Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
White Label DVD-R 4.7GB PRINCO...... 1x Plays on 3 DVD Players
Plays not on 0 DVD Players
Burn Reliability is Mixed
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is Poor
Read 5 comments
(42786 views)
Post comment
00 42 00 00 01 40 C1 FD 9E D8 50 00 02 98 0C 13 .B...@....P.....
76 78 80 00 03 50 52 49 4E 43 4F 00 04 00 00 00 vx...PRINCO.....
00 00 00 00 05 88 80 00 00 00 01 00 00 00 00 00 ................
Media color and text:
Green 4.7GB
UPC/EAN Code:
No
5 user comments
Showing 1 to 5 comments
Comments posted by Falcon from Other, December 13, 2003:
No comments
Additional information:
Burnt with Pioneer DVR-106 / DVR-A06 at 1x using firmware 1.07.
Burning reliability is Mixed.
PC reliability is Mixed.
DVD reliability is Good.
Console reliability is Mixed.
Media color is Green.
Media text is White Pabel.
Authoring/Burning comments:
Problem to read these DVD on my other DVD. The price is very low, but I am not sure that I am going to buy another 50 Pack.
Works fine on Pioneer DV-717
Comments posted by marco from Other, November 24, 2003:
Keep away from this disc or pay attention to the series.
The discs with white internal ring are all ok 1x/2x.
The discs with trasparent internal ring have many series totally crap.
The series are: p491... p493... p500...p370...and i think many others.
The only good trasparent series that are ok are: p490...
The seller or the builder know the problem and mix the good discs with the bad ones so is impossible to be sure that all discs are good.
Price: $0.6
Burnt with Pioneer DVR-105 / DVR-A05 at 1x
Burning reliability is Poor.
PC reliability is Poor.
DVD reliability is Poor.
Console reliability is Poor.
Media inkjet printable reliability is Poor.
Media text is WHITE LABEL 4.7 GB.
Comments posted by Leffe from Other, November 15, 2003:
These are marked as 1x media, and I only get the option of burning at 2x. This results in always lost data after finished burning.Some parts are unreadable after burning.
I use Nec DVDR 1300A with firmware 1.08.
Anyone have a solution to set down burningspeed to 1x ?
Burnt with NEC ND-1300A at 2x using firmware 1.08.
Media text is White Label 4.7Gb.
Used Nero6.0-Easycdcreator 6.0 and WinOncd 6.0
Comments posted by richard from Other, November 05, 2003:
the media is good and the price very attractive, you can burn at 1X but i read that with new firmwire (1.07) you can burn at 2X.
I try it and i can't burn at 2X. Anyway the media is good.
Price: $0.6 Date purchased: October 2003
Burning reliability is Good.
PC reliability is Good.
Media text is white label 4,7gb.
nero 6
Works fine on Thomson DTH-500
Comments posted by V60i from Other, November 03, 2003:
Disc are a light green, and have white label writen on them. The title white label is split into 2 boxes, the first saying white in a black box, and the second part Label is in a white box.. Cost £46.00 for 100 at a computer fair in uk. No error so far and have copied approx 10 films so far. Sold as 1 speed but they are recording at 2 speed.
Price: $1 Purchased from: computer fair Kettering Northants, UK £46.00 for 100 discs Date purchased: November 2003
Burnt with Pioneer DVR-106 / DVR-A06 at 2x using firmware 1.07 (multi-Region).
Media text is 4.7GB.
DVD Shrink 3.0 Beta 5
Works fine on Samsung DVD-V1000
5 user comments, Showing 1 to 5 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
