Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
GQ (Great Quality) DVD+R 4.7GB OPTODISCOR8 8x Plays on 8 DVD Players
Plays not on 5 DVD Players
Burn Reliability is Mixed
DVD Reliability is Good
PC Reliability is Good
Console Reliability is N/A
Read 5 comments
(86167 views)
Post comment
00 00 00 00 00 00 03 4f 50 54 4f 44 49 53 43 4f .......OPTODISCO
52 38 00 38 23 54 37 09 02 64 6a 02 c8 63 18 18 R8.8#T7..dj..c..
0a 0a 0e 0e 01 1b 1d 0b 0b 11 13 01 00 00 00 00 ................
Media color and text:
Silver No text
UPC/EAN Code:
N/A
5 user comments
Showing 1 to 5 comments
Comments posted by Rolly from United States, December 13, 2004:
No comments
Additional information:
Price: $0.3 Purchased from: Fry's Electronics Date purchased: November 2004
Burnt with Emprex DVDRW 1016IM at 8x using firmware A17J.
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media color is Purple.
Media text is None.
Authoring/Burning comments:
Nero 6.6
Works fine on Apex AD-1130W
Works fine on Apex AD-703
Works fine on Norcent DP 300
Comments posted by Seth from United States, December 04, 2004:
The +R stuff seems to work really well, no problems and I've burned about 75 discs of it, the -R stuff with the B.S. TYG02 tag is half and half bogus. It seems with the GQ stuff that you get good batches and bad batches and the bad is unusable and the good is fine.
Burnt with Memorex 16x DVD+/-DLRWL1 F16 External at 8x using firmware BWSE.
Burning reliability is Mixed.
Media color is Silver.
Media text is Clear.
Nero, it always seems to burn slower than 8X
Works fine on Coby DVD-224
Comments posted by Okleydokley from United States, August 27, 2004:
Burn was ony slightly faster (about 10 seconds) then 4x media..
Price: $0.6 Purchased from: Fry's Electronics
Burnt with NEC ND-3500A at 8x
Media text is Blank.
Media package type is Shrink Wrapped. Number of discs 20.
Nero
Works fine on JVC XV-S57
Comments posted by ab from United States, August 12, 2004:
Does not work with Emprex / BTC 1008IM.
With different burn programs and different data, burning hangs in the appx same place after writing 961 Mb
Software reported burning speed a bit over 2x (until it hangs)
Price: $0.7 Purchased from: Frys Date purchased: August 2004
Burnt with Emprex DVDRW 1008IM at 3x using firmware 0054.
Burning reliability is Poor.
Media text is none.
Roxio Easy CD DVD ver .6 (Copy and data modes)
Intervideo Copy DVD 2 platinum
Comments posted by F47D00d from United States, July 27, 2004:
Burned approximately 7 discs so far. Out of those 7, 2 were coasters. Mixed results with various players.
Price: $1.4 Purchased from: Fry's Electronics - Tempe, AZ Date purchased: July 2004
Burnt with Sony DRU-700A at 8x using firmware VY02.
PC reliability is Mixed.
DVD reliability is Mixed.
Media text is No text.
Media UPC/EAN code is N/A.
Nero Express 6.0.0.6
Works fine on Pioneer DVR-310
Works fine on RCA RC5240P
Does not work on Broksonic DVCR810
Does not work on Mintek MDP-5860
Does not work on Pioneer DVL-919
Does not work on RJTech RJ-1500DVX
Does not work on Toshiba SD4800
5 user comments, Showing 1 to 5 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
