Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Ultra DVD+R 4.7GB CMC MAG.F01 4x Plays on 5 DVD Players
Plays not on 1 DVD Players
Burn Reliability is Mixed
DVD Reliability is Good
PC Reliability is Good
Console Reliability is N/A
Read 8 comments
(61626 views)
Post comment
08 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
00 00 00 00 00 00 01 43 4D 43 20 4D 41 47 00 46 .......CMC MAG.F
30 31 00 38 23 54 37 10 02 48 71 02 8C 69 16 16 01.8#T7..Hq..i..
0B 0B 0A 0A 01 1D 1E 0C 0C 12 12 01 00 00 00 00 ................
Media color and text:
Silver Blank. No text printed.
UPC/EAN Code:
022769311005
8 user comments
Showing 1 to 8 comments
Comments posted by Wally from Sweden, April 13, 2004:
No comments
Additional information:
Purchased from: www.tigerdirect.ca Date purchased: March 2004
Burnt with HI-Val HDVDRW4D at 4x
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media color is Silver.
Media text is No text printed.
Media UPC/EAN code is 022769311005.
Authoring/Burning comments:
Elby CloneDVD 2.0
Comments posted by lucasiso from Canada, April 02, 2004:
No comments
Purchased from: tigerdirect.ca Date purchased: March 2004
Burnt with Plextor PX-708A at 8x
Media color is Yellow.
Media text is ultra_dvd+.
Media made in Austria.
nero6 firmwear 1.06
Comments posted by Cozman from Canada, March 19, 2004:
No problems burning with HP 300i at 4x.
Have used over 7 spindles of these.
Price: $1.1 Purchased from: www.tigerdirect.com Date purchased: December 2003
Burnt with HP DVD300i at 4x
DVD reliability is Mixed.
Media color is Purple.
Media text is None.
DVD Shrink and Nero 6.0
Works fine on Panasonic DVD-RP56
Comments posted by Clark76 from United States, March 19, 2004:
I have had no coasters in about 25 discs and my friend is using a Nec ND-1300a and has had no problems
Price: $0.6 Purchased from: www.tigerdirect.com
Burnt with NEC ND-2500A at 4x using firmware 1.60.
Media text is N/A.
DVD Decryptor
DVD Shrink
Nero 5.5
Works fine on Emerson EWD-7003
Comments posted by Cozman from United States, March 18, 2004:
Burned over 100 DVD+R with maybe one defect.
Purchased from: www.tigerdirect.ca Date purchased: December 2003
Media text is None.
Nero 6.0
Works fine on Panasonic DVD-A120
Comments posted by Mark from Canada, February 20, 2004:
Nothing but bad luck with this media in my writer, and my player. My Dad's TDK loveds this media. Wierd.
Purchased from: www.tigerdirect.ca Date purchased: February 2004
Burnt with OptoRite DD0401 at 2.4x using firmware 130.e.
Burning reliability is Poor.
PC reliability is Mixed.
DVD reliability is Poor.
Media text is no text.
Authored with DVDshrink and Burned with Nero5 and Nero6 Ultra
Does not work on Panasonic DVD-S35
Comments posted by Alex from Canada, February 20, 2004:
This is a follow-up to my review. I started using the second spindle of these disks once I found out that they where 2.4X and they passed the written step with Nero at that speed but every second disk failed the VERIFY stage.
I called www.tigerdirect.ca and they said they couldn't do anything for me because it had been over 30 days since I had purcased the product. Then I called the manufacturer at www.Ultraproducts.com to complain about the fact that I had 20 coasters out of 50 disks and they told me that even though there was a one year warranty that they couldn't do anything for me and that it was the Pioneer A06 drive that was at fault. The manager, Mike, said the media was 4X but that the Pioneer did not read the media correctly. I pointed out that DVDinfoPRO read the media Id and that the media code was sparse indicating that the disks were not of good quality. He said these disks were made by BMI and that that no other people had complained about this media and that he himself had printed 250-300 disks with them and had only a 5% failure rate (15 disks) due to power failures, etc.
According to the manager I should have complained as soon as I started getting bad disks. I replied that I didn't know at first what the problem was and that I had started using them recently. I also pointed out that I was able to burn Hypermedia 4X without any problems using the A06 drive.
Price: $30 Purchased from: www.tigerdirect.ca Date purchased: December 2003
Burnt with Pioneer DVR-106 / DVR-A06 at 2.4x using firmware 1.07.
Media text is None.
Nero 5.5.10.54
Works fine on Apex AD-1225
Works fine on Apex AD-660
Comments posted by Alex from Canada, February 07, 2004:
Hit or miss. Out of 25 I think 15 have worked. It is rated 4X but DVDinfoPro says they are 2.4X. I DO NOT RECOMMEND PURCHASING THEM. Here is the info:
Media Information
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID CMC MAG F01
Format Capacity Not Formatted
Free Blocks 405405696
Free Capacity 4.38GB(4.70GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed 2.4x 3324KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Data area starting sector 30000h
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
Price: $20 Purchased from: for 25 cackebox at WWW.TIGERDIRECT.CA BUNDLED WITH DVDXCOPY PLATINUM. Date purchased: December 2003
Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.07.
Media text is Blank. No text printed..
Ulead Movie Factory 2, Nero 5.5.10.54, DVDXCOPY PLatinum 0.3.2.1
8 user comments, Showing 1 to 8 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
