning comments: Ulead DVD workshop does not want to burn to it, and Nero 5.5.10 burns to it at 4x but it is unreadable. Does not work on Apex AD-1200 |
Comments posted by usualpulp from Other, June 23, 2003:
Media burns fine at 4x, however when played on a dvd player or dvd rom, the copy appears very jittery at times, typical of my experience with cmc media.
Price: $2 Purchased from: Best Buy Date purchased: June 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 4x Burning reliability is Good. PC reliability is Poor. DVD reliability is Mixed. Media color is Silver. Media text is Memorex 4X DVD-R recordable 4.7GB 120Minute Video. Works fine on Sony DVP-S560D |
162 user comments,
Showing
1 to
162 comments |
