Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Legacy DVD-R 4.7GB GSC002...... 4x Plays on 6 DVD Players
Plays not on 1 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Mixed
Console Reliability is Mixed
Read 7 comments
(88998 views)
Post comment
00 6A 00 00 01 40 C1 FD 9E D8 52 00 02 87 0D 11 .j...@....R.....
66 78 80 00 03 47 53 43 30 30 32 00 04 00 00 00 fx...GSC002.....
00 00 00 00 05 A8 82 00 20 00 02 00 06 09 11 11 ........ .......
Media color and text:
Silver Red n/a
UPC/EAN Code:
n/a
7 user comments
Showing 1 to 7 comments
Comments posted by Jay from United States, January 23, 2005:
Bought these from Newegg. Wanted to buy more name brand but these were so cheap... for a reason. I've had so many bad DVDs so far, especially errors on the outside, that I'm throwing away the whole lot. It's taking too long for one good disc by burning and scanning each one usualy for 5 bad ones before a good one. My DVD burner may be a little too picky as well. No reports here about this burner - came in an Averatec 3200 model laptop - so I can't be for certain. A portable DVD player someone has has been able to play the media but will skip here and there towards the end of movies.
Additional information:
Price: $0.4 Purchased from: Newegg.com Date purchased: December 2004
Burnt with QSI SDW-042 at 2x using firmware DX70, D361, D363.
Burning reliability is Mixed.
PC reliability is Poor.
DVD reliability is Mixed.
Media color is White.
Media text is White thermal printable.
Media package type is Shrink Wrapped. Number of discs 50.
Authoring/Burning comments:
Authored with DVD Shrink 2.3, 3.2
Nero Burning Rom 6.2
CloneDVD2
Works fine on Coby DVD-615
Comments posted by RevJim from United States, November 02, 2004:
5 coasters out of 100. Not bad considering how cheap they were from neweg.com.
DVDDecrypter will only burn @ 2x, but Roxio burns dvdshrink Image files @ 4x no problem. In fact, no coasters since I switched to Roxio for burning chores.
Price: $0.4 Purchased from: www.newegg.com Date purchased: October 2004
Burnt with Lite-On SOSW-852S at 4x
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Console reliability is Good.
Media color is Silver.
Media text is GSC.
Rip w/ DVD Decrypter, Re-author w/ DVD Shrink to an iso file, then burn w/ Roxio Easy CD/DVD for best and fastest results.
Works fine on Oritron DAV2100
Works fine on Philips DVP642
Does not work on Lasonic DVD-1100
Comments posted by theGrue from United States, October 01, 2004:
Friend got these off Newegg for something like $13, not realizing his burner could only do +R. Grabbed one for evaluation purposes. Decent PI/PO levels, a bit higher than my Ritek G03's.
Price: $0.5 Purchased from: www.newegg.com Date purchased: September 2004
Burnt with Plextor PX-712A at 4x using firmware 1.05.
Media text is blank.
DVD Decrypter 3.5.1.0
Works fine on Sylvania SRTD413
Comments posted by mygod from United States, July 17, 2004:
burned 30 pcs all in 2X only
Price: $0.4 Purchased from: www.newegg.com Date purchased: July 2004
Burnt with NEC ND-2500A at 4x
Burning reliability is Poor.
PC reliability is Mixed.
Console reliability is Poor.
Comments posted by jzukow from United States, July 16, 2004:
Not too bad. GSC002 media code. I was hoping for Sony media code, but no big deal. These were dirt cheap. They burn fine on my NEC 2510A. PI/PO error scans are acceptable. Definitely better than some CMC and Kypermedia's I've used. (crap) I just don't like the shiny silver tops. (they steal fingerprints). I guess some have matte finishes. But oh well they do the job. and for $20 a 50 pack, why not try em.
Price: $0.4 Purchased from: Newegg Date purchased: July 2004
Burnt with NEC ND-2510A at 4x using firmware 2.15.
Media text is Blank.
Nero, Decrypter
Works fine on LiteOn LVD-2001
Comments posted by makaveli7_wtf from United States, July 14, 2004:
threw away the lil paper so dont have UPC or info in where its made, burnt a couple discs at 4x fine
Media text is none.
Media UPC/EAN code is N/A.
Nero6
Comments posted by SledgeDG from United States, May 03, 2004:
burnt picture and data at 4x just fine
Purchased from: www.newegg.com Date purchased: April 2004
Burnt with LG GSA-4082B at 4x using firmware A201.
Media color is Silver Red.
Media text is n/a.
Media package type is Slim Case. Number of discs 10.
Media UPC/EAN code is n/a.
DVDShrink 3.1 and Nero 6.3.0.2
Works fine on RCA RC5240P
7 user comments, Showing 1 to 7 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
