Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
HP DVD+R 4.7GB CMC MAG.F01 4x Plays on 32 DVD Players
Plays not on 7 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is Mixed
Read 23 comments
(305092 views)
Post comment
08 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
00 00 00 00 00 00 01 43 4D 43 20 4D 41 47 00 46 .......CMC MAG.F
30 31 00 38 23 54 37 10 02 48 71 02 8C 69 16 16 01.8#T7..Hq..i..
0B 0B 0A 0A 01 1D 1E 0C 0C 12 12 01 00 00 00 00 ................
Media color and text:
Yellow Silver HP invent DVD+R 4.7 GB 4x
UPC/EAN Code:
637668020073
23 user comments
Showing 1 to 23 comments
Comments posted by jade from United States, May 24, 2006:
I got couple bad burns out of the batch, where the written data is bad toward the end. Burned video sometimes skips when played. Least reliable media I've had.
Additional information:
Price: $0.5 Purchased from: Fry's Electronics store Date purchased: December 2003
Burnt with NEC ND-2500A at 4x
Burning reliability is Mixed.
PC reliability is Mixed.
DVD reliability is Mixed.
Media color is Yellow.
Media text is HP Invent.
Media made in Taiwan.
Comments posted by alien from Canada, April 24, 2006:
No comments
Burnt with Lite-On SOHW-1213S at 4x
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media color is Gold.
Media text is dvd+r 4.7GB 4x.
Works fine on JVC XV-S502SL
Comments posted by double_d from United States, January 04, 2006:
I was not impressed with this disc. I would not purchase this product again.
Price: $0.5 Date purchased: November 2004
Burnt with HP DVD200i at 2.4x using firmware 1.51.
Media text is hp DVD+r 4.7 GB disc.
Media UPC/EAN code is 637668020066.
Works fine on Toshiba SD2800
Does not work on Samsung DVD-M301
Comments posted by Red from Italy, February 14, 2005:
They works very well in my DVD Burner. All the disc play flawless on my home DVD player.
Price: $0.4 Purchased from: www.nierle.de Date purchased: February 2005
Burnt with NEC ND-2500A at 4x using firmware 1.08v3-2.
Media text is HP Invent dvd+r 4,7Gb 4x.
Authoring/Burning comments:
Nero 6.6.0.6
Works fine on KiSS DP-1000
Works fine on Pioneer DV-470
Comments posted by Andrew Case from United States, January 13, 2005:
Good quality media....burns well on my Toshiba sd-5272,
BenQ dw1620(at 8x) and my Toshiba sd-5372(ONLY after firmware upgrade to TU53....otherwise you'll make coasters). Puchased all of the 10 packs staples had in slim cases for $6 a 10pk.
Price: $6 Purchased from: Staples Date purchased: January 2005
Burnt with BenQ DW1620 (Pro) at 8x using firmware G7P9.
Media color is Silver Orange.
Media text is HP invent dvd+r 4.7 GB 4x.
Media package type is Slim Case. Number of discs 10.
Nero 6.6.0.3 DVDdecrypter copytodvd blindwrite
Works fine on Sony DVP-NS575P
Works fine on Toshiba SD2900
Comments posted by flyboydave from United States, November 16, 2004:
No comments
Burnt with NEC ND-1300A at 4x using firmware 1.0a.
DVD reliability is Poor.
Media inkjet printable reliability is Good.
Media text is HP Invent dvd+r 4.7GB 4X.
Media UPC/EAN code is 637668020073.
Alcohol 120%, DVD Decrypter, Roxio EZ Media 7
Does not work on Panasonic DVD-RP56
Comments posted by LisaRae from United States, November 10, 2004:
Works fine in my computer and both phillips dvp642 & Ge 1101pb players.
Price: $30 Purchased from: tigerdirect 4-25 pack spindle Date purchased: October 2004
Burnt with Iomega Super DVD Writer 4x All-Format External at 4x
dvd shrink
Works fine on GE Digital GE1101P
Works fine on Philips DVP642
Comments posted by cuschieri from Canada, October 25, 2004:
Just got my dvd burner Oct 13/04 and this is my first batch of HP DVD+R I Bought with the burner And so far Works OK for PS2 games and dvd movie backups I used Nero, DVD Decrypter and Alcohol 120 ,for games and DVDXCOPY ,for movies and had no coasters as of yet ,down to my last 9 disks I'M Still not sure what`s the difference between a DVD+R AND A DVD-R is the + better ?
Price: $30 Purchased from: www.TigerDirect.ca Date purchased: October 2005
Burnt with Toshiba SD-R5272 at 4x
Console reliability is Good.
Media text is DVD+R 4.7GB 4x.
Media UPC/EAN code is 3766802006.
NERO,DVD DECRYPTER,ALCOHOL 120% ,DVDXCOPY
Works fine on Toshiba SD2715
Media image
Mediaimage
Click to enlarge
Comments posted by PBXTech from United States, October 17, 2004:
No comments
Price: $0.4 Purchased from: Staples Retail Date purchased: October 2004
Burnt with Asus DRW-1604P at 4x
Media color is Yellow Silver.
Media text is HP dvd+r 4.7GB 4x.
DVD Decrypter 3.5.1.0 w/DVD Shrink 3.2
Nero Burning ROM/Ultra 6
Does not work on Samsung DVD-C700
Media image
Mediaimage
Click to enlarge
Comments posted by Plutto from Canada, August 04, 2004:
No problems playing on Panasonic DVD S35 (never had a problem playing ANYTHING on this player). Does not play on an older Toshiba SD 2800. Some + discs do and some don't on the Toshiba.
Purchased from: www.tigerdirect.ca Date purchased: August 2004
Burnt with Pioneer DVR-106 / DVR-A06 at 4x
Media text is HP Invent DVD+R 4.7gb.
DVD Shrink 3.2.0.15 and Nero 6
Works fine on Panasonic DVD-S35
Does not work on Toshiba SD2800
Comments posted by Morgan Thevarajan from Sweden, August 03, 2004:
Burns at 8x on my BenQ DW822A although it's only 4x rated.
Price: $1 Purchased from: www.tigerdirect.ca
Burnt with BenQ DW822A at 8x using firmware B3IC.
Media text is HP invent dvd+r 4.7GB 4x.
Nero 6.3.1.15
Works fine on Daytek P871
Works fine on Panasonic DVD-RV31
Works fine on Panasonic DVD-RV32
Media image
Mediaimage
Click to enlarge
Comments posted by Spazmogen from Canada, July 22, 2004:
Bottom of DVD is purple. $34.99 CDN per spindle of 50.
Price: $30 Purchased from: www.tigerdirect.ca Date purchased: July 2004
Burnt with NEC ND-1100A at 4x using firmware 1.H1.
Nero 6. My firmware is an auto resetting Region hack from Etna.
Works fine on Hitachi DVP415U
Media image
Mediaimage
Click to enlarge
Comments posted by gary chang from United States, June 27, 2004:
No comments
Price: $40 Purchased from: micro center Date purchased: June 2004
Burnt with Sony DRX-530UL at 4x
Burning reliability is Poor.
PC reliability is Poor.
Media text is Hp invent dvd+r 4.7GB 4x.
Sonic RecordNow! 6.7.0
Does not work on Panasonic DVD-S35
Comments posted by TKL from United States, June 25, 2004:
Burned on BenQ DW800A @ 8x and BTC 1008IM @ 4x. Played on all dvd players I have come across without any problems at all. Got it at Microcenter for $35 for a 50 pack spindle.
Purchased from: Microcenter Date purchased: June 2004
Burnt with BenQ DW800A at 8x using firmware B2J7.
Media text is HP dvd+r 4.7GB.
DVD Decrypter 3.2.2.0, DVD Shrink 3.1.7.6 and Nero 5.5.10.56
Works fine on GoVideo DVR4400
Works fine on Jamba XDVD 1000
Works fine on JVC XV-N410BK
Works fine on JVC XV-N412S
Works fine on JVC XV-N44SL
Works fine on JVC XV-N50BK
Works fine on JVC XV-N55SL
Works fine on Philips DVD616K
Works fine on Pioneer DV-270
Works fine on Pioneer DV-275
Works fine on Pioneer DV-525
Works fine on Zenith DVB413
Media image
Mediaimage
Click to enlarge
Comments posted by Xadio from United States, June 04, 2004:
Works fine for the Micro Advantage DVD±RW Superdrive, and plays fine in the AVIndustries, AVX-100.
Price: $20 Purchased from: Office Max Date purchased: June 2004
Burnt with Micro Advantage 4DVDRW at 4x using firmware 050.
Media text is HP Invent dvd+r 4.7GB 4x.
Alcohol 120%
Works fine on AVX X-100
Comments posted by DL175 from Sweden, June 02, 2004:
Burns well and plays great on pc or Panasonic DVD S35. Price is $34.95 for 50 spindle at TigerDirect.ca - code K51-2030 The price is very low at 70 cents each. So far burn only 6 disc with no coasters.
Price: $40 Purchased from: www.tigerdirect.ca Date purchased: May 2004
Burnt with NEC ND-2500A at 4x using firmware 1.06.
Media text is HP invent DVD+R 4.7GB 4X.
DVD Shrink 3.1 & Pinnacle Instant CD for burning
Comments posted by Joe from United States, April 22, 2004:
Bought a 10-pack of these at Staples. They burnt well at 4x in my NEC 1300A burner and play well on my Sony player that supports DVD+R discs. No coasters.
Price: $20 Purchased from: Staples Date purchased: March 2004
Burnt with NEC ND-1300A at 4x using firmware 1.07.
Media text is HP Invent DVD+R 4.7GB 4x.
Burned stuff using Roxio Easy CD Creator 7, DVDDecrypter, and RecordNow MAX
Works fine on Sony DVP-NS325
Comments posted by Hodonin from United States, March 22, 2004:
Out of first 4 discs, only one worked on DVD player.Reburned with speed 1x, worked OK. Returned to Office Max. There are better brands on the market.
Burnt with HP DVD200e at 2.4x using firmware 1.65.
Media text is Yellow/Silver.
Does not work on Sampo DVE-631CF
Comments posted by RICAN from United States, February 26, 2004:
HP 4.7 GB DVD+R 4X
IVE BURNED ABOUT 15 DICS SO FAR, AND I HAVENT MADE A SINGLE COASTER YET. WORKS GREAT WITH MY NEC 2500A BURNER USING DVD SHRINK 3.1. ALL THE DICS HAVE PLAYED FLAWLESS ON MY HOME DVD PLAYER. I BOUGHT A 25 PACK AT STAPLES FOR $25 ON SALE.
Price: $1 Purchased from: STAPLES Date purchased: January 2004
Media text is SILVER.
DVD SHRINK 3.1
NERO (LASTEST)
Works fine on Sony DVP-S560D
Comments posted by Joshua from United States, February 21, 2004:
My TDK burner would burn the 4x media at 8x, like it is supposed to. However, it wouldn't play in one of the dvd player's I tried to play it in. Video was messed up in PS2.
Burnt with TDK 880N at 8x
Console reliability is Poor.
Media text is Silver.
Works fine on Philips DVD726
Does not work on Panasonic DVD-RV32
Comments posted by smackskbl from United States, February 07, 2004:
Media worked good after I figured out how to use my software. Burned off 2 DVD's with compression and looks as good as original. No problem here.
Burnt with Sony DRU-530A at 4x using firmware 1.0d.
Media text is HP invent 4.7GB DVD+R 4x.
DVD X Copy Platinum 3.2.1
Works fine on Sony DVP-S530D
Comments posted by RevMaynard from United States, February 06, 2004:
8x, 4x, 2x, it doesn't matter, these dvd's are pure crap. Out of 10 discs burnt, only 3 came out good. Not only that, they took about 3 times as long as they should have to burn.
Price: $1 Purchased from: Staples B&M Date purchased: February 2004
Burnt with BTC DRW 1008IM at 2x using firmware 55.
Media color is Purple.
Comments posted by Vance Howard from United States, February 03, 2004:
Have only burnt one so far out of a 25 pack. I can't burn CMC Mag DVD-R's, but apparently I can burn CMC Mag DVD+R's. I can burn Ritek DVD-R's just fine also
Price: $1 Purchased from: staples Date purchased: February 2004
Burnt with Sony DRU-510A at 4x using firmware 1.0d.
Media text is HP invent DVD+R 4.7 GB 4x.
DVD Xcopy express
Works fine on Pioneer DV-250
23 user comments, Showing 1 to 23 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
