Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Philips DVD+RW 4.7GB PHILIPS.041 4x Plays on 24 DVD Players
Plays not on 9 DVD Players
Burn Reliability is Good
DVD Reliability is Mixed
PC Reliability is Good
Console Reliability is Mixed
Read 31 comments
(283085 views)
Post comment
08 02 00 00 92 0F 04 00 00 03 00 00 00 26 05 3F .............&.?
00 00 00 00 00 00 01 50 48 49 4C 49 50 53 00 30 .......PHILIPS.0
34 31 00 39 23 00 9F 7C 5C 02 28 00 9A 7E 70 02 41.9#..|.(..~p.
28 00 A0 7B 68 02 28 04 04 20 E0 00 F0 00 00 00 (..{h.(.. ......
Media color and text:
Silver DVD+RW PHILIPS 1-4x
UPC/EAN Code:
No
31 user comments
Showing 1 to 31 comments
Comments posted by rdkapp from United States, October 07, 2007:
The Media works fine. Out of about 25 burns, I've experienced 3 errors, but since it's an RW, I just erase the disc and start over. It's always burned fine on the 2nd try.
Additional information:
Date purchased: December -0001
Burnt with Samsung SH-S182D / TS-H652D at 4x using firmware 06.
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Mixed.
Media color is Silver Green.
Media text is Philips DVD+RW 1-4x 4.7GB 120 min. DVD+ReWritable.
Media package type is Jewel Case. Number of discs 5.
Media made in Taiwan.
Media UPC/EAN code is 03784993481.
Authoring/Burning comments:
Burning Software used - ImgBurn
Burner has bitsetting for DVD+RW, which may be beneficial.
Works fine on Magnavox MDV456
Does not work on Samsung DVD-HD755
Comments posted by nicoC from France, September 18, 2006:
No comments
Burnt with MSI DR12-A at 2.4x
DVD reliability is Good.
Media color is Gray.
Media text is DVD+RW 120 min Video extended play 240min 4.7GB Data Philips 1-4x Single Sided.
Media package type is Jewel Case. Number of discs 1.
Works fine on Cyberhome CH-DVD 4010
Comments posted by Coetmeur from France, December 30, 2005:
Problems of playback in the second half of the disc on DVD player
Purchased from: Boulanger
Burnt with MSI DR12-A at 2.4x using firmware 120D.
Works fine on Bluesky DS-8315
Does not work on Bluesky AD-1000
Comments posted by Coetmeur from France, July 01, 2005:
No comments
Burnt with MSI DR12-A at 2x using firmware 120D.
Comments posted by Grove_Street from United States, June 12, 2005:
No coasters with this media so far.
Price: $10 Purchased from: Radio Shack Date purchased: June 2005
Burnt with CyberHome CH-DVR 1600 at 1x using firmware see comment.
Console reliability is Good.
Media color is Silver Black.
Media text is DVD+RW 120 MIN VIDEO EXTENDED PLAY 240MIN.
Media UPC/EAN code is 03784994273.
Firmware Version info of the DVD recorder is as follows: Main: CH_18.3.01.05.56
Loader: 090NDX
Works fine on Microsoft Xbox
Works fine on Sony Playstation 2
Comments posted by schranzmann from Germany, May 19, 2005:
No comments
Burnt with LG GSA-4163B at 4x using firmware 1.4.
Media color is Silver.
Media text is Philips DVD+RW.
Media package type is DVD Box. Number of discs 1.
Works fine on LG DV-8700H
Comments posted by Redking from United States, March 29, 2005:
Works perfectly, no problems.
Price: $4 Purchased from: Big Lots Date purchased: February 2005
Burnt with Philips DVDR615 at 1x using firmware 9.40.
Media package type is Jewel Case. Number of discs 3.
Works fine on Panasonic DVD-RA60
Comments posted by Pete Lloyd from United Kingdom, January 25, 2005:
Media burns but will not play in Logix 3000 DVD player. Plays OK on Pc but thats not what I really want.
Purchased from: Currys UK (Special offer)
Burnt with NEC ND-3450A at 4x
DVD reliability is Poor.
Media text is Philips 4X DVD+RW 4.7GB.
Media package type is DVD Box. Number of discs 10.
Sonic My DVD
Does not work on Logix DVD-3000
Comments posted by Samtron from Finland, January 23, 2005:
No comments
Burnt with Philips DVDR615 at 4x using firmware 1.25.
Media text is DVD+RW.
Media made in Netherlands.
Media UPC/EAN code is 8710895772662.
Works fine on Philips DVD633
Works fine on Philips DVD634
Works fine on Philips DVDR610
Works fine on Philips DVDR615
Works fine on Philips DVDR616
Works fine on Philips DVP520
Media image
Mediaimage
Click to enlarge
Comments posted by Sebastiaan from Netherlands, November 23, 2004:
It is a 1-4 speed dvd disc but you can burn it also on 6x speed with no problems.
Price: $2 Purchased from: In a shop Date purchased: November 2004
Burnt with NEC ND-3500A at 6x using firmware 2.16.
Media inkjet printable reliability is Good.
Media text is Philips 4.7 GB Data 1-4x speed DVD+RW Single Sided.
Media package type is Cake Box. Number of discs 10.
Nero 6.6.0.0 and alcohol 120% Version 1.9.2 build 1705
Works fine on Vestel DVD-2706
Comments posted by nogood from France, November 17, 2004:
it was burned and cleared on my dvd recorder nec nd3500a at 4x. I used too this media with my home dvd recorder philips hdrw 720.
Price: $10 Purchased from: nierle.de Date purchased: November 2004
Burnt with NEC ND-3500A at 4x using firmware 2.17.
Media text is Philips DVD+RW 120 min extented 240 mn video 4.7 GB data 1-4x.
nero, roxio easy media shrink.
Works fine on Philips HDRW720
Media image
Mediaimage
Click to enlarge
Comments posted by Gerhard from Germany, November 13, 2004:
No comments
Burnt with Teac DV-W58E at 4x using firmware D.0J.
Media text is Philips DVD+RW 120 min video 4.7 GB data 1-4x.
Media package type is Slim Case. Number of discs 5.
CloneDVD2
Comments posted by Edward Ryan from United States, October 06, 2004:
Burned with no problems at 4x using Linux k3b, but wouldn't play on my XBOX, home DVD player, friend's PS2, and friend's DVD player. Which personally, I feel, completely defeats the purpose of it.
Price: $5 Purchased from: Local RadioShack Store Date purchased: October 2004
Burnt with Lite-On LDW-811S/851S at 4x
Console reliability is Poor.
Media text is DVD+RW 120 Min Video (Extended Play 240 min) 4.7GB Data Philips 1-4X DVD+ReWritable Single Sided.
Media UPC/EAN code is 037849942734.
Authored with DVD Architect 2.0, burned with k3b.
Does not work on Microsoft Xbox
Does not work on Sony Playstation 2
Comments posted by Wingdings from Sweden, September 28, 2004:
No comments
Burnt with NEC ND-2510A at 4x using firmware 1.77 Herrie's.
Burning reliability is Mixed.
Media text is Philips DVD+RW 1-4x.
Nero 6.3.0.0
Does not work on Panasonic SA-HT80
Comments posted by Konstantin Yushin from Russian Federation, July 27, 2004:
Excellent media! Burns perfectly and reliably. Actually, it burns better then most of the other DVD-media (including +R/-R). Take a look here: http://ykk2.narod.ru/DVD-Media/Philips.DVDRW.4x.PNG
Price: $1.5 Purchased from: Small russian local store Date purchased: July 2004
Burnt with Lite-On SOHW-812S at 4x using firmware US0N.
Media text is Philips 1-4x DVD+RW 120 min video 4.7GB data.
Media UPC/EAN code is 8710895795609.
Nero 6.3.1.13
Works fine on BBK DVD-DV965
Media image
Mediaimage
Click to enlarge
Comments posted by Konstantin Yushin from Sweden, July 26, 2004:
Perfect DVD+RW Media. Burns fine in several DVD-burners. Very low PI/PO error levels.
Price: $3 Purchased from: www.ultracomp.ru Date purchased: May 2004
Burnt with NEC ND-2500A at 4x using firmware 1.7 Herrie v2b5.
Nero 6.3.1.13
Media image
Mediaimage
Click to enlarge
Comments posted by Mark from Netherlands, June 02, 2004:
My experience: total crap. Like DeathAngel (see comment below), the label said to check the firmware upgrade (not necessary in case of the NEC2500A). I checked and doublechecked everything, but so far 7 of 7 discs gave power calibration errors. It looks like the formatting is ok, but then after 15-25 seconds, the error message pops up. I've burned Sony DVD+R without a problem on the drive, so apparently the drive is ok. I'll never buy these again ...
Price: $2 Purchased from: V&D (large dutch retail store) Date purchased: May 2004
Burnt with NEC ND-2500A at 2.4x using firmware 1.06/1.07.
Burning reliability is Poor.
Media text is DVD+RW 120min video, 4.7Gb data, Philips 1-4x, DVD+ReWritable.
Nero 6.3.1.10
Comments posted by DeathAngel from Netherlands, May 08, 2004:
The label on the discs warns the user with the following text: "Before burning this disc in a 2.4x DVD+RW data drive, you need to check how to get the required firmware upgrade. Full Details can be found in enclosed booklet". see www.dvdrservices.com.
The NEC ND-1100 is a 2.4x speed burner (DVD+RW) therefore it's wise to check your disc after burning with NERO's CDSPEED or DVDinfoPro for abnormalities.
In almost all cases the burning process goes OKE.
The reliabilty for this media drops due to the lack of Firmware upgrades by NEC.
Price: $3
Burnt with NEC ND-1100A at 2.4x using firmware 1.A0.
PC reliability is Mixed.
Media text is Philips 1-4x 4.7GB DVD+RW 120 VIDEO Single Sided.
NERO 6.3.1.6
Works fine on Pioneer DV-444
Comments posted by ollibauso from Sweden, February 21, 2004:
No comments
Purchased from: ebay germany ; 18€ , 10 discs cake Date purchased: February 2004
Burnt with NEC ND-2500A at 4x using firmware 1.06.
Media text is Philips 1-4X DVD+RW 120 min Video 4.7GB Data.
Nero 6.3.0.3
Works fine on Medion MD 7457
Comments posted by Gareth from United Kingdom, February 21, 2004:
Works great burning movies to Sony DRU510A firmware version 1.0f. Burns at 4x. Plays back fine on my Scan SC-2000 player
Price: $6 Purchased from: Makro (UK Wholesale store) Date purchased: February 2004
Burnt with Sony DRU-510A at 4x using firmware 1.0f.
DVD Shrink v3.1 TMPGEnc DVD Author v1.5.19.59
Works fine on Scan SC-2000
Comments posted by Larsen from Sweden, February 21, 2004:
Philips 1-4x, RW, DVD+ReWritable
Price: $3 Purchased from: www.nierle.de Date purchased: February 2004
Burnt with Pioneer DVR-106 / DVR-A06 at 2.4x using firmware 1.08.
Media text is DVD+RW 120 in Video, extended play 240, 4.7GB DATA.
Nero 6
Comments posted by Ronald from Netherlands, January 28, 2004:
No comments
Price: $3 Purchased from: Dixons E29.99 for 10-disk cakebox Date purchased: January 2004
Media text is Philips 1-4x DVD+RW.
Authored with DVDShrink 3.1.3 and burned with Nero 6.3.0.2
Works fine on JVC XV-N33SL
Does not work on Daewoo DVG-5000D
Comments posted by Poul Ole Larsen from Other, December 23, 2003:
Excellent. Have burned a lot at 4x, no coasters (yet).
Price: $3 Purchased from: www.burnalot.dk Date purchased: December 2003
Burnt with Lite-On LDW-411S/451S at 4x using firmware FS0F.
Media text is Philips 4.7 GB DVD+RW 4x speed.
Comments posted by LB from Other, December 17, 2003:
No comments
Price: $4 Purchased from: Bestbuy Date purchased: December 2003
Media text is Philips 1-4x DVD+rw 120 min video, extended 240min 4.7GB DATA.
Nero
Does not work on Sony DVP-S530D
Comments posted by Patrick from Other, December 16, 2003:
No comments
Price: $4 Purchased from: Media Markt Date purchased: December 2003
Burnt with LG GSA-4040B at 2.4x using firmware 1.03.
Media text is Philpis DVD+RW 120min Video extendend Play 240min 1-4x.
Nero 6.0.0.28
Does not work on Panasonic DVD-RV32
Comments posted by towi from Other, December 15, 2003:
i had to set the DVD-ROM bit for my LG player at home
Price: $1.7 Purchased from: saturn tuebingen Date purchased: December 2003
Burnt with Freecom DVD+RW/+R Internal at 2.4x using firmware 1.5g.
Media color is Black.
Media text is dvd+rw 120 min video xtended play 240min philips 1-4x single sided.
nero 5
Comments posted by Triton from Other, December 14, 2003:
No comments
Burnt with Lite-On LDW-401S at 4x
Media color is Blue.
Works fine on Samsung DVD-S223
Comments posted by hugo from Other, December 14, 2003:
No comments
Burnt with Plextor PX-708A at 4x using firmware 1.03.
Nero 5.5.10.45
Works fine on GoVideo DVP865
Comments posted by Jason from Other, December 02, 2003:
No comments
Burnt with NEC ND-5100A at 4x
Media text is Memorex 4.7 GB DVD+RW 4X rewritable.
Works fine on Samsung DVD-812
Comments posted by Guenter from Other, December 02, 2003:
Worked fine with NEC 1300A.
No problems with burning, erasing and burening again
Burnt with NEC ND-1300A at 2.4x using firmware 1.08.
Media text is Silver DVD+RW PHILIPS 1-4x.
Nero 5.5.10.54
Works fine on Panasonic DVD-S31
Comments posted by safari from Other, November 21, 2003:
Media perfectly burns
Price: $3 Date purchased: November 2003
Media text is DVD+RW PHILIPS 1-4x.
RecordNow MAX
31 user comments, Showing 1 to 31 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
