Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Memorex DVD+R 4.7GB PHILIPS.C16 16x Plays on 1 DVD Players
Plays not on 0 DVD Players
Burn Reliability is Mixed
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is Poor
Read 6 comments
(54453 views)
Post comment
00 00 00 00 00 00 07 50 48 49 4c 49 50 53 00 43 .......PHILIPS.C
31 36 01 38 23 54 37 12 02 5a 6e 02 b0 68 16 16 16.8#T7..Zn..h..
0b 0b 0a 0a 01 1d 1e 0c 0c 12 12 01 00 00 00 00 ................
Media color and text:
Silver memorex
UPC/EAN Code:
034707056114
6 user comments
Showing 1 to 6 comments
Comments posted by VinZ from Netherlands, April 09, 2007:
According to an inside source @ Philips these discs require a very high power burning laser. Only 2 writers have this and this media was delivered with these writers. Due to a management error these dvd's came on the open market.
Burn at a low speed (4x max or lower with a 16x writer) to avoid making coasters
->AVOID<-
Additional information:
Date purchased: December -0001
Burnt with NEC ND-3500A at 6x
Burning reliability is Poor.
PC reliability is Poor.
DVD reliability is Poor.
Console reliability is Poor.
Media color is Silver.
Media text is Memorex.
Media package type is Jewel Case. Number of discs 5.
Media made in Germany.
Comments posted by VinZ from Germany, September 16, 2006:
Unique Disc Identifier : [DVD+R:PHILIPS-C16-001]
Disc & Book Type : [DVD+R] - [DVD-ROM]
Manufacturer Name : [Philips]
Manufacturer ID : [PHILIPS]
Media Type ID : [C16]
Product Revision : [001]
Blank Disc Capacity : [2,295,104 Sectors = 4.70 GB (4.38 GiB)]
Recording Speeds : [1x-2.4x , 4x , 6x-8x , 6x-16x]
[ DVD Identifier V4.2.0 - http://DVD.Identifier.CDfreaks.com ]
Purchased from: www.ddvd.info Date purchased: December 2005
Burnt with NEC ND-3520A at 4x using firmware 3.06.
Burning reliability is Mixed.
PC reliability is Mixed.
Media text is Memorex -is it live or is it memorex?.
Authoring/Burning comments:
dvddecryptor 3.5.4.0
Media image
Mediaimage
Click to enlarge
Comments posted by Redshift21 from United States, November 25, 2005:
No comments
Price: $0.7 Purchased from: Best Buy Date purchased: April 2005
Burnt with NEC ND-3550A at 16x
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media text is Memorex 4.7 GB DVD+R 16x.
Nero v6
Comments posted by Tom from United States, October 29, 2005:
No comments
Purchased from: Best Buy Date purchased: August 2005
Burnt with NEC ND-2100A at 2.4x using firmware 1.26?.
Media text is Memorex DVD+R Recordable 16x 4.7GB 120min.
burned using DVD Decrypter from a fileset made by someone else
Works fine on Sony DVP-NC675P
Comments posted by Nicole from United States, October 28, 2005:
piece of junk as far as I'm concerned. i burned about 15 coasters trying to find a speed at which these would cooperate. 16x media on a 16x burner would not successfully burn higher than 6x.
successful burns do read in the burner, and my standalone player, but in no other standalones that I've tried.
Degradation of media was a serious problem for me. Had to use ISObuster to retrieve data on a successfully burned disc just 5 weeks after burning (disc was inside a case...no surface scratches or anything)
Burnt with Toshiba SD-R5372 at 6x using firmware TU56.
Media text is Memorex on left side, DVD+R 16x, 4.7GB, 120min on bottom right.
Media made in Taiwan.
Comments posted by koolaidwa from United States, February 02, 2005:
only works at12x on the liteon 1633s, work at 16x on my btc 1016im
also that upc was for the single, the 5pack upc is this 034707056138
Price: $1.2 Purchased from: compusa Date purchased: February 2005
Burnt with BTC DRW 1016IM at 16x using firmware A076.
Media text is memorex.
Media UPC/EAN code is 034707056114.
nero 6 OEM
6 user comments, Showing 1 to 6 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
