Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Philips DVD+R 8.5GB RICOHJPND01 8x Plays on 3 DVD Players
Plays not on 0 DVD Players
Burn Reliability is Poor
DVD Reliability is Good
PC Reliability is Good
Console Reliability is N/A
Read 4 comments
(56069 views)
Post comment
00 00 00 00 E1 0F 32 10 00 03 00 00 00 FC FF FF ......2.........
00 22 D7 FF 00 00 03 52 49 43 4F 48 4A 50 4E 44 .".....RICOHJPND
30 31 43 40 25 25 37 10 00 2C 6C 00 2C 6C 20 1F 01C@%%7..,l.,l .
0C 0C 14 14 02 01 01 20 00 20 1F 0C 0C 14 14 02 ....... . ......
Media color and text:
Silver Philips Double Layer DVD+R 8.5GB 240min 8x Speed
UPC/EAN Code:
710895992114
4 user comments
Showing 1 to 4 comments
Comments posted by BomberHarris from Russian Federation, February 06, 2008:
No comments
Additional information:
Purchased from: www.ret.ru Date purchased: January 2008
Burnt with Pioneer DVR-111D / DVR-710 at 2.4x using firmware 1.29.
Burning reliability is Mixed.
PC reliability is Good.
DVD reliability is Good.
Media color is Silver.
Media text is Philips 8.5GB DVD+R DL 2.4x speed.
Media package type is Cake Box. Number of discs 10.
Authoring/Burning comments:
Burned with Nero 8.2.8.0
Works fine on Philips DVD720
Comments posted by Philips from Germany, July 11, 2007:
I had much problems to burn this dvd. I had burn one dvd with 2.4x after i restarted the burning process on clonedvd2 3 times but all the others did not start after 10 restarts. The programm is always saying bad oder wrong medium.
Purchased from: - Date purchased: December -0001
Burnt with LG GSA-H42L at 2.4x using firmware SL01.
Burning reliability is Poor.
PC reliability is Mixed.
Media text is Philips Doubl Layer DVD+R 2.4x certified speed.
Media made in India.
Media UPC/EAN code is -.
Nero 6
CloneDVD2
Comments posted by Henry from Netherlands, July 05, 2007:
Although identified as RICOHJPN 8X (Identical Media Code), Philips sells them as 2.4X only!
Price is for 5-pack, Euro 26,99
Even at this speed it won't burn the second layer!
Price: $30 Purchased from: Dixons Date purchased: December -0001
Burnt with Philips DVD8631 at 2.4x using firmware 2X16.
Media text is PHILIPS RW DVD+R DL DOUBLE LAYER DVD+R 8.5 GB 240 MIN 2.4XSPEED.
Media package type is Jewel Case. Number of discs 5.
Media UPC/EAN code is `9082 100 04656.
Nero, ImgBurn,
Media image
Mediaimage
Click to enlarge
Comments posted by Crazyjoe from Austria, December 19, 2006:
Labeled as 8x, Burner recognizes it as 4x but actually burns it at 2,4x
Date purchased: December 2006
Burnt with LG GSA-4167B at 4x using firmware DL13.
Media text is Philips Double Layer DVD+R 8.5GB 240min 8x Speed.
Media package type is Jewel Case. Number of discs 1.
Media UPC/EAN code is 710895992114.
Authored with Scenarist Pro 2.5
Burned with DVD Decrypter 3.5.4.0
As stated before burner uses only 2,4x although setting is 4x.
Works fine on Cyberhome AD-L 528
Works fine on Pioneer DV-525
4 user comments, Showing 1 to 4 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
