Acro Circle |
DVD+R |
4.7GB |
OPTODISCOR8 |
8x |
Plays on 6 DVD Players
Plays not on 0 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is Mixed
Read 9 comments (89592 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
08 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
00 00 00 00 00 00 03 4F 50 54 4F 44 49 53 43 4F .......OPTODISCO
52 38 00 38 23 54 37 09 02 64 6A 02 C8 63 18 18 R8.8#T7..dj..c..
0A 0A 0E 0E 01 1B 1D 0B 0B 11 13 01 00 00 00 00 ................
Media color and text:
White Acro Circle DVD+R 1-8X UPC/EAN Code:
4710837109505
9 user comments
Showing
1 to
9 comments |
Comments posted by jimboe from United States, February 15, 2007:
00000000 08 02 00 00 01 0F 02 00 00 03 00 00 00 25 7A 0F .............%z.
00000010 00 00 00 00 00 00 03 4F 50 54 4F 44 49 53 43 4F .......OPTODISCO
00000020 52 38 00 38 23 54 37 09 02 64 6A 02 C8 63 18 18 R8.8#T7..dj..c..
00000030 0A 0A 0E 0E 01 1B 1D 0B 0B 11 13 01 00 00 00 00 ................
I 06:29:32 ImgBurn Version 2.1.0.0 started!
I 06:30:26 Source File Sectors: 2,259,460 (MODE1/2048)
I 06:30:26 Source File Size: 4,627,374,080 bytes
I 06:30:26 Destination Device: [1:2:0] _NEC DVD_RW ND-3500AG 2.1B (D:) (ATA)
I 06:30:26 Destination Media Type: DVD+R (Disc ID: OPTODISC-OR8-00) (Speeds: 2.4x, 4x, 6x, 8x)
I 06:30:27 Destination Media Sectors: 2,295,104
I 06:30:27 Write Mode: DVD
I 06:30:27 Write Type: DAO
I 06:30:27 Write Speed: 8x
I 06:30:27 Link Size: Auto
I 06:30:27 Test Mode: No
I 06:30:27 BURN-Proof: Enabled
I 06:40:13 Average Write Rate: 8,399 KB/s (6.1x) - Maximum Write Rate: 11,626 KB/s (8.4x)
I 06:40:13 Cycling Tray before Verify...
I 06:46:32 Average Verify Rate: 12,729 KB/s (9.2x) - Maximum Verify Rate: 20,768 KB/s (15.0x
Nero CD Speed Pic attached.. Not a great result from CD Speed..
Surface tested out 100% though.
~$1/25 pack with coupon. Search deal sites to find at this price.
Additional information:
Price: $1 Purchased from: S4T Date purchased: February 2007 Burnt with NEC ND-3500A at 8x using firmware 2.1b. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is n/a. Media package type is Cake Box. Number of discs 25. Media UPC/EAN code is 805060942716. Authoring/Burning comments: ImgBurn Works fine on Apex AD-5131 Works fine on Yamakawa 238 |
Comments posted by speed from Netherlands, April 15, 2006:
Disk work fine with firmware Dee's 1.W7 rpc1
Best speed for cheap price :)
Average Write Rate: 12.878 KB/s (9.3x) - Maximum Write Rate: 17.809 KB/s (12.9x)depend on image type!
I 02:58:12 DVD Decrypter Version 3.5.4.0 started!
I 02:58:12 Microsoft Windows XP Media Center Edition (5.1, Build 2600 : Service Pack 2)
I 02:58:12 Initialising SPTI...
I 02:58:12 Searching for SCSI / ATAPI devices...
I 02:58:12 Found 3 DVD-ROMs and 1 DVD±RW!
I 02:58:34 Operation Started!
I 02:58:34 Source File: XXXXX.ISO
I 02:58:34 Source File Sectors: 2.285.880 (MODE1/2048)
I 02:58:34 Source File Size: 4.681.482.240 bytes
I 02:58:34 Source File Implementation Identifier: DVD Shrink
I 02:58:34 Destination Device: [2:1:0] _NEC DVD_RW ND-3540A 1.W7 (G:) (ATA)
I 02:58:34 Destination Media Type: DVD+R (Disc ID: OPTODISC-OR8-00) (Speeds: 4x; 6x; 8x; 12x; 16x)
I 02:58:34 Destination Media Sectors: 2.295.104
I 02:58:34 Write Mode: DVD
I 02:58:35 Write Type: SAO
I 02:58:35 Write Speed: MAX
I 02:58:35 Link Size: Auto
I 02:58:35 Test Mode: No
I 02:58:35 BURN-Proof: Enabled
I 02:58:35 Filling Buffer...
I 02:58:35 Writing LeadIn...
I 02:58:58 Writing Image...
I 03:04:54 Synchronising Cache...
I 03:04:55 Closing Track...
I 03:05:06 Finalising Disc...
I 03:05:22 Operation Successfully Completed! - Duration: 00:06:48
I 03:05:22 Average Write Rate: 12.878 KB/s (9.3x) - Maximum Write Rate: 17.809 KB/s (12.9x)
I 03:05:22 Cycling Tray before Verify...
I 03:05:37 Operation Started!
I 03:05:38 Source Device: [2:1:0] _NEC DVD_RW ND-3540A 1.W7 (G:) (ATA)
I 03:05:38 Source Media Type: DVD+R (Disc ID: OPTODISC-OR8-00) (Speeds: 4x; 6x; 8x; 12x; 16x)
I 03:05:38 Verifying Sectors...
I 03:10:53 Operation Successfully Completed! - Duration: 00:05:10
I 03:10:53 Average Verify Rate: 14.747 KB/s (10.6x) - Maximum Verify Rate: 21.289 KB/s (15.4x)
Price: $30 Purchased from: www.opus.nl Date purchased: February 2006 Burnt with NEC ND-3540A at 16x using firmware 1.W7 rpc1. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Yellow. Media text is acro circle dvd+r/120min/1-8X. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Customer MediaCodeSpeedEdit change OPTODISCOR8-000 -> OPTODISCOR16-000.
Firmware:Dee's 1.W7 firmware.
DVD Decrypter Version 3.5.4.0 write speed max.
http://home.arcor.de/ala42/MCSE_Mirror/
http://liggydee.cdfreaks.com/page/3540/
Media image
 Click to enlarge |
Comments posted by VinZ from Germany, January 29, 2006:
No comments
Price: $30 Purchased from: www.opusshop.de Date purchased: December 2005 Burnt with NEC ND-3520A at 6x using firmware 3.06. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Acro Circle. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Nero 6.6 & 7, dvd-decrypter, Roxio easy dvd creator. |
Media image
 Click to enlarge |
Comments posted by semi from Germany, October 24, 2005:
Changed my opinion. The quality is not good anymore. It used to be a very good media but now it's crap. My burner won't burn some of the disks, and sometimes the speed drops to 4x. I also have to verify the disks that did'nt burn at 8x since there's crc-errors and shit. Dsiks that burn at 8x are always fine though.
Burnt with Pioneer DVR-109 / DVR-A09 / DVR-509 at 8x using firmware 1.58. Burning reliability is Mixed. Media color is White Silver. Media text is Acro Circle DVD+R 1-8X. Media package type is Cake Box. Number of discs 25. |
Comments posted by Radski from Netherlands, October 18, 2005:
Works fine on 8x
Price: $30 Purchased from: www.opus.nl Date purchased: October 2005 Burnt with AOpen DUW1608/ARR at 8x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Mixed. Media color is Silver. Media text is Acro Circle. Media package type is Cake Box. Number of discs 100. Authoring/Burning comments: Nero burning rom Works fine on Daytek DVD-707 |
Comments posted by ca1 from Brazil, September 30, 2005:
It burns ok, but when I try to copy from it to another media (using DVD Shrink) I get this error "Erro nos dados (verificação Cíclica de Redundância" in Portuguse. With other medias everything goes ok.
Price: $0.7 Purchased from: Santa Ifigenia Date purchased: September 2005 Burnt with LG GSA-4163B at 8x using firmware A103. Burning reliability is Mixed. PC reliability is Poor. DVD reliability is Good. Media color is White. Media text is +R 1~8x. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: DVD Shrink 3.2 and Burned with Nero 6.6.0.13 Works fine on Panasonic DVD-A560 |
Media image
 Click to enlarge |
Comments posted by Glenn from Canada, August 13, 2005:
Burned well at 8X used Sonic RecordNow
Price: $0.3 Purchased from: http://www.anitec.ca/ Date purchased: July 2005 Burnt with BenQ DW822A at 8x using firmware B3LC-2. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Acro Circle DVD+R 1-8X. Media package type is Cake Box. Number of discs 25. Media UPC/EAN code is 805060942716. Authoring/Burning comments: To be able to write and read these DVD's, I had to upgrade the BenQ DW822A firmware from B3IC to upgrade B3LC-2, see upgrade at
http://support.benq.com Works fine on Philips DVP642 |
Comments posted by None OfYours from Greece, July 21, 2005:
No comments
Price: $0.4 Purchased from: www.plaisio.gr Date purchased: June 2005 Burnt with NEC ND-2500A at 8x using firmware 1.0A. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Mixed. Media color is Gray. Media text is AcroCircle DVD+R 1-8x. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: Roxio 7.1 |
Comments posted by semi from Sweden, May 22, 2005:
Just burned a few. Works fine. Can't go any higher than 8x, though.
Price: $0.4 Purchased from: www.opus.nl Date purchased: April 2005 Burnt with Pioneer DVR-109 / DVR-A09 / DVR-509 at 8x using firmware 1.40. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is White. Media text is Acro Circle DVD+R 1-8X. Media package type is Cake Box. Number of discs 25. Media UPC/EAN code is 4710837109505. Authoring/Burning comments: DVDdecrypter, Nero 6.6 Works fine on JVC XV-N5 |
Media image
 Click to enlarge |
9 user comments,
Showing
1 to
9 comments |
