The Original
Official Guide by Sefy Levy |
More
Guides: |
AVI to VCD / DVD2SVCD / ImTOO DVD Ripper / EasyDivX / Complete Guide / TMPGEnc
/ DVDx
Introduction!
This Guide will show you how to use VirtualDub as a tool to both add
Subtitles to encoders which do not support it, as well as frameserving
to encoders which don't support VOB or D2V files. ( * Examples: LSX Encoder / XingMPEG /
Panasonic v2.51 * )
NOTE-1: LSX is not a Free Encoder, you CAN replace that step with ANY
other encoder you want!
NOTE-2: This Guide is mainly a combination of segments taken from the
Complete DVD Backup Guide v2.6! |
Programs
used in this guide:
Copying - CladDVD XP
FrameServing - VirtualDub
Encoding - LSX Encoder and splitting
using: TMPGEnc / Plus
Chapters
- Chapter-X-Tractor
Authoring - VCDEasy ( & ASPI Layer for
your system! - use the search for "WinASPI" or scrool to the bottom
of the page!)
Before we start with the guide, we must make sure the tools we
are
going to use actually work and setup correctly! Unzip the tools
you are going to be working with into the SAME folder, and
once you do, make sure all applications work, and then we are
ready to begin! For this example i've used "Superman - The Movie
Special Edition" (NTSC/154min/DD51@384k) and we will be converting it
to a Video-CD NTSC Standard so it will fit on two 80min CDR
media. (or 74min with 2min Overburning, which is only if your CDRW
drive and media supports it!), do remember that 740mb filesize
will fit into 74min CDR and 800mb Filesize will fit into a 80min CDR
(in VCD 1min = 10mb!).
NOTE:
This current guide support Subtitles using the VobSub filter for
VirtualDub, there are many other ways as well, but this is what will be
used here, if you want to use other type of subtitles in your movie I
suggest you use one of the other great guides on VideoHelp!
This guide
will be divided into the following sections:
Part 1 - Copying
Part 2 - FrameServing
Part 3 - Encoding
Part 4 - Splitting
Part 5 - Chapters
Part 6 - Authoring
Part 7 - Burning
Part 8 - Troubleshooting |
Using - CladDVD XP |
This is
an update to the CladDVD program and it is capable of not only copying
the movie, but also generating frameserving files.
(* NOTE: This section of the guide was done with the great help from
kwag who has taken the time to do the images for me and explained each
step of them *)
Step
1 - Place your DVD movie in your drive ( DVD drive, NOT
a CD drive!) and select a Source Drive and also a Target
Location where the files will be copied to.
Step
2 - Press the "Options" button, select the pulldown from
the "Audio Streams (Re-Map)" to select an Audio Track.
Step
3 - CladDVD XP also supports creating a D2V compatible FrameServing
file, to do so, Press on the "FrameServe" button, and here you
can set to use the quality of your movie under the "Video Settings"
and also if you want to use the "Force Film" to create a NTSC
Film 23.976 format for FrameServing.
Step 4 - After you pressed the "OK" button, press "
Save Settings" and you'll be back at the main screen, and you can
press the "Start" to begin the copying progress.
Step 5 - If you have selected to use the build-in "
FrameServe" option, then when copying is done, it will automaticly
invoke the internal DVD2AVI generator, which will open the "Statistics
Window ", don't close it, when it's done, you are finished both
copying and frameserving your movie.
VirtualDub - FrameServing
This program is basicly both an editor and a frameserver and has many
filters, which one of them i'll cover here, and that is the SubTitles.
It makes it possible for an encoder (old or new) to encode the movie
from the VOB files with the addition of selected filters, that it would
not be capable of doing otherwise. |
Pre-Steps - Before you start with "VirtualDub", run the "AuxSetup"
and select "Install handler" and press "OK " to confirm,
when you are back at the "Auxiliary Setup" press the "Run
VirtualDub" button, and this will run the main program.
Pre-Step A
Pre-Step B
Step 1 (a/b/c)- Click on "File" then "Open video file" and select your source (Such as the Fake AVI you created using VFAPI Converter) file. The Audio is an OPTIONAL step which only
depends on the Encoder you are using, if it only has a single input or it crashes on large
WAV files, only then you use this option! If not, skip to Step 2. Click on the "Audio" menu and Instead of the default "AVI audio" select "WAV Audio", this will cause a "Open WAV File" window to popup, here you select the Audio Track created earlier using DVD2AVI, Click on "Open", then under the "Audio" select the "Full processing mode" option.
a) b)
c)
Step 1d - To add "Filters" such as Subtitles, Click on "Video" and select "Filters" if you want to add the VobSub filter.
Step 1e) - In the Filters menu, click on the "Add..." button.
Step 1f) - In the "Add Filter" selection, if your VobSub is not there, click on the "Load..." button.
Step 1g) - Use the "Load external filter" to locate and open the "textsub.vdf" file.
Step 1h) - After you have loaded the TextSub filter, Click on it, and press the "OK" button
NOTE: Click Here to Configure the TextSub Filter for Subtitles in your Movie!
Step 2(a/b) - Click on the "File" menu and then click on "Start frame server..." and when you get the "Frameserver setup" click on "Start"
a)
b)  |
Step 2(c/d) - After you clicked on the "Start" button, you will be asked to save the new frameserved file, make sure you add .VDR at the end of the file, as it is NOT being added automaticly. This will make VirtualDub ready to serve, when you are done with encoding, press on the "Stop serving" button.
Using - LSX Encoder |
This Encoder is extremly fast,
however it's quality is not one of the best, it is also no longer
available as a download or even for buying. It has many nice options
but I would more recommand an updated encoder such as TMPGEnc or
MainConcept. |
Step 1 - Since LSX MPEG Encoder v3.5 only supports one input,
i'm using DVD2AVI/VFAPI and VirtualDub
for framserving, i've enabled the Video and i've also enabled the "WAV
Audio" and selected the WAV file that was generated by DVD2AVI earlier so both the Video and Audio
will be frameserved into LSX, and i've created a "fake" AVI file
instead of VDR as used in Step 4c on VirtualDub.
NOTE: Do NOT use the Install Handler as shown on the Pre-Steps on
the VirtualDub section!
Step 2 - When opening the "fake" AVI generated by VirtualDub, LSX will give you the following
information.
Step 3 - An "Output File" will automaticly be selected,
you can of course change the default name, in the "Stream Format"
you can select the type of encoding you want, supported are "Video-CD
", "Super Video-CD" and "DVD", for this example i've used
the regular "Video-CD" Standard.
Step 4 - Pressing on the "Advanced" button will give
you much more control over how to encode the movie, all menu items are
very self-explanatory, so here are just two menus out of them as
examples.
Step 5 - When you are done with the "Advanced" menus,
press the "OK" button, which will bring you back to the main
program, select the "Action" and then the "START Encoding"
or press "Alt-R" to start the encoding process.
Step 6 - This is how the encoding window will look like, as
you can see, Subtitles exist thanks to VirtualDub
(Steps 2a to 2h).
TMPGEnc - MPEG Tools (v2.5x +) |
In the Latest versions of TMPGEnc there has been a new feature
added to ease up the usage for Newbie's, it's a Wizard mode, which
helps you through each step you take in an easier to use way,
here I will guide you through the Wizard Steps. |
Step 1a
- Open TMPGEnc and press "File" and select "MPEG Tools ".
Step 1b - Now go to the "Merge & Cut" section, and
select the type of file you want to create using "Type" category.
Step 2a - Press the "Add" button and choose the file you
want to cut, once you selected, Double click the file.
Step 2b - Use the "Slide Bar" to move to the points in
your movie that you want to be the start and ending, and use the "{
" to mark the starting point, and use the "}" to mark the end
point and then press the "OK" button.
Step 3 - After you have selected the Start and End frame for the
first part you want to cut, select the "Output" filename and
press "Run" to start the cutting process.
Step 4 - When you are done with the first Part, repeat Step 2a
to Step 2b and a diffrent filename for the "Output" so you
won't overwrite the previous file, and then press the "Run"
button to start the cutting process for the second part of the movie.
Using - Chapter-X-Tractor |
This program is capable of accessing the DVD Movie's IFO file and
extracting the Chapters Information so it will be used in to create a
VCD/SVCD with the same Chapter Points, so when you use the Remote
Control you can jump from chapter to chapter. |
Step 1a - Load Chapter-X-Tractor (1a) and press the "
Open IFO" button.
Step 1b
- Select the Movie IFO file which you ripped earlier.
Step 2a
- You will now see all the information needed in the " RAW Data"
field.
Step 2b
- Now Press the "Save data" button, and select a filename
for the Chapter Information.
Using - VCDEasy |
A New program that is capable of
doing chapters in a rather easy and
simple way, and uses all the free tools out there for giving you the
best of the best, it's chaptering capabilities are far simple but
effective in the last few builds it has added support for the free
CDRDao burning tool, and gives you an easy interface for burning
the images it created.
Step
1a
- Open VCDEasy, and set everything according to your specific movie,
and
follow the example below.
NOTE:
Please do not create blank spaces in the Cue/Bin name, as CDRDao may
have a problem burning it later on.*)
Step 1b - Press the "Add Files" button and
select the
first of the two files you encoded earlier.
Step 1c - Change the "Volume Label" to reflect
the name
of the Movie, and also select the "Bin Output File"
location.
Step 2 - On the "Options" tab you can write down
the
name of the "Album" and also enable the "Use Playback Control
(PBC)".
Step 3a - Press the "Chapters" menu item and
Here you
can select to import the Chapters for your movie, Right Click
to
get the popup menu so you can import from Smart Ripper or
Chapter-X-Tractor.
Step 3b - Select the "Start offset" and "End
offset
" for the first part of the movie and press the "Ok" button.
Step 4 - Press the "Go" button, VCDEasy will
begin
analysing your MPG file and create an Image file for burning.
Step 5a - Go back to "Main"
by pressing the "(S)VCD "
button, remove the MPG file, and open the second part of the movie.
Step 5b - Change the name of the "Bin Output File",
so
you don't accidently overwrite the previous file (if you didn't
burn it yet).
Step 5c - As in Step 3a and 3b, select
the
Chapters for the second part of the movie, make sure to start a
Chapter after the one you last selected on the previous part (3b),
and when you are done press the "Ok" button.
Step 6 - Press the "Go" button again to create
the
second image file of the movie.
Using - VCDEasy / CDRDao |
VCDEasy comes with CDRDao which
enables it to burn Bin/Cue images, this way, you do not require any
additional software to burn your images.
Step 1 - To burn the
newely created images, first make
sure that the CDRDo is set up correctly, go to the "Settings "
and select the "CDRDAO" menu item, make sure you select your "
CD Writer" and set the speed, and also enable the "Allow Overburn
" if you plan on using over 80min CDR media.
Step 2 - Next, go to the "Tools" section and
select "CDRDao
Tools" from the above menu, here you can "Blank a CDRW " and
also select to "Burn a CUE or TOC CD Image" file, you can also
select to "Simulate" and not actually burn. Press
the " CUE/TOC file" button, and then select the Image you want
to burn.
Step 3a - After you selected the first image of the
movie (in
this case Superman - VCD1.cue) then press the "Burn"
button and the writing of the CD will start.
Step 3b - When you are done burning the first part
select the
second image of the movie (in this case Superman - VCD2.cue)
and again press the "Burn" button and the writing of the CD
will start.
THE END |
Troubleshooting |
Here I will try to cover all the
problems you may encounter, and
hopefully help you fix them. |
- In Order for TMPGEnc to recognise D2V files, you MUST have the VFAPI and the DVD2AVI.VFP
file located where the TMPGEnc.EXE file is! it will NOT work any
other way! It is also sometimes helps to use the Forced Film option in
DVD2AVI, but only if you are still unable to open the D2V files with
TMPGEnc. (suggsted by msfox)
- In some DVD movies the Audio Track is located on the second track,
so you might want to try in DVD2AVI to rip the secondary Audio Track,
if you are not sure which Audio Track to choose, open the
Chapter-X-Tractor text file and you can check in there.
- Also in some movies the Audio Track is a DTS and DVD2AVI is
incapable of handling it and converting it to WAV, I would recommand
you find a diffrent track, there is usually both DTS and AC3
tracks, use the information files by either Smart Ripper or
Chapter-X-Tractor to find out if your movie has an AC3 track and if
does, then on which track it is, and if there isn't find the next
best alternative which would be the 2ch track.
- Make sure when you encode the movie that the currect Template will
be used for your movie, an incorrect Template will cause A/V sync!
and not to mention the resolution will be distorted (if you use PAL on
NTSC and NTSC on PAL).
- If you are having problems copying the Movie VOB files to your
HDD, I suggest you check your ASPI Layer, the ASPI that comes with
Windows9x, Millenium are not good for ripping, update them, and
Windows2000/XP does not come with an ASPI Layer at all! make sure
you download the latest ASPI for your system, you can get the v4.6 for 98/Me/2000XP
here! (scrool to the
bottom of the page!)
- If Smart Ripper or any other of the DVD Copying programs
are unable to access your DVD Movie, try to first play the disc using
any Software DVD Player, and then try to run the ripper.
Because the Copying program always selects as default the longest
running title of the DVD, it might select the wrong title, So make
sure the VOB's that were copied are indeed the VOB that belong to
the movie itself and not the Extra features (e.g. Pearl Harbor).
Copyright 2000-2004 by Sefy Levy, All
Rights Reserved.
Best Regards,
Sefy Levy,
Certified Computer Technician. |
