Philips |
DVD+RW |
4.7GB |
PHILIPS.041 |
4x |
Plays on 24 DVD Players
Plays not on 9 DVD Players
Burn Reliability is Good
DVD Reliability is Mixed
PC Reliability is Good
Console Reliability is Mixed
Read 31 comments (283098 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
08 02 00 00 92 0F 04 00 00 03 00 00 00 26 05 3F .............&.?
00 00 00 00 00 00 01 50 48 49 4C 49 50 53 00 30 .......PHILIPS.0
34 31 00 39 23 00 9F 7C 5C 02 28 00 9A 7E 70 02 41.9#..|.(..~p.
28 00 A0 7B 68 02 28 04 04 20 E0 00 F0 00 00 00 (..{h.(.. ......
Media color and text:
Silver DVD+RW PHILIPS 1-4x UPC/EAN Code:
No
31 user comments
Showing
1 to
31 comments |
Comments posted by rdkapp from United States, October 07, 2007:
The Media works fine. Out of about 25 burns, I've experienced 3 errors, but since it's an RW, I just erase the disc and start over. It's always burned fine on the 2nd try.
Additional information:
Date purchased: December -0001 Burnt with Samsung SH-S182D / TS-H652D at 4x using firmware 06. Burning reliability is Good. PC reliability is Good. DVD reliability is Mixed. Media color is Silver Green. Media text is Philips DVD+RW 1-4x 4.7GB 120 min. DVD+ReWritable. Media package type is Jewel Case. Number of discs 5. Media made in Taiwan. Media UPC/EAN code is 03784993481. Authoring/Burning comments: Burning Software used - ImgBurn
Burner has bitsetting for DVD+RW, which may be beneficial. Works fine on Magnavox MDV456 Does not work on Samsung DVD-HD755 |
Comments posted by nicoC from France, September 18, 2006:
No comments
Burnt with MSI DR12-A at 2.4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Gray. Media text is DVD+RW 120 min Video extended play 240min 4.7GB Data Philips 1-4x Single Sided. Media package type is Jewel Case. Number of discs 1. Works fine on Cyberhome CH-DVD 4010 |
Comments posted by Coetmeur from France, December 30, 2005:
Problems of playback in the second half of the disc on DVD player
Purchased from: Boulanger Burnt with MSI DR12-A at 2.4x using firmware 120D. Burning reliability is Good. PC reliability is Good. DVD reliability is Mixed. Media color is Gray. Media text is DVD+RW 120 min Video extended play 240min 4.7GB Data Philips 1-4x Single Sided. Media package type is Jewel Case. Number of discs 1. Works fine on Bluesky DS-8315 Does not work on Bluesky AD-1000 |
Comments posted by Coetmeur from France, July 01, 2005:
No comments
Burnt with MSI DR12-A at 2x using firmware 120D. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Gray. Media text is DVD+RW 120 min Video extended play 240min 4.7GB Data Philips 1-4x Single Sided. Media package type is Jewel Case. Number of discs 1. Works fine on Bluesky DS-8315 Does not work on Bluesky AD-1000 |
Comments posted by Grove_Street from United States, June 12, 2005:
No coasters with this media so far.
Price: $10 Purchased from: Radio Shack Date purchased: June 2005 Burnt with CyberHome CH-DVR 1600 at 1x using firmware see comment. Burning reliability is Good. PC reliability is Good. DVD reliability is Mixed. Console reliability is Good. Media color is Silver Black. Media text is DVD+RW 120 MIN VIDEO EXTENDED PLAY 240MIN. Media package type is Jewel Case. Number of discs 5. Media made in Taiwan. Media UPC/EAN code is 03784994273. Authoring/Burning comments: Firmware Version info of the DVD recorder is as follows: Main: CH_18.3.01.05.56
Loader: 090NDX Works fine on Microsoft Xbox Works fine on Sony Playstation 2 |
Comments posted by schranzmann from Germany, May 19, 2005:
No comments
Burnt with LG GSA-4163B at 4x using firmware 1.4. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Philips DVD+RW. Media package type is DVD Box. Number of discs 1. Works fine on LG DV-8700H |
Comments posted by Redking from United States, March 29, 2005:
Works perfectly, no problems.
Price: $4 Purchased from: Big Lots Date purchased: February 2005 Burnt with Philips DVDR615 at 1x using firmware 9.40. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Philips DVD+RW. Media package type is Jewel Case. Number of discs 3. Media made in Taiwan. Works fine on Panasonic DVD-RA60 |
Comments posted by Pete Lloyd from United Kingdom, January 25, 2005:
Media burns but will not play in Logix 3000 DVD player. Plays OK on Pc but thats not what I really want.
Purchased from: Currys UK (Special offer) Burnt with NEC ND-3450A at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Gray. Media text is Philips 4X DVD+RW 4.7GB. Media package type is DVD Box. Number of discs 10. Media made in Taiwan. Authoring/Burning comments: Sonic My DVD Does not work on Logix DVD-3000 |
Comments posted by Samtron from Finland, January 23, 2005:
No comments
Comments posted by Sebastiaan from Netherlands, November 23, 2004:
It is a 1-4 speed dvd disc but you can burn it also on 6x speed with no problems.
Price: $2 Purchased from: In a shop Date purchased: November 2004 Burnt with NEC ND-3500A at 6x using firmware 2.16. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media inkjet printable reliability is Good. Media color is Silver. Media text is Philips 4.7 GB Data 1-4x speed DVD+RW Single Sided. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: Nero 6.6.0.0 and alcohol 120% Version 1.9.2 build 1705 Works fine on Vestel DVD-2706 |
Comments posted by nogood from France, November 17, 2004:
it was burned and cleared on my dvd recorder nec nd3500a at 4x. I used too this media with my home dvd recorder philips hdrw 720.
Price: $10 Purchased from: nierle.de Date purchased: November 2004 Burnt with NEC ND-3500A at 4x using firmware 2.17. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Philips DVD+RW 120 min extented 240 mn video 4.7 GB data 1-4x. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: nero, roxio easy media shrink. Works fine on Philips HDRW720 |
Media image
 Click to enlarge |
Comments posted by Gerhard from Germany, November 13, 2004:
No comments
Date purchased: November 2004 Burnt with Teac DV-W58E at 4x using firmware D.0J. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Philips DVD+RW 120 min video 4.7 GB data 1-4x. Media package type is Slim Case. Number of discs 5. Authoring/Burning comments: CloneDVD2
Comments posted by Edward Ryan from United States, October 06, 2004:
Burned with no problems at 4x using Linux k3b, but wouldn't play on my XBOX, home DVD player, friend's PS2, and friend's DVD player. Which personally, I feel, completely defeats the purpose of it.
Price: $5 Purchased from: Local RadioShack Store Date purchased: October 2004 Burnt with Lite-On LDW-811S/851S at 4x Burning reliability is Good. DVD reliability is Poor. Console reliability is Poor. Media color is Silver Black. Media text is DVD+RW 120 Min Video (Extended Play 240 min) 4.7GB Data Philips 1-4X DVD+ReWritable Single Sided. Media package type is Jewel Case. Number of discs 1. Media made in Taiwan. Media UPC/EAN code is 037849942734. Authoring/Burning comments: Authored with DVD Architect 2.0, burned with k3b. Does not work on Microsoft Xbox Does not work on Sony Playstation 2 |
Comments posted by Wingdings from Sweden, September 28, 2004:
No comments
Burnt with NEC ND-2510A at 4x using firmware 1.77 Herrie's. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Poor. Media color is Silver. Media text is Philips DVD+RW 1-4x. Media package type is Jewel Case. Number of discs 1. Media made in Netherlands. Media UPC/EAN code is 8710895772662. Authoring/Burning comments: Nero 6.3.0.0 Does not work on Panasonic SA-HT80 |
Comments posted by Konstantin Yushin from Russian Federation, July 27, 2004:
Excellent media! Burns perfectly and reliably. Actually, it burns better then most of the other DVD-media (including +R/-R). Take a look here: http://ykk2.narod.ru/DVD-Media/Philips.DVDRW.4x.PNG
Price: $1.5 Purchased from: Small russian local store Date purchased: July 2004 Burnt with Lite-On SOHW-812S at 4x using firmware US0N. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Philips 1-4x DVD+RW 120 min video 4.7GB data. Media package type is Cake Box. Number of discs 10. Media made in Taiwan. Media UPC/EAN code is 8710895795609. Authoring/Burning comments: Nero 6.3.1.13 Works fine on BBK DVD-DV965 |
Media image
 Click to enlarge |
Comments posted by Konstantin Yushin from Sweden, July 26, 2004:
Perfect DVD+RW Media. Burns fine in several DVD-burners. Very low PI/PO error levels.
Price: $3 Purchased from: www.ultracomp.ru Date purchased: May 2004 Burnt with NEC ND-2500A at 4x using firmware 1.7 Herrie v2b5. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Philips 1-4x DVD+RW 120 min video 4.7GB data. Media package type is Jewel Case. Number of discs 1. Media made in Netherlands. Media UPC/EAN code is 8710895772662. Authoring/Burning comments: Nero 6.3.1.13 Works fine on BBK DVD-DV965 |
Media image
 Click to enlarge |
Comments posted by Mark from Netherlands, June 02, 2004:
My experience: total crap. Like DeathAngel (see comment below), the label said to check the firmware upgrade (not necessary in case of the NEC2500A). I checked and doublechecked everything, but so far 7 of 7 discs gave power calibration errors. It looks like the formatting is ok, but then after 15-25 seconds, the error message pops up. I've burned Sony DVD+R without a problem on the drive, so apparently the drive is ok. I'll never buy these again ...
Price: $2 Purchased from: V&D (large dutch retail store) Date purchased: May 2004 Burnt with NEC ND-2500A at 2.4x using firmware 1.06/1.07. Burning reliability is Poor. Media color is Silver. Media text is DVD+RW 120min video, 4.7Gb data, Philips 1-4x, DVD+ReWritable. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: Nero 6.3.1.10 |
Comments posted by DeathAngel from Netherlands, May 08, 2004:
The label on the discs warns the user with the following text: "Before burning this disc in a 2.4x DVD+RW data drive, you need to check how to get the required firmware upgrade. Full Details can be found in enclosed booklet". see www.dvdrservices.com.
The NEC ND-1100 is a 2.4x speed burner (DVD+RW) therefore it's wise to check your disc after burning with NERO's CDSPEED or DVDinfoPro for abnormalities.
In almost all cases the burning process goes OKE.
The reliabilty for this media drops due to the lack of Firmware upgrades by NEC.
Price: $3 Burnt with NEC ND-1100A at 2.4x using firmware 1.A0. Burning reliability is Mixed. PC reliability is Mixed. DVD reliability is Good. Media color is Silver. Media text is Philips 1-4x 4.7GB DVD+RW 120 VIDEO Single Sided. Media package type is Jewel Case. Number of discs 5. Media made in Taiwan. Authoring/Burning comments: NERO 6.3.1.6 Works fine on Pioneer DV-444 Works fine on Sony Playstation 2 |
Comments posted by ollibauso from Sweden, February 21, 2004:
No comments
Purchased from: ebay germany ; 18€ , 10 discs cake Date purchased: February 2004 Burnt with NEC ND-2500A at 4x using firmware 1.06. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Philips 1-4X DVD+RW 120 min Video 4.7GB Data. Authoring/Burning comments: Nero 6.3.0.3 Works fine on Medion MD 7457 |
Comments posted by Gareth from United Kingdom, February 21, 2004:
Works great burning movies to Sony DRU510A firmware version 1.0f. Burns at 4x. Plays back fine on my Scan SC-2000 player
Price: $6 Purchased from: Makro (UK Wholesale store) Date purchased: February 2004 Burnt with Sony DRU-510A at 4x using firmware 1.0f. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Philips 1-4x DVD+RW 120 min video 4.7GB data. Authoring/Burning comments: DVD Shrink v3.1 TMPGEnc DVD Author v1.5.19.59 Works fine on Scan SC-2000 |
Comments posted by Larsen from Sweden, February 21, 2004:
Philips 1-4x, RW, DVD+ReWritable
Price: $3 Purchased from: www.nierle.de Date purchased: February 2004 Burnt with Pioneer DVR-106 / DVR-A06 at 2.4x using firmware 1.08. Burning reliability is Good. PC reliability is Good. Media color is Silver. Media text is DVD+RW 120 in Video, extended play 240, 4.7GB DATA. Authoring/Burning comments: Nero 6 |
Comments posted by Ronald from Netherlands, January 28, 2004:
No comments
Price: $3 Purchased from: Dixons E29.99 for 10-disk cakebox Date purchased: January 2004 Burnt with NEC ND-2500A at 4x using firmware 1.06. Burning reliability is Good. PC reliability is Good. DVD reliability is Mixed. Media color is Silver Black. Media text is Philips 1-4x DVD+RW. Authoring/Burning comments: Authored with DVDShrink 3.1.3 and burned with Nero 6.3.0.2 Works fine on JVC XV-N33SL Does not work on Daewoo DVG-5000D |
Comments posted by Poul Ole Larsen from Other, December 23, 2003:
Excellent. Have burned a lot at 4x, no coasters (yet).
Price: $3 Purchased from: www.burnalot.dk Date purchased: December 2003 Burnt with Lite-On LDW-411S/451S at 4x using firmware FS0F. Burning reliability is Good. PC reliability is Good. Media color is Silver. Media text is Philips 4.7 GB DVD+RW 4x speed. |
Comments posted by LB from Other, December 17, 2003:
No comments
Price: $4 Purchased from: Bestbuy Date purchased: December 2003 Burnt with Lite-On LDW-411S/451S at 4x using firmware FS0F. Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Silver. Media text is Philips 1-4x DVD+rw 120 min video, extended 240min 4.7GB DATA. Authoring/Burning comments: Nero Does not work on Sony DVP-S530D |
Comments posted by Patrick from Other, December 16, 2003:
No comments
Price: $4 Purchased from: Media Markt Date purchased: December 2003 Burnt with LG GSA-4040B at 2.4x using firmware 1.03. Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Gray. Media text is Philpis DVD+RW 120min Video extendend Play 240min 1-4x. Authoring/Burning comments: Nero 6.0.0.28 Does not work on Panasonic DVD-RV32 |
Comments posted by towi from Other, December 15, 2003:
i had to set the DVD-ROM bit for my LG player at home
Price: $1.7 Purchased from: saturn tuebingen Date purchased: December 2003 Burnt with Freecom DVD+RW/+R Internal at 2.4x using firmware 1.5g. Burning reliability is Mixed. PC reliability is Good. Media color is Black. Media text is dvd+rw 120 min video xtended play 240min philips 1-4x single sided. Authoring/Burning comments: nero 5 |
Comments posted by Triton from Other, December 14, 2003:
No comments
Burnt with Lite-On LDW-401S at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Blue. Media text is Philips DVD+RW 1-4x. Works fine on Samsung DVD-S223 |
Comments posted by hugo from Other, December 14, 2003:
No comments
Burnt with Plextor PX-708A at 4x using firmware 1.03. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Philips DVD+RW 1-4x. Authoring/Burning comments: Nero 5.5.10.45 Works fine on GoVideo DVP865 |
Comments posted by Jason from Other, December 02, 2003:
No comments
Burnt with NEC ND-5100A at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Memorex 4.7 GB DVD+RW 4X rewritable. Works fine on Samsung DVD-812 |
Comments posted by Guenter from Other, December 02, 2003:
Worked fine with NEC 1300A.
No problems with burning, erasing and burening again
Burnt with NEC ND-1300A at 2.4x using firmware 1.08. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Silver DVD+RW PHILIPS 1-4x. Authoring/Burning comments: Nero 5.5.10.54 Works fine on Panasonic DVD-S31 |
Comments posted by safari from Other, November 21, 2003:
Media perfectly burns
Price: $3 Date purchased: November 2003 Burnt with NEC ND-1300A at 2.4x using firmware 1.08. Burning reliability is Good. PC reliability is Good. Media color is Silver. Media text is DVD+RW PHILIPS 1-4x. Authoring/Burning comments: RecordNow MAX |
31 user comments,
Showing
1 to
31 comments |
