Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
HP DVD+R 4.7GB CMC MAG.M01 16x Plays on 15 DVD Players
Plays not on 10 DVD Players
Burn Reliability is Mixed
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is Mixed
Read 21 comments
(212988 views)
Post comment
00 00 00 00 00 00 07 43 4d 43 20 4d 41 47 00 4d .......CMC MAG.M
30 31 00 38 23 54 37 18 00 3e 6e 00 70 62 15 15 01.8#T7..>n.pb..
0b 0b 08 08 01 19 1b 0b 0b 0e 0f 01 00 00 00 00 ................
Media color and text:
Orange HP dvd+r 16x 4.7GB
UPC/EAN Code:
No info
21 user comments
Showing 1 to 21 comments
Comments posted by 1683688 from Thailand, March 16, 2010:
No comments
Additional information:
Purchased from: www.dvdr2u.com Date purchased: December -0001
Burnt with Pioneer DVR-117 at 16x
Burning reliability is Good.
PC reliability is Mixed.
Media color is Yellow .
Media text is HP DVD+R 4.7GB 16x.
Comments posted by redborough from Netherlands, June 30, 2009:
No comments
Price: $4 Purchased from: www.opus.de Date purchased: May 2009
Burnt with Pioneer DVR-112D / DVR-1810 at 8x using firmware 1.28.
Burning reliability is Poor.
DVD reliability is Mixed.
Media color is Orange.
Media text is HP 4.7 GB DVD+R 16x speed.
Media package type is Cake Box. Number of discs 10.
Media made in Taiwan.
Media UPC/EAN code is 4710212129647.
Authoring/Burning comments:
Media gives crappy scans on several writers. Results in skips even on dvd players that are usually uncritical (Onkyo). burnt at 6x and 8x
Works fine on Harman Kardon DVD21
Works fine on Onkyo DV-SP402E
Works fine on Onkyo DV-SP404E
Works fine on Onkyo DV-SP406
Comments posted by victoriabears from Canada, February 11, 2008:
Works great on LG burner, I always burn at 8x though, and LG burners seem to be more tolerant
Price: $0.3 Purchased from: tiger direct canada Date purchased: August 2007
Burnt with LG GSA-4163B at 8x using firmware a16.
PC reliability is Good.
DVD reliability is Good.
Media text is HP DVD+R.
Works fine on OPPO DV-981HD
Works fine on Philips DVP5960
Works fine on Philips DVP5980
Comments posted by Bud Stansbury from United States, August 05, 2007:
I did not realize how bad this stuff was until I had burned 30 of them. It will not play in Sony DVD units. It can't even be recoginixed as DVD media in a NEC 3550A drive. All were burn in a Lite-0n 1693 drive and worked in a Toshiba DVD drive. This is the same media listed for HP Media. Mfg. is CMC Mag. There have been dozens of bad reports on this media on this web site.
Price: $30 Purchased from: Sam's Club Date purchased: January 2007
Burnt with Lite-On SOHW-1693S at 6x using firmware 1.05.
PC reliability is Poor.
DVD reliability is Poor.
Console reliability is Poor.
Media inkjet printable reliability is Poor.
Media color is White.
Media text is No Text Printable label.
Media UPC/EAN code is 002356485214.
Nero Express 6.0
Works fine on Toshiba SDK620
Does not work on Sony SLV-D251P
Comments posted by yup from Canada, August 03, 2007:
No comments
Price: $10 Date purchased: July 2007
Burnt with LG GSA-H62L at 16x
Media text is HP DVD+R 16X.
Media UPC/EAN code is 637668020400.
Burned w/ Nero Express 7
Also worked with BenQ 1620
Media image
Mediaimage
Click to enlarge
Comments posted by Urnfs from Israel, July 04, 2007:
This media is the best for long term backups. i went and did a transfer rate test a year and a half after i burned it and it got a perfect curve. just to compare, i did the same thing to a verbatim dvd-r x16 azu+ media and it totally gave in on me near the end of the disc. now when i see an HP media next to a verbatim media at the store i know which one I'll be choosing. just excellent.
Burnt with Philips DVDR1628 / DVDR1648 at 16x using firmware 1.1.
Media color is Gold.
Media text is HP Invent dvd+r 16x 4.7GB/120min..
Media package type is Slim Case. Number of discs 10.
Comments posted by Anonymous from United States, May 31, 2007:
No comments
Purchased from: Officemax Date purchased: December -0001
Burnt with Lite-On LDW-411S/451S at 16x
Media text is HP invent.
Nero 6, Also burned with a Lite-on LH-20A1L
Does not work on RCA RC5240P
Comments posted by farmkid from United States, May 19, 2007:
My spindle had many bad discs. Approximately 20% had visible defects. If I tried using a disc with a defect, the burning process invariably failed when the laser reached the defect. Two of the discs without visible defects also failed. However, those that worked were just fine.
Price: $10 Purchased from: OfficeMax Date purchased: March 2007
Burnt with Lite-On SOHW-1633S at 8x
Media text is HP.
Nero
Comments posted by Ric from United States, February 20, 2007:
This is a follow-up to a previous post (Ric, Jan. 8, 2007).
After burning several more discs (approx. 10/50), I downgrade this media. Burns at 16X & 12X failed. Burns at 8X are playable but have more errors than "quality media". Burns at 6X are better. Will consider hacking my firmware to allow 4X burns. Media still okay due to cheap price for give-aways and non-critical stuff at 6X burn, but will investigate 4X burns.
Purchased from: CircuitCity Date purchased: January 2007
Burnt with Lite-On SOHW-1693S at 6x using firmware KSOB.
Burning reliability is Mixed.
Media color is Gray.
Media text is hp dvd+r 16x.
NERO 7, DVD Shrink
Works fine on Samsung DVD-M301
Works fine on Sony DVP-NS425P
Works fine on Toshiba SD1700
Comments posted by EnsErmac from United States, February 12, 2007:
Media does not burn in Toshiba SD-R 5272
Price: $10 Purchased from: Big Lots Date purchased: February 2007
Burnt with Toshiba SD-R5272 at 4x using firmware 1031.
Media text is HP DVD+R 16x.
Tried with Toast Titanium, Disco, and Apple's built in software with NO LUCK AT ALL
all say that the media is not writable
Comments posted by oldandinthe way from United States, January 09, 2007:
Works every time.. LG-4163B LG-H10N
Price: $0.1 Purchased from: staples Date purchased: November 2007
Burnt with LG GSA-4163B at 16x
Gateway oem firmware/ Nero, AnyDVD, DVDshrink IMGburn, etc etc
Works fine on Lite-On LVW-5005
Works fine on Zenith XBV343
Comments posted by Ric from United States, January 08, 2007:
Model DR00044XM purchased at Circuit City January 1, 2007 for $10. So far no bad disk, although only burned 1 of 50. Ran scan and PI Error max was 223 PIF max was 3 (Avg. .60). A distant third behind Sony DVD+R and TDK DVD-R I also use, but good enough for "give aways" considering price. Suggest burning at lower speed than 16X.
Price: $10 Purchased from: Circuit City Date purchased: January 2007
Burnt with Lite-On SOHW-1693S at 16x using firmware KS0B.
Console reliability is Good.
NEROVision (Max speed burn option)
Comments posted by Cesar Romeo from United States, October 30, 2006:
The media quality is bad/mediocre only recommended, if you find them cheap.
I burned with Imgburn at 16x, 12x, 8x, 6x and 4x and tested with Nero CD/DVD Speed.
These are my results (less is better):
16x PI errors Max: 6772 PI failures Max: 774
12x PI errors Max: 6103 PI failures Max: 431
8x PI errors Max: 447 PI failures Max: 76
6x PI errors Max: 413 PI failures Max: 22
4x PI errors Max: 274 PI failures Max: 19
Keep in mind that media reliaability might change (if you have a different burner/firmware/better PC), just because 4x is the best burning speed for me, it does not mean it will be the best for you.
I recommend you do your own testing and just use my testing as a guideline, because you might get different (better or worse) results
Price: $6 Purchased from: Circuit City Date purchased: December -0001
Burnt with NEC ND-3550A at 4x using firmware 1.06.
Media color is Silver Orange.
Media text is dvd+r 16x 4.7GB / 120min.
Media UPC/EAN code is 6 37668 02037 0.
Imgburn, Nero CD/DVD Speed.
Media image
Mediaimage
Click to enlarge
Comments posted by J Blatt from United States, August 01, 2006:
0 for 2. Same manufacturer as Memorex, same poor reliability. Fuji disks are much better.
Burnt with Pioneer DVR-110D / DVR-R100 / DVR-610 at 8x using firmware 1.39.
Media text is dvd+r 16x 4.7GB / 120 min.
Comments posted by Vu Luu from United States, July 07, 2006:
No comments
Price: $0.3 Purchased from: Frys
Burnt with BenQ DW1620 (Pro) at 16x using firmware b7v9.
Media UPC/EAN code is 637668020417.
Nero version 6.6.0.15
Comments posted by Alfred from United States, June 30, 2006:
Burned in hp 200e, reads back fine. However is not readable by any DVD player (various models of Sony & Panasonic tried) nor any other computer. However, Sony or Memorex disks burned on the same hp 200e read fine on players and computers. Strongly suspect bad media. Burned at 2x.
Price: $0.7 Purchased from: OfficeMax Date purchased: June 2006
Burnt with HP DVD200e at 2x
Media text is hp invent dvd+r 16x 4.7GB/120min.
Converted/Burned with ConvertXtoDVD
Does not work on Panasonic DVD-A560
Does not work on Panasonic DVD-C220
Does not work on Panasonic DVD-CP72S
Does not work on Panasonic DVD-CV35
Does not work on Sony DVP-6500
Does not work on Sony DVP-CX860
Does not work on Sony DVP-K880
Comments posted by Ron Waid from United States, June 08, 2006:
Burn failed on 2 different DVD burners, My LG GSA-4163B & my Lite-on SOHW-1673S. Not sure about the playback reliability cause I haven't got one to burn yet.
Price: $20 Purchased from: OfficeMax Date purchased: May 2006
Burnt with LG GSA-4163B at 16x using firmware A05.
Media text is DVD+R 16X 4.7GB / 120min.
Used both Nero & VSO CopytoDVD.
Does not work on Lafayette LF400
Comments posted by Mercury from United States, April 24, 2006:
No comments
Burnt with Lite-On SOHW-1213S at 16x
DVDNextCopy
Comments posted by Urnfs from Israel, March 20, 2006:
Ripoff. Chose 16x to burn.Nero says it's 16x,but infact it burnt at 4x at max (unless 16x usally takes 15 minutes to burn).Verification suceeded,but reading speeds at verification were low (4.0x - 6.8x at best,i usally get 10x with my burnt stuff)
dvd playback is good,no freezes and stuff
Price: $7 Date purchased: March 2006
Burnt with Philips DVDR1628 / DVDR1648 at 4x using firmware 1.0.
nero,don't know the ver.
Comments posted by Bengt from Sweden, March 04, 2006:
No comments
Price: $0.4 Purchased from: www.wesellcd.com Date purchased: February 2006
Burnt with NEC ND-3500A at 16x using firmware 2.88.
Media UPC/EAN code is 4710212129630.
Works fine on LG 6194
Works fine on Philips DVP520
Media image
Mediaimage
Click to enlarge
Comments posted by Harry from United States, January 27, 2006:
No comments
Price: $0.3 Purchased from: Officemax Date purchased: January 2006
Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.08.
Media text is HP dvd+r 16x 4.7GB.
burned with Nero Burning Rom version 6.6.0.8
21 user comments, Showing 1 to 21 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
