SW Technology |
DVD-R |
4.7GB |
OPTODISCK001 |
1x |
Plays on 16 DVD Players
Plays not on 3 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is Good
Read 14 comments (114135 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
00 42 00 00 01 40 C1 FD 9E D8 50 00 02 7A 0D 12 .B...@....P..z..
87 88 80 00 03 4F 50 54 4F 44 49 00 04 53 43 4B .....OPTODI..SCK
30 30 31 00 05 00 00 00 00 00 01 00 00 00 00 00 001.............
or
00 6A 00 00 01 40 C1 FD 9E D8 50 00 02 7A 0D 11 .j...@....P..z..
88 88 70 00 03 4F 50 54 4F 44 49 00 04 53 43 4B ..p..OPTODI..SCK
30 30 31 00 05 88 80 00 00 00 01 00 00 00 00 00 001.............
Media color and text:
Silver Gray SW Technology DVD-R For General 120 min 4.7 GB UPC/EAN Code:
No
14 user comments
Showing
1 to
14 comments |
Comments posted by Coca from Sweden, March 05, 2004:
No comments
Additional information:
Burnt with NEC ND-1300A at 2.4x using firmware 1.9. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is SW Tech. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: Some coasters but when they pass it´s 100% playback on PC and DVD. |
Comments posted by Mats Bernhardsson from Sweden, January 23, 2004:
No problems with burning took 28 minits to finish used auto speed.
Price: $1.3 Purchased from: www.mycom.se Date purchased: January 2004 Burnt with NEC ND-2500A at 2x using firmware 1.06. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is SW Technology DVD-R For General 120 min 4,7 GB. Authoring/Burning comments: anydvd clonedvd Works fine on Pioneer DV-340 |
Comments posted by Bo L from Other, January 04, 2004:
The only budget disk found that works with settop Panasonic DMR-HS2 (most selective burner encountered; burns only at 1x, but reads what was burnt at 4x in the PC)
Price: $0.8 Date purchased: January 2004 Burnt with Panasonic DMR-HS2 at 1x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is SW Technology DVD-R For General. |
Comments posted by mkidol from Other, December 30, 2003:
No comments
Burnt with TX Galaxy Dual 4x at 1x Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Silver. Media text is SW Technology DVD-R for General 4.7GB 120min. Does not work on Thomson DTH-195E |
Comments posted by miko from Other, December 18, 2003:
This is one of the best disks (-R)around for NEC ND-1300 if you have firmware 1.07 or LOWER. Warning DO NOT USE firmware 1.08 or 1.09. The disks are unreadable on many dvd players.
Purchased from: www.jmedata.se Date purchased: October 2003 Burnt with NEC ND-1300A at 2x using firmware 1.07. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media inkjet printable reliability is Good. Media color is Silver. Media text is SW Technology. Authoring/Burning comments: CopyDVD, Nero 5.5 Works fine on Mustek DVD-PL207 Works fine on Mustek DVD-V300 Works fine on Pioneer DV-525 Works fine on Pioneer DV-535 Works fine on Pioneer DV-565A-S |
Comments posted by Rutger from Other, November 19, 2003:
Some problems with burning in 2X.
Burnt with Pioneer DVR-103 / DVR-A03 at 1x using firmware 2.0. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is SW Technology DVD-R for general 120 min 4.7GB. Authoring/Burning comments: Nero 5 and Nero 6. Works fine on D-I-K DVD 090 Works fine on Denon DVD-2500 Works fine on Pioneer DV-757Ai |
Comments posted by guttergod from Other, November 11, 2003:
Burns data at 2x fine. DVD video is crappy even when watched on the computer DVD-ROM. So it probably really is for data only as it says.
Burnt with NEC ND-1300A at 2x using firmware 1.08. Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Silver. Media text is SW Technology DVD-R for general 120 min 4.7GB DVD R for data title date archove no. Authoring/Burning comments: Nero and Copy2DVD Does not work on JVC XV-S300BK Does not work on Onkyo DV-S555 |
Comments posted by Karl from Other, September 26, 2003:
Slightly different Media code
00000000 00 42 00 00 01 40 C1 FD 9E D8 50 00 02 7A 0D 11 .B...@....P..z..
00000010 88 88 70 00 03 4F 50 54 4F 44 49 00 04 53 43 4B ..p..OPTODI..SCK
00000020 30 30 31 00 05 88 80 00 00 00 01 00 00 00 00 00 001.............
Price: $1.2 Purchased from: www.mycom.se Date purchased: September 2003 Burnt with Freecom DVD+RW/+R Internal at 2x using firmware 1.31. Burning reliability is Good. PC reliability is Good. Media color is Silver. Media text is SW Technology DVD-R For General. Authoring/Burning comments: Nero 6.0.0.15
The Freecom burner (NEC-1300A) will only burn these disks at 2x (not 1x).
All disk have good data. However DVDInfo tests shows a marginal behavior at the end of all the disks. On three positions white codes are shown, which means that the data was OK upon the second read. I do not know if this has any implications for the long time stability of the discs. Used 9 discs for Data backup so far, all with the same results. |
Comments posted by darkshippo from Other, September 24, 2003:
I've tried the media at 1x and it burns fine. Since the release of the 2x4all firmware. I've burnt it at 2x, PI errors has increased in the beginning of media, but PI errors in the end of the media has decreased.
Price: $1 Purchased from: www.mycom.se Date purchased: September 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 2x using firmware 1.07 and 1.07 2x4all. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is SW Technology DVD-R 120min. |
Comments posted by sliver from Other, September 08, 2003:
No comments
Price: $0.9 Purchased from: www.mycom.se Date purchased: September 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 1x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is SW Technology DVD-R 4,7GB. Authoring/Burning comments: Stomp Record Max 4.5 Works fine on Pioneer DV-454 |
Comments posted by buRRo from Other, August 15, 2003:
No coasters, but dont hold the information properly .. worked in both of my stationary DVDs and computer players/writers(pioneer-DVD535 and Technika-DVD2020,nec1300, liteon) right after burn.
When i checked the media again after 4days they didnt work properly in any of my stationary or computer-based players/ writers.
5 SW-discs out of 6 burned had problems, and _yes_ i treat my discs ok. (its not greasyfingers or scratches)
Price: $0.9 Purchased from: www.Dataprince.se Date purchased: August 2003 Burnt with NEC ND-1300A at 2x using firmware 1.05. Burning reliability is Good. PC reliability is Poor. DVD reliability is Poor. Media color is Silver. Media text is SW-technology , DVD-R for General. Authoring/Burning comments: Nero 5.5 |
Comments posted by Tam_Libanes from Other, June 27, 2003:
No comments
Price: $1.3 Purchased from: www.jmedata.se Burnt with NEC ND-1300A at 2x using firmware 1.05. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Gray Black None. Media text is DVD-R For General 4.7GB 120min. Works fine on Philips DVD733 Works fine on Pioneer DV-2650 Works fine on Samsung DVD-S324 |
Comments posted by nenne from Other, June 22, 2003:
No comments
Price: $1.8 Purchased from: $1.8 from http://www.jmedata.se, June 2003 Burnt with NEC ND-1300A at 2x using firmware 1.05. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Silver Gray SW Technology DVD-R For General 120 min 4.7 GB. Authoring/Burning comments: ImgTool + Nero 5.5.10.28 Works fine on Sony DAV-S300 |
Comments posted by scandic from Other, June 21, 2003:
No comments
Price: $1.8 Purchased from: http://www.jmedata.se Date purchased: June 2003 Burnt with NEC ND-1300A at 2x using firmware 1.05. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver Gray. Media text is SW Technology DVD-R For General 120 min 4.7 GB. Authoring/Burning comments: DVD Decrypter + ImgTool + Nero 5.5.10.28 Works fine on Philips DVD711 Works fine on Philips DVDR890 |
14 user comments,
Showing
1 to
14 comments |
