Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Sky DVD-R 4.7GB MXL RG01.... 2x Plays on 5 DVD Players
Plays not on 2 DVD Players
Burn Reliability is Good
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is Mixed
Read 9 comments
(59618 views)
Post comment
00 42 00 00 01 40 C1 FD 9E D8 50 00 02 58 0E 11 .B...@....P..X..
98 99 80 00 03 4D 58 4C 20 52 47 00 04 30 31 00 .....MXL RG..01.
00 00 00 00 05 88 80 00 00 00 01 00 00 00 00 00 ................
Media color and text:
Silver Blank, but has IFPI GZ04 stamped on the hub
UPC/EAN Code:
No
9 user comments
Showing 1 to 9 comments
Comments posted by Jon from United States, April 03, 2004:
Inexpensive Media. I bought it from YesBuy without any problems.
Additional information:
Price: $0.6 Purchased from: Yesbuy.com Date purchased: December 2003
Burnt with Lite-On LDW-411S/451S at 2x
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media color is Silver.
Media text is IFPI GZ06.
Media package type is Shrink Wrapped. Number of discs 100.
Authoring/Burning comments:
Nero, Sonic MyDVD. The only problem I've ran into is that you have to set the Nero Recode to 4425Mb to make the disk close properly.
Works fine on Mintek DVD-1600
Comments posted by Bruno from Portugal, January 28, 2004:
Doesn't work on Iomega Dual DVD+/-
Price: $1 Purchased from: Portugal Date purchased: January 2004
Burnt with Iomega Dual DVD±RW at 2x
Burning reliability is Poor.
Media color is Gray.
Media text is Sky 2x speed.
Nero
Comments posted by golem from Other, December 14, 2003:
It burns solidly at 2x using the SD-R5002 even when leaving as little as 100-300mb/s free space. In as far as the Apex not liking the disks, well, the Apex seems not to like 95% of the disks I feed it. Even retail DVDs will fail in that unit which is the reason I will not hold that against the media.
Price: $0.6 Purchased from: www.yesbuy.net Date purchased: August 2003
Burnt with Toshiba SD-R5002 at 2x using firmware X032.
Media text is IFPI GZ05.
SpruceUp (author)
DVD Decrypter (burn)
DVD Shrink 3.0 (author)
Nero 5.5.10.0 (burn)
Works fine on Cyberhome CH-DVD 500
Does not work on Apex AD-1201
Comments posted by SpCmNsPfF from Other, October 10, 2003:
Works fine in ps2, xbox, and DVD player burned till the very end. 1x burned at 2x working so far 3 for 3.
Price: $0.6 Purchased from: www.yesbuy.net Date purchased: October 2003
Burnt with Pioneer DVR-105 / DVR-A05 at 2x using firmware 1.33.
Console reliability is Good.
Media text is Unbranded.
RecordNow DX
Works fine on Pioneer DV-434
Comments posted by Todd from Other, October 03, 2003:
Junk, 45 minutes into DVD locks up
Burnt with Sony DRU-500A at 2x using firmware 2.0f.
Burning reliability is Mixed.
DVD reliability is Poor.
Media color is Blue.
Media text is Sky 2x.
Nero
Does not work on Memorex MVD-2025
Comments posted by Andy from Other, September 30, 2003:
Burns so so had two bad burns (one on each) on two burns I try so far. On the ones that burn ok, the movie would be mess up around 45 - 50 minute area. Guess I will use it as backup instead of video
Price: $0.6 Purchased from: Yesbuy.com Date purchased: September 2003
Burnt with Pioneer DVR-104 / DVR-A04 at 2x
PC reliability is Poor.
Media text is Blank.
DVD decryptor
Works fine on Pioneer DV-525
Comments posted by mrshade from Other, September 09, 2003:
these media are the worst pieces of crap ever.. i bought a 50 spindle from yesbuy.net or top of the fact they gave me the runaround about shipping the media out (took 2.5 weeks) the media burn great at 2x but they dont work in ANY dvd player/rom.. i tried 15 different dvd players/rom and none worked.. they all did the thing where the laser hits the end of its track and keeps hitting because it thinks there is more media.. only after leaving the media in the only player that it sort-of worked in (the PS2) for about 20 minutes it loaded the title menu of the dvd but wouldnt play the movie.. you could navigate around the main menu though.. Too many dvd players it didn't work on i cant remember all thier model numbers... Worst ever.. Id stay away from them if you know whats good for you..
Burnt with Sony DRU-500AX at 2x using firmware 2.0f.
Console reliability is Poor.
Media text is n/a.
dvd decrypter
dvd shrink
stomp! record now max
Comments posted by amp from Other, August 13, 2003:
Cheap Media but works great.
Burnt with Iomega Dual DVD±RW at 2x using firmware 1.20h.
Media text is Sky DVD-R 4.7 Gb DVD-R475.
Clone DVD with Any DVD
Comments posted by perinator from Other, August 09, 2003:
Consistant burn at 2X, no problems at all.
Price: $1 Purchased from: www.yesbuy.net Date purchased: August 2003
Burnt with Pioneer DVR-105 / DVR-A05 at 2x using firmware 1.21.
Media text is Blank, but has IFPI GZ04 stamped on the hub.
dvdxcopy express
Works fine on Philips MX3700D
9 user comments, Showing 1 to 9 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
