Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Mitsubishi DVD-R 4.7GB MCC 01RG20 4x Plays on 3 DVD Players
Plays not on 0 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is N/A
Read 3 comments
(34685 views)
Post comment
00 00 00 00 01 40 c1 fd 9e d8 52 00 02 87 0d 11 .....@....R.....
66 78 80 00 03 4d 43 43 20 30 31 00 04 52 47 32 fx...MCC 01..RG2
30 20 20 00 05 a8 82 00 20 00 02 00 06 09 11 11 0 ..... .......
Media color and text:
Silver Mitsubishi Chemical Corporation 4.7GB Ver.2.0/4X DVD-R For Data
UPC/EAN Code:
No info
3 user comments
Showing 1 to 3 comments
Comments posted by Brad from New Zealand, January 13, 2005:
Great media, only ever had one coaster, which was due to an error by the burning software. Picked them up at NZ$12 for a pack of 5.
Additional information:
Burnt with Teac DV-W24E at 4x
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media color is Silver.
Media text is Mitsubishi Chemical Corporation 4.7GB Ver.2.0/4X DVD-R For Data.
Media package type is Jewel Case. Number of discs 5.
Works fine on Sony DAV-S500
Comments posted by IonNuke from United States, June 05, 2004:
Model Number DHR47U1
Writes perfectly @ 4x speed. Alcohol120% reports back average writing speed of 4.2x and max speed of 4.5x
Price: $4 Purchased from: Aurora chain store in Taipei, Taiwan Date purchased: May 2004
Burnt with Lite-On LDW-811S/851S at 4x using firmware HS0K.
Media text is For Data MITSUBISHI CHEMICAL CORPORATION 4.7GB Ver.2.0/4x DVD-R.
Media package type is Jewel Case. Number of discs 1.
Media made in Singapore.
Media UPC/EAN code is 4991348044398.
Authoring/Burning comments:
Alcohol120% v1.4.8 Build 1222 for image archival
Media image
Mediaimage
Click to enlarge
Comments posted by bradlundgren from Australia, May 17, 2004:
Only one coaster made with these and it was user error. Only problem found so far is Im paying $2.50AU a disc and have seen them as much as 5 for $23! I usually write at 4X but have written at 8X. Highly recommended
Burnt with NEC ND-2500A at 4x using firmware 1.07beta9a.
Media made in Taiwan.
nero and dvd shrink
Works fine on Digitor G1605
Works fine on Panasonic DVD-CV52
3 user comments, Showing 1 to 3 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
