Laser |
DVD-R |
4.7GB |
AN31........ |
4x |
Plays on 9 DVD Players
Plays not on 3 DVD Players
Burn Reliability is Mixed
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is Mixed
Read 10 comments (88384 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 87 0E 15 .l...@....R.....
98 9A 90 00 03 41 4E 33 31 00 00 00 04 00 00 00 .....AN31.......
00 00 00 00 05 CC C0 00 00 00 01 00 06 0B 10 11 ................
Media color and text:
Silver Blank UPC/EAN Code:
No
10 user comments
Showing
1 to
10 comments |
Comments posted by imagineburn from United States, May 24, 2004:
Tried this in my JVC SX-502 and no go with many many disks.
Additional information:
Burnt with NEC ND-2500A at 4x using firmware 1.06. Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media color is White. Media text is None. Media package type is Cake Box. Number of discs 25. Does not work on JVC XV-S502SL |
Comments posted by Rob from Australia, April 10, 2004:
No comments
Price: $0.9 Purchased from: www.austin.net.au Date purchased: March 2004 Burnt with Iomega Dual DVD±RW at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Silver. Media text is Laser 4X. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Used Nero 6 to burn 22 DVD-Rs at 4X. 1 coaster (stopped at 99%) so far. Rest burned properly. Of these, 10 are DVD-Video, and could play on PS2 console, and BenQ portable DVD player. Works fine on BenQ DVDgem |
Comments posted by Adriaan from Australia, April 06, 2004:
Burnt about 400 disks using 106 and 107 only about 5 Failures
Price: $1.3 Purchased from: www.pcworld.com.au Burnt with Pioneer DVR-106 / DVR-A06 at 4x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is DVD-R 4X 4.7GB AML 3P222. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Nero Works fine on Pioneer DV-525 |
Comments posted by cozmos45 from Australia, April 04, 2004:
this media works pretty good.
i got some off my friend and i burnt using Nero, burnt a couple of movies and they work fine.
all burnt at 4x.
Price: $0.9 Purchased from: computer markets at parra Date purchased: March 2004 Burnt with Pioneer DVR-107 / DVR-A07 at 4x using firmware 1.12. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is none. Media package type is Cake Box. Number of discs 25. Media UPC/EAN code is n/a. Authoring/Burning comments: used Nero 6.300 Works fine on Sast AEP-816 |
Comments posted by Doug from Australia, March 28, 2004:
Had a failure rate of 5 out of 10 with Laser silver top and 7 out of 10 with printable surface. Pioneer do not recommend them at all. Burnt at 1, 2 and 4 speed, same results.
Purchased from: IT WAREHOUSE Burnt with Pioneer DVR-106 / DVR-A06 at 2x Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media inkjet printable reliability is Poor. Media color is Silver. Media text is IFPI GZ04. Media package type is Cake Box. Number of discs 20. Authoring/Burning comments: Nero 6.6.03 Does not work on XMS 750 |
Comments posted by Ang from Australia, March 11, 2004:
Pathetic media. Tested in Pioneer 106
would not work at 4x
2x had PI and PO errors which were way above standard requirements
1x had worse results than 2x
really poor media. barely useable for anything accept coffee coasters and frisbees. Cost 30 bucks for 25. sent em back. rather keep my money than put it down a toilet.
Price: $30 Purchased from: Strathfield car audio Burnt with Pioneer DVR-106 / DVR-A06 at 4x Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Console reliability is Poor. Media inkjet printable reliability is Poor. Media color is Silver. Media text is nothing. Media package type is Cake Box. Number of discs 25. Media made in Taiwan. Does not work on Teac DV-3500 |
Comments posted by Michael S from Australia, March 03, 2004:
DVD-R Laser Brand. $25 for a spindle of 25.
Did not work at 4x (created coaster). Only worked at 2x. Even though rated at 4x. Noisy operation (may not be perfectly round??).
Price: $1 Purchased from: Zip Computers, Sydney AU. Date purchased: March 2004 Burnt with MSI DR8-A at 2x using firmware 120i. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Purple. Media text is Silver - No Text. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Nero 6.0.3 Works fine on Sony DVP-S336 |
Comments posted by Garth from Other, October 23, 2003:
More compatible than $10 media
Comments posted by Madmax from Other, October 21, 2003:
I have a sony dru-510a and i purchashed a 25 pack of lazer dvd's and have had no problems , in fact the results are pretty awsome so far ( touch wood ).
Price: $1.8 Purchased from: australia Date purchased: October 2003 Burnt with Sony DRU-510A at 4x using firmware 1.0c. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is none. Authoring/Burning comments: anydvd , clonedvd Works fine on Toshiba SD2600 |
Comments posted by kay from Other, October 17, 2003:
I got a 25 pack spindle for $41CDN. No labels, just silver tops.
Price: $1.6 Purchased from: Infomicro.ca Date purchased: October 2003 Burnt with Pioneer DVR-106 / DVR-A06 Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Silver. Media text is Blank. Works fine on Apex AD-1200 |
10 user comments,
Showing
1 to
10 comments |
