Laser |
DVD-R |
4.7GB |
AN32........ |
4x |
Plays on 3 DVD Players
Plays not on 1 DVD Players
Burn Reliability is Mixed
DVD Reliability is Good
PC Reliability is Good
Console Reliability is Good
Read 9 comments (46155 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 87 0E 15 .l...@....R.....
98 9A 90 00 03 41 4E 33 32 00 00 00 04 00 00 00 .....AN32.......
00 00 00 00 05 CC C0 00 00 00 01 00 06 0B 10 11 ................
Media color and text:
Silver nil UPC/EAN Code:
No
9 user comments
Showing
1 to
9 comments |
Comments posted by Dave from Other, January 16, 2004:
These only work at 2x on the Pioneer A06. I've used plenty of the laser's made by AML and they work ok at 4x but these don't.
Additional information:
Burnt with Pioneer DVR-106 / DVR-A06 at 2x using firmware 1.06. Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is none. Authoring/Burning comments: Nero and DVD Decrypter |
Comments posted by beneuto from Other, January 07, 2004:
I have tried many things to get these discs to work without success. The burner writes to TDK and Taiyo Yuden ok.
Price: $1.6 Purchased from: The Disc Shop Date purchased: November 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0d. Burning reliability is Poor. Media color is Silver. Media text is None. Authoring/Burning comments: Tried Roxio, HaCD, Nero, CloneDVD, Sonic DVD, and even Norton Ghost. Tried all speeds, DMA/PIO, Master/Slave, only drive. |
Comments posted by Ian from Other, November 10, 2003:
bought as a tub of 25 blank on top works fine in sonydru-510a plays on all dvd players i've tried without a hitch
Price: $1.9 Purchased from: The Discshop.com.au Date purchased: November 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0d. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is nil. Authoring/Burning comments: nero 6 |
Comments posted by Al from Other, November 05, 2003:
Only works at 2x in the Pioneer A06. If lucky you may get 1 or 2 out of a spindle pack of 25 to work at 4x, but if it fails the DVD becomes unusable.
Price: $4 Date purchased: September 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.06. Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is (none). Authoring/Burning comments: Nero Express 5.5.10.42 Works fine on Pioneer DV-505 |
Comments posted by A7MAD from Other, November 03, 2003:
They are 4x DVD-R discs however I have used no other burning software on these discs other than Clone DVD 1.3 (latest) even @ 4x the program takes 29-30mins to complete so it is as if it is burning the discs like @ 2x however they are stable thru and thru.
I have used both the Sony DRU-510A (1.0D) and the Pioneer DVR-106D (1.07 >NIL:)
When played in stand alone DVD players all of them work, just had issues with one Conia standalone, but its over 6 years old now...
Price: $1.6 Purchased from: www.it-tech.com.au Date purchased: October 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware >NIL: 1.07). Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is No media text. Authoring/Burning comments: Clone DVD (www.elby.de) |
Comments posted by Mark from Other, October 25, 2003:
Half way through my 25 pack. Nero always picks up as 4x, but I only like to burn at 2x. Never failed a burn. Play perfectly right the way to the end...
Price: $2 Purchased from: IT Warehouse (South AUSTRALIA) Date purchased: October 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 2x using firmware 1.07. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is blank reflective tops. Authoring/Burning comments: DVD Shrink 2.3, Nero 6. Works fine on Pioneer DV-355 |
Comments posted by murkm from Other, September 30, 2003:
Bought a 25 pack cheap $22 with shipment.
ND-1300A does not recognie them as useful media.
Using firmware 1.07
Guess they will wait till next firmware update,
or till next recorder ...
Price: $0.7 Purchased from: yesbuy.com Date purchased: September 2003 Burnt with NEC ND-1300A at 4x using firmware 1.07. Burning reliability is Poor. Media color is Silver. Media text is DVD-R 4x AN32. Authoring/Burning comments: Ulead, Roxio |
Comments posted by js from Other, September 30, 2003:
claimed as 4x but on a Pioneer A05 produces a readable result only at 1x (and this is on the same Pioneer unit that wrote it!)
DVD-Video burned at 1x playable on Omni player but not on an old Sony.
Price: $2 Purchased from: Northrocks Date purchased: September 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 4x Burning reliability is Poor. PC reliability is Good. DVD reliability is Mixed. Media color is Silver. Media text is none. Authoring/Burning comments: Nero 6 & Ulead Movie Factory 2
Works fine on Omni SLP3000 Does not work on Sony DVP-S525D |
Comments posted by studebarc from Other, September 10, 2003:
No comments
Price: $0.9 Purchased from: www.thediscshop.com.au Date purchased: September 2003 Burnt with Lite-On LDW-400D at 2x Burning reliability is Poor. PC reliability is Good. DVD reliability is Poor. Media color is Silver. Media text is nil. |
9 user comments,
Showing
1 to
9 comments |
