Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Acro Circle DVD+R 4.7GB OPTODISCOR8 8x Plays on 6 DVD Players
Plays not on 0 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is Mixed
Read 9 comments
(89617 views)
Post comment
08 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
00 00 00 00 00 00 03 4F 50 54 4F 44 49 53 43 4F .......OPTODISCO
52 38 00 38 23 54 37 09 02 64 6A 02 C8 63 18 18 R8.8#T7..dj..c..
0A 0A 0E 0E 01 1B 1D 0B 0B 11 13 01 00 00 00 00 ................
Media color and text:
White Acro Circle DVD+R 1-8X
UPC/EAN Code:
4710837109505
9 user comments
Showing 1 to 9 comments
Comments posted by jimboe from United States, February 15, 2007:
00000000 08 02 00 00 01 0F 02 00 00 03 00 00 00 25 7A 0F .............%z.
00000010 00 00 00 00 00 00 03 4F 50 54 4F 44 49 53 43 4F .......OPTODISCO
00000020 52 38 00 38 23 54 37 09 02 64 6A 02 C8 63 18 18 R8.8#T7..dj..c..
00000030 0A 0A 0E 0E 01 1B 1D 0B 0B 11 13 01 00 00 00 00 ................
I 06:29:32 ImgBurn Version 2.1.0.0 started!
I 06:30:26 Source File Sectors: 2,259,460 (MODE1/2048)
I 06:30:26 Source File Size: 4,627,374,080 bytes
I 06:30:26 Destination Device: [1:2:0] _NEC DVD_RW ND-3500AG 2.1B (D:) (ATA)
I 06:30:26 Destination Media Type: DVD+R (Disc ID: OPTODISC-OR8-00) (Speeds: 2.4x, 4x, 6x, 8x)
I 06:30:27 Destination Media Sectors: 2,295,104
I 06:30:27 Write Mode: DVD
I 06:30:27 Write Type: DAO
I 06:30:27 Write Speed: 8x
I 06:30:27 Link Size: Auto
I 06:30:27 Test Mode: No
I 06:30:27 BURN-Proof: Enabled
I 06:40:13 Average Write Rate: 8,399 KB/s (6.1x) - Maximum Write Rate: 11,626 KB/s (8.4x)
I 06:40:13 Cycling Tray before Verify...
I 06:46:32 Average Verify Rate: 12,729 KB/s (9.2x) - Maximum Verify Rate: 20,768 KB/s (15.0x
Nero CD Speed Pic attached.. Not a great result from CD Speed..
Surface tested out 100% though.
~$1/25 pack with coupon. Search deal sites to find at this price.
Additional information:
Price: $1 Purchased from: S4T Date purchased: February 2007
Burnt with NEC ND-3500A at 8x using firmware 2.1b.
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media color is Silver.
Media text is n/a.
Media UPC/EAN code is 805060942716.
Authoring/Burning comments:
ImgBurn
Works fine on Apex AD-5131
Works fine on Yamakawa 238
Comments posted by speed from Netherlands, April 15, 2006:
Disk work fine with firmware Dee's 1.W7 rpc1
Best speed for cheap price :)
Average Write Rate: 12.878 KB/s (9.3x) - Maximum Write Rate: 17.809 KB/s (12.9x)depend on image type!
I 02:58:12 DVD Decrypter Version 3.5.4.0 started!
I 02:58:12 Microsoft Windows XP Media Center Edition (5.1, Build 2600 : Service Pack 2)
I 02:58:12 Initialising SPTI...
I 02:58:12 Searching for SCSI / ATAPI devices...
I 02:58:12 Found 3 DVD-ROMs and 1 DVD±RW!
I 02:58:34 Operation Started!
I 02:58:34 Source File: XXXXX.ISO
I 02:58:34 Source File Sectors: 2.285.880 (MODE1/2048)
I 02:58:34 Source File Size: 4.681.482.240 bytes
I 02:58:34 Source File Implementation Identifier: DVD Shrink
I 02:58:34 Destination Device: [2:1:0] _NEC DVD_RW ND-3540A 1.W7 (G:) (ATA)
I 02:58:34 Destination Media Type: DVD+R (Disc ID: OPTODISC-OR8-00) (Speeds: 4x; 6x; 8x; 12x; 16x)
I 02:58:34 Destination Media Sectors: 2.295.104
I 02:58:34 Write Mode: DVD
I 02:58:35 Write Type: SAO
I 02:58:35 Write Speed: MAX
I 02:58:35 Link Size: Auto
I 02:58:35 Test Mode: No
I 02:58:35 BURN-Proof: Enabled
I 02:58:35 Filling Buffer...
I 02:58:35 Writing LeadIn...
I 02:58:58 Writing Image...
I 03:04:54 Synchronising Cache...
I 03:04:55 Closing Track...
I 03:05:06 Finalising Disc...
I 03:05:22 Operation Successfully Completed! - Duration: 00:06:48
I 03:05:22 Average Write Rate: 12.878 KB/s (9.3x) - Maximum Write Rate: 17.809 KB/s (12.9x)
I 03:05:22 Cycling Tray before Verify...
I 03:05:37 Operation Started!
I 03:05:38 Source Device: [2:1:0] _NEC DVD_RW ND-3540A 1.W7 (G:) (ATA)
I 03:05:38 Source Media Type: DVD+R (Disc ID: OPTODISC-OR8-00) (Speeds: 4x; 6x; 8x; 12x; 16x)
I 03:05:38 Verifying Sectors...
I 03:10:53 Operation Successfully Completed! - Duration: 00:05:10
I 03:10:53 Average Verify Rate: 14.747 KB/s (10.6x) - Maximum Verify Rate: 21.289 KB/s (15.4x)
Price: $30 Purchased from: www.opus.nl Date purchased: February 2006
Burnt with NEC ND-3540A at 16x using firmware 1.W7 rpc1.
Console reliability is Good.
Media color is Yellow.
Media text is acro circle dvd+r/120min/1-8X.
Customer MediaCodeSpeedEdit change OPTODISCOR8-000 -> OPTODISCOR16-000.
Firmware:Dee's 1.W7 firmware.
DVD Decrypter Version 3.5.4.0 write speed max.
http://home.arcor.de/ala42/MCSE_Mirror/
http://liggydee.cdfreaks.com/page/3540/
Media image
Mediaimage
Click to enlarge
Comments posted by VinZ from Germany, January 29, 2006:
No comments
Price: $30 Purchased from: www.opusshop.de Date purchased: December 2005
Burnt with NEC ND-3520A at 6x using firmware 3.06.
Media text is Acro Circle.
Nero 6.6 & 7, dvd-decrypter, Roxio easy dvd creator.
Media image
Mediaimage
Click to enlarge
Comments posted by semi from Germany, October 24, 2005:
Changed my opinion. The quality is not good anymore. It used to be a very good media but now it's crap. My burner won't burn some of the disks, and sometimes the speed drops to 4x. I also have to verify the disks that did'nt burn at 8x since there's crc-errors and shit. Dsiks that burn at 8x are always fine though.
Burnt with Pioneer DVR-109 / DVR-A09 / DVR-509 at 8x using firmware 1.58.
Burning reliability is Mixed.
Media color is White Silver.
Media text is Acro Circle DVD+R 1-8X.
Comments posted by Radski from Netherlands, October 18, 2005:
Works fine on 8x
Price: $30 Purchased from: www.opus.nl Date purchased: October 2005
Burnt with AOpen DUW1608/ARR at 8x
Console reliability is Mixed.
Nero burning rom
Works fine on Daytek DVD-707
Comments posted by ca1 from Brazil, September 30, 2005:
It burns ok, but when I try to copy from it to another media (using DVD Shrink) I get this error "Erro nos dados (verificação Cíclica de Redundância" in Portuguse. With other medias everything goes ok.
Price: $0.7 Purchased from: Santa Ifigenia Date purchased: September 2005
Burnt with LG GSA-4163B at 8x using firmware A103.
PC reliability is Poor.
Media color is White.
Media text is +R 1~8x.
DVD Shrink 3.2 and Burned with Nero 6.6.0.13
Works fine on Panasonic DVD-A560
Media image
Mediaimage
Click to enlarge
Comments posted by Glenn from Canada, August 13, 2005:
Burned well at 8X used Sonic RecordNow
Price: $0.3 Purchased from: http://www.anitec.ca/ Date purchased: July 2005
Burnt with BenQ DW822A at 8x using firmware B3LC-2.
To be able to write and read these DVD's, I had to upgrade the BenQ DW822A firmware from B3IC to upgrade B3LC-2, see upgrade at
http://support.benq.com
Works fine on Philips DVP642
Comments posted by None OfYours from Greece, July 21, 2005:
No comments
Price: $0.4 Purchased from: www.plaisio.gr Date purchased: June 2005
Burnt with NEC ND-2500A at 8x using firmware 1.0A.
DVD reliability is Mixed.
Media color is Gray.
Media text is AcroCircle DVD+R 1-8x.
Media package type is Cake Box. Number of discs 10.
Roxio 7.1
Comments posted by semi from Sweden, May 22, 2005:
Just burned a few. Works fine. Can't go any higher than 8x, though.
Price: $0.4 Purchased from: www.opus.nl Date purchased: April 2005
Burnt with Pioneer DVR-109 / DVR-A09 / DVR-509 at 8x using firmware 1.40.
Media UPC/EAN code is 4710837109505.
DVDdecrypter, Nero 6.6
Works fine on JVC XV-N5
Media image
Mediaimage
Click to enlarge
9 user comments, Showing 1 to 9 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
