Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Legacy DVD-R 4.7GB LONGTEN 001. 4x Plays on 5 DVD Players
Plays not on 2 DVD Players
Burn Reliability is Good
DVD Reliability is Mixed
PC Reliability is Good
Console Reliability is Mixed
Read 7 comments
(55849 views)
Post comment
00 6A 00 00 01 40 C1 FD 9E D8 52 00 02 F7 0E 0B .j...@....R.....
77 88 70 00 03 4C 4F 4E 47 54 45 00 04 4E 20 30 w.p..LONGTE..N 0
30 31 00 00 05 AA A2 22 22 20 01 00 06 0B 0F 12 01....."" ......
Media color and text:
Silver None
UPC/EAN Code:
No
7 user comments
Showing 1 to 7 comments
Comments posted by hatelegacy from United States, June 15, 2004:
No comments
Additional information:
Price: $0.3 Purchased from: www.newegg.com
Burnt with Pioneer DVR-107 / DVR-A07 at 4x
Burning reliability is Mixed.
PC reliability is Mixed.
Console reliability is Poor.
Media color is Silver.
Media text is no.
Authoring/Burning comments:
I bought 100 pcs but about 20% of the disc can only burn in 2X, what the f%#k disc. Why legacy always choose worse disc factory??? but leacy disc is really "CHEAP" !!! I think I will choose another brand next time. I don't want my important DVD copy ruin in BAD quality disc
Comments posted by redogre from United States, June 13, 2004:
i bought a 50 pack of these from newegg. i havent had any problems burning, and movies play on my computer just fine. however, i haven't been able to get them to play on any kind of stand alone dvd player. its possible that i am doing something wrong with the way i burn them, but so far, i haven't had any that played on a regular player.
Burnt with Lite-On LDW-411S/451S at 1x
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Poor.
Media text is none.
Comments posted by Gunzee from Canada, February 05, 2004:
Bought 50 of these disc from ATech in Edmonton. One of them turn out to be a coaster. Three other had burn errors at the end(probably outer edge). The rest of the disc, 47, appears to be fine. For the price, it is ok, but not reliable.
Price: $1.5 Purchased from: www.atechcanada.com/ Date purchased: January 2004
Burnt with LG GSA-4081B at 4x using firmware A100.
DVD reliability is Good.
Media inkjet printable reliability is Poor.
Media text is no text.
DVD Decrypter, Nero 6.3, EZ CD 6
Works fine on Apex AD-600
Works fine on JVC XV-S42
Does not work on Koss KD260
Comments posted by Slayer from Canada, January 23, 2004:
worked flawlessly with this great drive & firmware a302.MAKE SURE you upgrade firmware to a302 if you're using 301 cause media ends with errors.Only tested on PC,Xbox & PS2.
Price: $0.1 Purchased from: www.pccanada.com
Burnt with LG GSA-4040B at 2x using firmware 302.
Console reliability is Good.
Media color is Purple.
Media text is None.
Sonic RecordNow DX 4.61
Nero 6
fireburner 2.2.1
Comments posted by ninja from Canada, January 20, 2004:
LONGTEN OO1 IS SHIT!!! NOTHING BUT SHIT SKIPS STUTTERS SPEND MONEY ON SOMETHING GOOD! The problem is Legacy like many other companies use different manufacturers and it is not consistent!
Price: $1.4 Date purchased: January 2004
Burnt with Lite-On LDW-411S/451S at 4x
DVD reliability is Mixed.
Console reliability is Mixed.
Media text is none.
shrink, nero
Works fine on Apex AD-1200
Does not work on Koss C928
Comments posted by cleric from Other, January 03, 2004:
Media burns well at 4x on my nec burner, only issue i had was playing the media in a sony ps2 as it would skip, but on my standalone dvd player it would play without a hitch. Other then that the media was not bad for the price, all burned well and played well.
Price: $1 Purchased from: www.mwave.com
Burnt with NEC ND-2500A at 4x
Media text is SILVER DVD no text.
Used, nero 6, and dvd decrypter to burn dvd's at 4.1x
Works fine on Sony DVP-S360
Comments posted by G-SLIM from Other, November 27, 2003:
Cheap media but you get what you pay for.
Quite a few defective media in a spindle of 25. You can pretty much see the defects if you examine the DVD...mostly near the end of the DVD as reported before. Had a few coasters while burning as well. You take your chances with this media. I think I will be moving on to different media.
Plays ok in my Curtis DVD1025 and my Norcent DP-311.
Some movies play fine, others play with a little pixelation every now and then.
Price: $2
Burnt with LG GSA-4040B at 2x using firmware A301.
Media text is None.
DVD Shrink 3 beta 5
Copy To DVD 2.3.10.235
Nero 5.5.10.35
Works fine on Norcent DP 312
7 user comments, Showing 1 to 7 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
