E3Works |
DVD-R |
4.7GB |
LEADDATA01.. |
4x |
Plays on 22 DVD Players
Plays not on 4 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is Mixed
Read 21 comments (173674 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
00 6A 00 00 01 40 C1 FD 9E D8 52 00 02 87 0D 11 .j...@....R.....
66 78 80 00 03 4C 45 41 44 44 41 00 04 54 41 30 fx...LEADDA..TA0
31 00 00 00 05 A8 82 00 20 00 02 00 06 09 11 11 1....... .......
or
00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 88 0E 13 .l...@....R.....
87 88 80 00 03 4C 45 41 44 44 41 00 04 54 41 30 .....LEADDA..TA0
31 00 00 00 05 88 80 00 00 00 01 00 06 06 14 11 1...............
Media color and text:
Silver None UPC/EAN Code:
837853000952
21 user comments
Showing
1 to
21 comments |
Comments posted by Oldfart13 from Canada, June 26, 2004:
Won't finalize in Panasonic E80H at 1X. DVDInfo Pro says that they are riddled with errors. Tested in a Pioneer A05 which I use to burn Maxell media, these are full of errors while the Maxells report 0 errors! Though they play in my E80H, Norcent DP-300 and Apex AD-1500 they may not work in other players. The Maxells play fine in all players. Back these go...
Additional information:
Price: $30 Purchased from: Future Shop Date purchased: June 2004 Burnt with Panasonic DMR-E80H at 1x Burning reliability is Poor. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is None. Media package type is Cake Box. Number of discs 50. Media made in China. Media UPC/EAN code is 3785300020. Works fine on Norcent DP 300 |
Comments posted by Sam Ontario from Canada, June 04, 2004:
No coaster and played fine on all my DVD players
Purchased from: Future Shop Burnt with LG GSA-4082B at 4x using firmware A201. Burning reliability is Good. DVD reliability is Good. Media color is Silver. Media text is e3Works 1-4x DVD-R. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Nero 5.5.10.56 Works fine on Apex AD-1225 Works fine on Citizen JDVD3838 Works fine on Citizen JDVD3842 Works fine on Daytek P871 |
Comments posted by Bojan from Canada, March 30, 2004:
Media would burn only at 2x. It would read 1 out of 2 of my DVD players. To my surprise the Apex AD-600A would not read it and my Electrohome EH8008A does read it. It's a cheap media and I might continue to buy since it does work on 1 of my DVD players that I have.
Burnt with LG GSA-4040B at 2x using firmware A302. Burning reliability is Good. PC reliability is Good. DVD reliability is Mixed. Media color is Silver Pink. Media text is e3works 4.7GB 1x-4x. Media package type is Slim Case. Number of discs 10. Authoring/Burning comments: Used dvd decrypter, then used dvd shrink and finally Nero to burn. Works fine on Electrohome EH8158 Does not work on Apex AD-600 |
Comments posted by Drew from Canada, March 16, 2004:
Purchased from Future Shop too.
Burned 4.7GB MP3 files successful at 4X.
Burnt with AOpen DRW8800/AAN at 4x Burning reliability is Good. PC reliability is Good. Media color is Purple. Media text is e3 Works. Media package type is Slim Case. Number of discs 10. Media made in Taiwan. |
Comments posted by Doofy from Canada, February 28, 2004:
Got the e3works media at Future Shop.My Plextor 708A has a hard time even recognizing these discs, nevermind burning them. They seem to burn alright (when recognized), but compatibility with both DVD-ROM and DVD standalone players over 4GB seems poor at best. I'll be steering clear of these ones in the future.
Price: $1.5 Burnt with Plextor PX-708A at 4x using firmware 1.04. Burning reliability is Poor. PC reliability is Mixed. DVD reliability is Poor. Media color is Silver. Media text is Black. Media package type is Cake Box. Number of discs 25. |
Comments posted by Steve Paulette from Canada, January 21, 2004:
No problems with this at 2X on a LG GSA 4040B. Good with data, DVD backups. Will repost when burner firmware is updated.
Price: $1.5 Purchased from: Future Shop Date purchased: January 2004 Burnt with LG GSA-4040B at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is E3 Works 4.7 GB - 1x-4X, DVD-R, DVD R, R 47. Authoring/Burning comments: DVD's authored on Linux Mandrake 9.2 system using dvdauthor 0.6.6, transcode 6.11. Works fine on Sony DVP-S360 |
Comments posted by Joseph Bart from Other, January 08, 2004:
Well it sucks, I bought the bundle of 25 from Future Shop and it seems to me it will go back. I went through other no name DVD R’s before with no problem. It played flawlessly on my Koss DVD player or the computer. I burned 3 DVDs from the new pack of E3Works and all of them crushed or froze at the and of the move after 4x burn. I will try another one at 2x and probably will return it to the store.
Purchased from: Future Shop Date purchased: December 2003 Burnt with Sony DRU-510A at 4x Burning reliability is Good. PC reliability is Poor. DVD reliability is Poor. Media color is Purple. Media text is E3Works 4.7 GB 1x-4x. Authoring/Burning comments: Nero 6.3 Does not work on Koss KS3123-2 |
Comments posted by bill from Other, December 29, 2003:
Good media, didnt work on a ps2 but many ps2's were made and that was only one that had problems with it. Its cheap media but it works well.
Purchased from: futureshop Burnt with LG GMA-4020B at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Poor. Media color is Purple. Media text is A3VL3303E29300167. Authoring/Burning comments: Tmpgenc DVD Author
Nero 5.5.9.14 Works fine on JVC XV-N44SL Works fine on Toshiba SD2710 |
Comments posted by Kevin DOan from Other, November 28, 2003:
Burns fine at 2x for my LG GMA-4020B which only burns at 2x anyways, plays fine in set-tops, but in the PS-2, you can hear an odd noice but will still read fine.
Price: $1.8 Purchased from: www.FutureShop.com Date purchased: November 2003 Burnt with LG GMA-4020B at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Mixed. Media color is Silver. Media text is e3works. |
Comments posted by Red Ketchup from Other, November 22, 2003:
Got my DVD writer mostly to perform data backups and transfers (DV raw data). Got a spindle at Futile-Shop too and up to now 10 DVD's were burned flawlessly at 4x.
I've yet to author or "backup" DVD's for my Apex-1500 but I am optimist.
At $1.60can each, I can't complain.
Price: $1.6 Purchased from: Future-Shop Date purchased: November 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 107. Burning reliability is Good. PC reliability is Good. Media color is Silver. Media text is E3Works 4.7gb - 1x-4x - DVD-R. Authoring/Burning comments: Nero (not impressed with nero, back to EasyCD-DVD I go!) |
Comments posted by STEVE from Other, November 05, 2003:
Bought a 25 disc spindle at Future Shop, and at least 1 disc failed to read on my computer; however, it works on standalone DVD players. Strange! The long term durability of this media is unknown, although the manufacturer claims a 100 year archival life for their product. I have to put critical data on Maxell or Memorex discs. You get what you paid for. Poor value at the regular price. Pay a little more for Memorex for premium media, and that's good value to boot!
Comments posted by maxxnostra from Other, November 04, 2003:
Looks like the media is same as PioData, at least the media info is same and those are just unbranded. Works well on my ASUS 0402P/D and in my APEX-AD1500
Price: $1.5 Purchased from: www.FutureShop.ca Date purchased: November 2003 Burnt with Asus DRW-0402P/D at 4x using firmware 1.05. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is silver/non branded. Authoring/Burning comments: DVD Shrink 2.3 and Nero Express 6 Works fine on Apex AD-1500 |
Comments posted by derrek from Other, October 13, 2003:
No comments
Price: $2 Burnt with LG GMA-4020B at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Silver. Media text is E3Works Pearl Discs. |
Comments posted by doodio from Other, October 12, 2003:
Great media so far... burns fast! 4.0-4.3X.. quite stable. discs work fine in my pioneer and apex.. works in the xbox! : )
Price: $0.8 Purchased from: Future Shop - www.futureshop.ca Date purchased: September 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is none. Authoring/Burning comments: everything! Works fine on Apex AD-1600 Works fine on Pioneer DV-C503D Works fine on Pioneer DV-C505 |
Comments posted by Jeff from Other, September 30, 2003:
works in any and all dvd set top players that i have tested it on. works on xbox. have had very mixed results with ps2 though. and sometimes it works on ps2 but will stutter. they are a really good deal if you have a set top player.
Price: $1.6 Purchased from: Futureshop Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.30. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Mixed. Media color is Silver. Media text is unbranded. Authoring/Burning comments: Nero 5.5 Does not work on Sony Playstation 2 |
Comments posted by skyh from Other, September 21, 2003:
No comments
Price: $1.6 Purchased from: Futureshop Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.06. Burning reliability is Good. Console reliability is Good. Media color is Gray. Media text is Blank. Authoring/Burning comments: Nero Works fine on Microsoft Xbox |
Comments posted by derrek from Other, September 18, 2003:
Burnt 4 discs so far and all good. No problems in dvd-rom drive or standalone. Looking at the other comments, either its the hardware, or multitasks being done which are interfering with discs. I do not multitask and shut down all none essential programs. then burn @ 2x on p4, 2.53ghz. I have yet to make a coster (83 successful burns)despite all the media I used (memorex, maxell, apple, princo and not e3works).
My only concern though is long term durability; but I have
a guinea pig dvdr being used and abused daily now for 5 days to see whether its stands up and will report findinds in the near future.
Overall though, for the time being, Im satisfied.
Price: $1.6 Purchased from: www.futureshop.ca Date purchased: September 2003 Burnt with LG GMA-4020B at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is E3Works Pearl Discs. Works fine on JVC XV-S300BK |
Comments posted by g0 from Other, September 17, 2003:
well they were on sale when I got my LG 4040B this week, can only get 2x out of them with anything. They are the cheap ones tho so I was not expecting much
Price: $1.6 Purchased from: www.futureshop.ca Date purchased: September 2003 Burnt with LG GSA-4040B at 2x using firmware a300. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is nothing. Authoring/Burning comments: nero
dvd decrypter
alcohol |
Comments posted by Davie from Other, September 06, 2003:
Burned at 2X only. Returned first spindle to Future Shop as writer claims 4X capability. Burned three more discs (2X max again). Failed to play back at all on PC on one of them; failed PC play back at 25 - 30 minute mark on another.
Could be DVD-Writer's fault. Returning second of these drives to be unsatisfactory after only a total of eight days since initial purchase.
"Pine" brand, having no DVD Media code replacement, also burned at 2X max and gave same playback error when same disc content was redone.
All discs seemed to be OK for playback on Pioneer 434 standalone DVD player, though 100 % screening was not done.
Purchased from: Future Shop Date purchased: August 2003 Burnt with LG GSA-4040B at 2x using firmware A104. Burning reliability is Poor. PC reliability is Poor. DVD reliability is Good. Media color is Silver. Media text is None. Authoring/Burning comments: TMPGEnc DVD Author plus Nero 6.0.0.11 Works fine on Norcent DP 300 Works fine on Pioneer DV-434 |
Comments posted by Sh0gun from Other, September 03, 2003:
Picked a spindle of 25 at Future Shop on sale ($40CDN) and burns great(4x) with my pioneer 105 and plays perfect on my pioneer dv-353.Wish they'd have labels but for that price I can't complain.
Purchased from: Future Shop Date purchased: September 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.33 hacked. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is none. Authoring/Burning comments: DVD shrink,CopyToDvd,Nero 6 Works fine on Pioneer DV-353 |
Comments posted by Papidesi from Other, September 03, 2003:
Burned a 4.3GB DVD onto this media. However, burned at 2.4x not 4.0x as advertized but that might be due to the fact that i've to update the firmware on my Sony DRU-500AX.
Purchased from: Futureshop Date purchased: September 2003 Burnt with Sony DRU-500AX at 4x using firmware 2.0c. Burning reliability is Good. PC reliability is Good. DVD reliability is Mixed. Media color is Silver. Media text is None. Media UPC/EAN code is 837853000952. Authoring/Burning comments: Burned DVD using InstantCopy but only burned at 2.4x The burnt DVD plays fine in my Dell PC, and Apex-AD2500 but does not plays in Panasonic DVD120 player. Works fine on Apex AD-2500 Does not work on Panasonic DVD-A120 |
21 user comments,
Showing
1 to
21 comments |
