Sky |
DVD-R |
4.7GB |
MXL RG01.... |
2x |
Plays on 5 DVD Players
Plays not on 2 DVD Players
Burn Reliability is Good
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is Mixed
Read 9 comments (59617 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
00 42 00 00 01 40 C1 FD 9E D8 50 00 02 58 0E 11 .B...@....P..X..
98 99 80 00 03 4D 58 4C 20 52 47 00 04 30 31 00 .....MXL RG..01.
00 00 00 00 05 88 80 00 00 00 01 00 00 00 00 00 ................
Media color and text:
Silver Blank, but has IFPI GZ04 stamped on the hub UPC/EAN Code:
No
9 user comments
Showing
1 to
9 comments |
Comments posted by Jon from United States, April 03, 2004:
Inexpensive Media. I bought it from YesBuy without any problems.
Additional information:
Price: $0.6 Purchased from: Yesbuy.com Date purchased: December 2003 Burnt with Lite-On LDW-411S/451S at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is IFPI GZ06. Media package type is Shrink Wrapped. Number of discs 100. Authoring/Burning comments: Nero, Sonic MyDVD. The only problem I've ran into is that you have to set the Nero Recode to 4425Mb to make the disk close properly. Works fine on Mintek DVD-1600 |
Comments posted by Bruno from Portugal, January 28, 2004:
Doesn't work on Iomega Dual DVD+/-
Price: $1 Purchased from: Portugal Date purchased: January 2004 Burnt with Iomega Dual DVD±RW at 2x Burning reliability is Poor. Media color is Gray. Media text is Sky 2x speed. Authoring/Burning comments: Nero |
Comments posted by golem from Other, December 14, 2003:
It burns solidly at 2x using the SD-R5002 even when leaving as little as 100-300mb/s free space. In as far as the Apex not liking the disks, well, the Apex seems not to like 95% of the disks I feed it. Even retail DVDs will fail in that unit which is the reason I will not hold that against the media.
Price: $0.6 Purchased from: www.yesbuy.net Date purchased: August 2003 Burnt with Toshiba SD-R5002 at 2x using firmware X032. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is IFPI GZ05. Authoring/Burning comments: SpruceUp (author)
DVD Decrypter (burn)
DVD Shrink 3.0 (author)
Nero 5.5.10.0 (burn) Works fine on Cyberhome CH-DVD 500 Does not work on Apex AD-1201 |
Comments posted by SpCmNsPfF from Other, October 10, 2003:
Works fine in ps2, xbox, and DVD player burned till the very end. 1x burned at 2x working so far 3 for 3.
Price: $0.6 Purchased from: www.yesbuy.net Date purchased: October 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 2x using firmware 1.33. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Unbranded. Authoring/Burning comments: RecordNow DX Works fine on Pioneer DV-434 |
Comments posted by Todd from Other, October 03, 2003:
Junk, 45 minutes into DVD locks up
Burnt with Sony DRU-500A at 2x using firmware 2.0f. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Poor. Media color is Blue. Media text is Sky 2x. Authoring/Burning comments: Nero Does not work on Memorex MVD-2025 |
Comments posted by Andy from Other, September 30, 2003:
Burns so so had two bad burns (one on each) on two burns I try so far. On the ones that burn ok, the movie would be mess up around 45 - 50 minute area. Guess I will use it as backup instead of video
Price: $0.6 Purchased from: Yesbuy.com Date purchased: September 2003 Burnt with Pioneer DVR-104 / DVR-A04 at 2x Burning reliability is Mixed. PC reliability is Poor. DVD reliability is Poor. Media color is Silver. Media text is Blank. Authoring/Burning comments: DVD decryptor Works fine on Pioneer DV-525 |
Comments posted by mrshade from Other, September 09, 2003:
these media are the worst pieces of crap ever.. i bought a 50 spindle from yesbuy.net or top of the fact they gave me the runaround about shipping the media out (took 2.5 weeks) the media burn great at 2x but they dont work in ANY dvd player/rom.. i tried 15 different dvd players/rom and none worked.. they all did the thing where the laser hits the end of its track and keeps hitting because it thinks there is more media.. only after leaving the media in the only player that it sort-of worked in (the PS2) for about 20 minutes it loaded the title menu of the dvd but wouldnt play the movie.. you could navigate around the main menu though.. Too many dvd players it didn't work on i cant remember all thier model numbers... Worst ever.. Id stay away from them if you know whats good for you..
Price: $0.6 Purchased from: www.yesbuy.net Date purchased: August 2003 Burnt with Sony DRU-500AX at 2x using firmware 2.0f. Burning reliability is Good. PC reliability is Poor. DVD reliability is Poor. Console reliability is Poor. Media color is Silver. Media text is n/a. Authoring/Burning comments: dvd decrypter
dvd shrink
stomp! record now max |
Comments posted by amp from Other, August 13, 2003:
Cheap Media but works great.
Burnt with Iomega Dual DVD±RW at 2x using firmware 1.20h. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Sky DVD-R 4.7 Gb DVD-R475. Authoring/Burning comments: Clone DVD with Any DVD Works fine on Pioneer DV-525 |
Comments posted by perinator from Other, August 09, 2003:
Consistant burn at 2X, no problems at all.
Price: $1 Purchased from: www.yesbuy.net Date purchased: August 2003 Burnt with Pioneer DVR-105 / DVR-A05 at 2x using firmware 1.21. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Blank, but has IFPI GZ04 stamped on the hub. Authoring/Burning comments: dvdxcopy express Works fine on Philips MX3700D |
9 user comments,
Showing
1 to
9 comments |
