White Label |
DVD-R |
4.7GB |
TDKG02000000 |
2x |
Plays on 15 DVD Players
Plays not on 4 DVD Players
Burn Reliability is Mixed
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is N/A
Read 17 comments (99885 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
00 42 00 00 01 40 C1 FD 9E D8 50 00 02 98 0C 13 .B...@....P.....
76 78 80 00 03 54 44 4B 47 30 32 00 04 30 30 30 vx...TDKG02..000
30 30 30 00 05 88 80 00 00 00 01 00 00 00 00 00 000.............
Media color and text:
UPC/EAN Code:
No
17 user comments
Showing
1 to
17 comments |
Comments posted by Frank Zippo from Norway, October 18, 2004:
No comments
Additional information:
Burnt with Plextor PX-708A at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Turquoise. Media text is White Label 2x. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Good burning, no coasters, playback ok. Does not work on Polaroid PDV-0700 |
Comments posted by tim from Other, October 30, 2003:
this media sux. got it at a computer how burned great on pioneer a04 but drive burned out. firmware update or something. hasnt been able to burn a thing that readable. anyone have any suggestions?
Price: $0.7 Purchased from: www.tri-statefairs.com Date purchased: August 2003 Burnt with Plextor PX-708A at 2x using firmware 1.01. Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media color is White. Media text is none. Authoring/Burning comments: nero and ez cd and dvd creator |
Comments posted by aybesea from Other, May 30, 2003:
These media are incredible. I have burned over 200 of them at 2X with no coasters. Very reliable.
Price: $1 Purchased from: www.qtccdr.com Date purchased: April 2003 Burnt with Sony DRU-500A at 2x using firmware 1.0f. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is White. Media text is nothing. Authoring/Burning comments: Authored with: ReelDVD, SpruceUp, TMPEGEnc Author
Burned with: RecordNow Max, Nero, Backup My PC
Copied with: DVDXCopy Works fine on Panasonic DVD-CV51 |
Comments posted by webstar from Other, March 01, 2003:
WHITE LABEL DVD-R 2X
Price: $1 Purchased from: www.bigpocket.cd.uk Burnt with Pioneer DVR-105 / DVR-A05 using firmware 1.21. Authoring/Burning comments: Media unusable. Not seen by my DVD-writer
I've buy 45 pack, all tested and unusable with my Pioneer A05/105 with 1.21 firmware
So if you a a Pioneer A05/105, buy another kind of DVD-R |
Comments posted by Jackson from Other, February 22, 2003:
Burns on 2 speed on my Toshiba SD-R5002. Great picture on video. Really very nice quality! Bought a 10 pack.
Price: $1 Purchased from: PC-dump Rai Building Amsterdam Date purchased: February 2003 Burnt with Toshiba SD-R5002 Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Authoring/Burning comments: Ripped and burned in ISO mode with DVD Decrypter. Works fine on Daytek DVD-707 Works fine on Philips DVD612 |
Comments posted by Dennis from Other, January 27, 2003:
Only -R brand so far to work in my Philips DVD950 (which refused to play Imation DVD-R).
Bought a spindle of 10 (blue discs) for data but decided to try one for video and it worked great.
Price: $0.9 Purchased from: www.opus.nl Date purchased: December 2002 Burnt with Sony DRU-500A at 1x Authoring/Burning comments: Nero 5.5.9.17
Authored with DVDMaestro Works fine on Philips DVD950 |
Comments posted by John from Other, December 06, 2002:
buying these disks is probably the best thing you can do providing you buy the correct ones.Dont buy the yellow 2X versions they are crap movie break up half way through,dvd players struggle with them and ps2 wont read them.Buy instead the 1X version normally blue i cant fault these disks for anything movies perfect compatability with standalone dvd players 99% also no problem at all if you back up your PS2 games.So if your patient enough to still burn at 1X these are the disks for you.
Comments posted by RetroSpeC from Other, December 02, 2002:
Bought a 10 pack spindle. Not pleased with media at all 5 out 5 worked on my standalone.
Also tried in a United player.
Comments posted by Boxingjunkie from Other, November 26, 2002:
I bought a pack of twenty and they all worked great. Then I purchased a pack of fifty. I have yet to make a coaster. They all worked great on my Sony S-360, my mothers Pioneer, and my friends Sony. Using a Pioneer A-04 to burn. Cant beat these disks for the price.
Boxingjunkie
Price: $1 Purchased from: Ebay Date purchased: October 2002 Burnt with Pioneer DVR-104 / DVR-A04 at 2x Authoring/Burning comments: Used SpruceUp to author
and Prassi to burn.
I havent ruined a disk yet Works fine on Sony DVP-S360 |
Comments posted by Ph@ntom from Other, November 23, 2002:
on AO4 works great for one hour then Freezes
Price: $0.5 Purchased from: WWW.Bigpockets.com Date purchased: September 2002 Burnt with Pioneer DVR-104 / DVR-A04 at 2x Authoring/Burning comments: Spruce Up & Instant CD/DVD 6 |
Comments posted by J. Rosado from Other, November 18, 2002:
Very good media. Tryed on several dvd-players and woks fine (sony, Mustek, Raite, etc..). Buyed 20, one ad some kind of dirty, but that was not a problem for my Pioneer recorder...
Price: $1.3 Purchased from: www.digitalpromo.co.uk Date purchased: November 2002 at 2x Authoring/Burning comments: Used Nero 5.5.9.17 |
Comments posted by videoed from Other, November 02, 2002:
The DO NOT play on my PlayStation 2 and some discs start jumping and pixelating after an hour of so of playing in my Saba DVD430SA. My DVD Liteon 163D DO NOT read them either! I have to use the recorder in orden to read them. Not very satisfied with them. I expected more compatibility
Purchased from: http://www.bigpockets.co.uk/ Date purchased: September 2002 Burnt with Pioneer DVR-103 / DVR-A03 at 2x Authoring/Burning comments: Nero 5.5.9.14 |
Comments posted by anonym from Other, October 31, 2002:
whitelabel dvd-rw works sony dvp-ns305 but it's not work sony dvp-S525D.
And when I test whitelabel DVD-r medias in sony model dvp-S525D, its repeat that disc but picture was bad and its snapping.
Price: $1.6 Purchased from: www.bigpockets.co.uk Date purchased: September 2002 Burnt with Pioneer DVR-104 / DVR-A04 at 1x Authoring/Burning comments: smartripper, ifoedit, nero Does not work on Sony DVP-S525D |
Comments posted by Ickey from Other, October 21, 2002:
works ok pioneer 525 and scan 2500 but would not work on Pioneer dcs 303
Price: $1 Purchased from: www.bigpockets.co.uk Date purchased: October 2002 Burnt with Pioneer DVR-104 / DVR-A04 at 2x Authoring/Burning comments: gearpro 3.02 |
Comments posted by tonymac from Other, October 04, 2002:
Check discs carefully. Had 3 lots of 20,first two perfect, last lot badly marked on rim. Above site takes returns, no quibble.
Price: $1.2 Purchased from: blankdiscshop.co.uk Date purchased: September 2002 at 1x Authoring/Burning comments: Maestro and Recordnowmax for perfect results. Works fine on Alba DVD108 Works fine on JVC XV-521BK |
Comments posted by Wayne from Other, October 03, 2002:
the best disks i have tried yet, out of a pack of 25,only one disk went blocky on me on my old pioneer dv-515
Date purchased: September 2002 at 2x Authoring/Burning comments: Nero 5.5.9.9 Works fine on Pioneer DV-515 |
Comments posted by Brian Wescombe from Other, September 24, 2002:
Cost about £1.00. Advertised as 2x but are apparently 4x discs for the new drives.
Price: $1.5 Purchased from: www.digitalpromo.co.uk Date purchased: September 2002 at 2x Authoring/Burning comments: Burned at 2x and worked perfectly on Pioneer 737, using Nero 5599 software. Works fine on Pioneer DV-737 |
17 user comments,
Showing
1 to
17 comments |
