Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
illusion DVD+R 8.5GB PHILIPS.CD2 2.4x Plays on 3 DVD Players
Plays not on 0 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is N/A
Read 1 comments
(37695 views)
Post comment
00 00 00 00 e1 0f 32 10 00 03 00 00 00 fc ff ff ......2.........
00 22 d7 ff 00 00 00 50 48 49 4c 49 50 53 00 43 .".....PHILIPS.C
44 32 00 40 25 25 37 0b 02 3c 6a 02 3c 6a 1b 1c D2.@%%7...j..j..
0d 0c 0c 0c 02 01 01 10 00 1b 1c 0d 0c 0c 0c 02 ................
Media color and text:
Silver illusion Professional Media Solution DVD+R DL 2.4x Double Layer 8.5 GB / 240 Min
UPC/EAN Code:
No info
1 user comments
Showing 1 to 1 comments
Comments posted by ofbarea from Costa Rica, November 19, 2005:
This media is supposed to be written at 2.4x, but Nero 6.6 and DVD Decrypter identified this media as 4x capable. I burned them at 2.4x just to be safe.
I bought 4 of this disk in a near by store. Since in CR is very difficult to find DL media I decided to give this a try. I needed two disk for data backups, so I bough an extra pair to test some dual layer compatibility.
To validate compatibility I burned two copies of the same 7.85 GB movie. One with book type set to DVD+R DL and the other set to DVD-ROM.
On the PC compatibility when the book type was set to DVD+R DL it could not be read by a Toshiba DVD-RAM SD-W2002. The same problem happened with a Samsung combo drive SM-348B. Finally a Panasonic DMR-E55 recorder was not able to play the movie either.
These problems disappeared completely when the media was book type was set to DVD-ROM. I would recommend this media, but only if you can set the book type to DVD-ROM, otherwise you will find many compatibility problems.
Additional information:
Price: $7 Purchased from: Store near my home Date purchased: November 2005
Burnt with Lite-On SOHW-1693S at 2.4x using firmware KS0B.
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media color is Silver.
Media text is illusion Professional Media Solution DVD+R DL 2.4x Double Layer 8.5 GB / 240 Min.
Media package type is Slim Case. Number of discs 1.
Media made in Taiwan.
Authoring/Burning comments:
Burned with DVD Decrypter 3.5.4.0
Works fine on Apex AD-5131
Works fine on Panasonic DMR-E55
Works fine on Panasonic DMR-ES10
Affiliates: free-codecs.com
©1999-2025 videohelp.com
