Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Legacy DVD-R 4.7GB GSC001...... 4x Plays on 6 DVD Players
Plays not on 1 DVD Players
Burn Reliability is Mixed
DVD Reliability is Mixed
PC Reliability is Good
Console Reliability is Poor
Read 6 comments
(75693 views)
Post comment
00 00 00 00 01 40 c1 fd 9e d8 52 00 02 87 0d 11 .....@....R.....
66 78 80 00 03 47 53 43 30 30 31 00 04 00 00 00 fx...GSC001.....
00 00 00 00 05 a8 82 00 20 00 02 00 06 09 11 11 ........ .......
Media color and text:
Silver blank
UPC/EAN Code:
828897344492
6 user comments
Showing 1 to 6 comments
Comments posted by captylor from United States, June 07, 2005:
Really good media. Lowwer PI error levels than other media. Would have to say go gigastorage. Went through a whole mess. Best to start out on. Like the clean surface as well. Nice area to scrible onto. Tried other "quailty media." Will be ordering another stack of these asap.
Additional information:
Purchased from: www.newegg.com
Burnt with Lite-On SOHW-1633S at 4x using firmware BSOK.
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media color is Silver.
Media text is none.
Media package type is Shrink Wrapped. Number of discs 50.
Authoring/Burning comments:
Nero 6.6
Shrink 3.2
Works fine on Pioneer DV-250
Works fine on Pioneer DV-414
Works fine on Sony DVP-NS725P
Works fine on Toshiba SD4900
Comments posted by PhatStrat from United States, April 07, 2005:
First 5 or so disks off the top burned fine and played on my DVD player without a hitch. Then the nightmare began. I have now gone through 20 of the 50 disks on the spindle and have a very nice set of coasters and 6 usable DVD's. The data is all there and intact, and they all play just fine on my PC, but will not play on any of the three DVD players we have in the house. Recommend for data storage only.
Purchased from: newegg.com Date purchased: March 2005
Burnt with NEC ND-3520A at 4x
Media text is No text.
DivXtoDVD, then burned with DVDCopy and/or Alcohol. Same result with both.
Comments posted by vindicated from United States, January 18, 2005:
This media got really good reviews on Newegg so I gave it a try. On my first burn attempt, my DVD burner had problems with this media. I had to update the firmware to 1.0b then it burned just fine. I used InterVideo DVDCopy 2 & AnyDVD to make a backup of the movie HERO with Jet Li. It played great on my computer, but when I tried to play it on my Apex AD-703 it couldn't read the disc. After a few attempts the Apex was able to play the FBI warning screen but it would freeze. I tried with another movie and the same thing happened.
My Apex may be a cheap brand player but normally it can play everything you throw at it. The price is good ($15), but from now on I'll just pay a few more dollars and get Ridata or Sony.
Purchased from: www.newegg.com Date purchased: January 2005
Burnt with NEC ND-1300A at 4x using firmware 1.0b.
DVD reliability is Poor.
Media text is Legacy DVD-R General Use Single Sided.
Media UPC/EAN code is 828897344492.
Made backup of HERO with Jet Li using InterVideo DVDCopy 2.
Does not work on Apex AD-703
Comments posted by hatelegacy from United States, January 17, 2005:
This media is absolute piece of junk.
Price: $0.3 Purchased from: www.newegg.com Date purchased: January 2005
Burnt with NEC ND-3500A at 4x
Burning reliability is Poor.
PC reliability is Poor.
Console reliability is Poor.
Media text is silver.
Media made in China.
Comments posted by j from United States, January 01, 2005:
No comments
Price: $20 Purchased from: newegg
Burnt with Toshiba SD-R5112 at 1x using firmware 1033.
Media text is Silver Blank.
I have burned 25 discs without a coaster using DVD Decrypter. Although slow with firmware 1033. Just upgraded firmware to x433, but haven't burned anything since the upgrade.
Works fine on Toshiba SDH400
Comments posted by w c from United States, December 06, 2004:
7 coasters out of 50, would not burn at 4x before or after firmware upgrade (1031 to 1033) with Toshiba SD-R5112. I will not buy these again.
Price: $0.4 Purchased from: Newegg Date purchased: September 2004
Burnt with Toshiba SD-R5112 at 4x using firmware 1033.
Burning reliability is Mixed.
Media text is blank.
Nero 6 oem
Works fine on Apex AD-1200
Media image
Mediaimage
Click to enlarge
6 user comments, Showing 1 to 6 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
