Go Tech |
DVD-R |
4.7GB |
AN30........ |
4x |
Plays on 3 DVD Players
Plays not on 6 DVD Players
Burn Reliability is Mixed
DVD Reliability is Poor
PC Reliability is Mixed
Console Reliability is Mixed
Read 12 comments (63058 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 87 0E 15 .l...@....R.....
98 9A 90 00 03 41 4E 33 30 00 00 00 04 00 00 00 .....AN30.......
00 00 00 00 05 CC C0 00 00 00 01 00 06 0B 10 11 ................
Media color and text:
Gold Black GO TECH DVD-R Recordable UPC/EAN Code:
03115106
12 user comments
Showing
1 to
12 comments |
Comments posted by Carlos Mena from Chile, May 30, 2005:
No comments
Additional information:
Burnt with LG GSA-4082B at 4x using firmware A206. Burning reliability is Mixed. PC reliability is Good. DVD reliability is Poor. Media color is White. Media text is none. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: Nero 6.6.0.8 Does not work on Philips DVP5100K |
Comments posted by Tim Case from Australia, May 11, 2004:
not very good at all, burnt badly
Burnt with Pioneer DVR-107 / DVR-A07 at 4x using firmware 1.10. Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Console reliability is Poor. Media inkjet printable reliability is Poor. Media color is Turquoise. Media text is nothing. Media package type is Cake Box. Number of discs 50. Media made in China. Authoring/Burning comments: any dvd
clone dvd Does not work on Toshiba SD1200 |
Comments posted by Rose Sheldon-Collins from Australia, May 07, 2004:
Really much the same as others. Was using Princo, no probs then bought these and half of them have failed the burn 1/2 to 3/4 way through. Going back to princo now.
Price: $30 Purchased from: Big W Date purchased: April 2004 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.06. Burning reliability is Poor. PC reliability is Mixed. Media color is Gold Black. Media text is Black. Media package type is Cake Box. Number of discs 10. Media made in Taiwan. Authoring/Burning comments: DVD Shrink and Nero Express |
Comments posted by MrHat from Australia, May 01, 2004:
My experience with Go tech diska is much the same as what others have reported. I was using princo with no problems then I tried some Go tech and every single one failed. As others have reported they fail about half way through. I even tried at 1x with no luck.
Price: $30 Purchased from: Big W Australia Burnt with Sony DW-U14A at 4x Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media color is Gold Black. Media text is DVD-R Recordable 120 Minutes General use GO TECH COMPUTERWARE 4X 4.7 Gigabyte. Media package type is Cake Box. Number of discs 10. Media made in Taiwan. Authoring/Burning comments: Nero 6
Comments posted by Mark from Australia, March 01, 2004:
AVOID THESE DVD-R's LIKE THE PLAGUE! Was given a pack for birthday, turned out to be a terrible gift. Have only bothered using three, will destroy the rest. Two were used for movies, playback on two standalone players varies from bad to really bad!! Similar to other comments, 1/2 - 2/3 way through movie, breaking up, then unplayable chapters. One was burnt with a 1GB dvd slideshow, luckily plays back fine on a pioneer standalone, but then turns around and starts skipping straight away on a samsung!!??
Date purchased: January 2004 Burnt with Pioneer DVR-106 / DVR-A06 at 2x using firmware 1.07. Burning reliability is Poor. DVD reliability is Poor. Media inkjet printable reliability is Poor. Media color is Gold Black. Media text is GO TECH COMPUTERWARE DVD-R 4X 4.7GB General Use. Media package type is Cake Box. Number of discs 10. Authoring/Burning comments: Shrink 3.1, Nero 6, MemoriesOnTV. Does not work on Pioneer DV-355 Does not work on Samsung DVD-M105 |
Comments posted by Nitin Mangalath from Australia, February 24, 2004:
Bought a pack of 10, 4 ended up as coasters
Price: $30 Purchased from: Big-W (Riverton, WA, Aust) Date purchased: November 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 2x using firmware 1.07. Burning reliability is Mixed. PC reliability is Mixed. Media color is Gold Black. Media text is GO TECH COMPUTERWARE DVD-R Recordable. Authoring/Burning comments: Nero 6 |
Comments posted by Wayne Murray from Australia, January 28, 2004:
Burned dozens of coasters until I was told the media may be the problem. First attempt at burning and just expected it to work first time. First part of the disc seemed to work ok but then the movie started to skip around and then freeze completely towards the last third of the movie. Noticed the same comments from someone else!! Tried slower burn speed to no avail.
Price: $3 Purchased from: Big W Date purchased: January 2004 Burnt with Pioneer DVR-106 / DVR-A06 at 4x Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media color is Gold Black. Media text is Silver/Black. Authoring/Burning comments: CloneDVD and DVD X Copy Platinum Does not work on Philips DVD718 |
Comments posted by Troy from Australia, January 23, 2004:
Hopeless on playback!!
Price: $3 Purchased from: Big W Date purchased: January 2004 Burnt with LG GSA-4040B at 4x Burning reliability is Mixed. PC reliability is Poor. DVD reliability is Poor. Media color is Gold. Media text is GoTech Computerware 4.7gb DVD-R 4x. |
Comments posted by JJB from Other, January 15, 2004:
Out of 10 disks, 5 movies were burnt OK, 2 out of 5 back-ups for Playstation 2 (PS2) burns failed (burnt at 4x speed). The same PS2 images were burnt on other DVD media (Princo 4.7 GB DVD-RW 2x) and worked correctly.
Price: $3 Purchased from: Big W Date purchased: December 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.07. Burning reliability is Mixed. PC reliability is Mixed. Console reliability is Mixed. Media color is Gold Black. Media text is Go Tech DVD-R 4x 4.7GB General Use. Authoring/Burning comments: Alcohol 1.4.8.1222, DVD Shrink 3.0 Beta, ImgTool Burn Works fine on Pioneer DV-626 |
Comments posted by Lachlan Moore from Other, October 13, 2003:
Had two successes in twenty burns, the rest froze up towards the end of the movie (last 1/3). The successful burns were ~ 3.7 GB. I tried using several programs and burning speeds.
Switched to Shintaro media and have no coasters yet.
Price: $3 Purchased from: Big W Date purchased: November 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.07. Burning reliability is Poor. PC reliability is Poor. DVD reliability is Poor. Media color is Gold Black. Media text is Go-tech 4.7 GB DVD-R 4x. Authoring/Burning comments: Authored with DVD Shrink and DVD Decrypter
Burnt with Nero 5.5.8.0 and DVD Decrypter |
Comments posted by Norman Walsh from Other, October 08, 2003:
No comments
Price: $3 Purchased from: Big W Australia Date purchased: October 2003 Burnt with LG GMA-4020B at 2x Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Gold Black. Media text is GO TECH 4x General Use. Authoring/Burning comments: Nero, DVD Decrypter, Pinacle Instant Copy. No problems. Only burnt 3 so far though. Works fine on Sony DVP-S305 |
Comments posted by Guy Redman from Other, October 02, 2003:
Burns OK at 4x
Not as reliable as Princo
Price: $3 Purchased from: Big W (Aust) Date purchased: September 2003 Burnt with Pioneer DVR-106 / DVR-A06 at 4x Burning reliability is Good. PC reliability is Mixed. DVD reliability is Mixed. Console reliability is Mixed. Media color is Gold Black. Media text is GO TECH DVD-R Recordable. Media UPC/EAN code is 03115106. Authoring/Burning comments: Nero 6 Works fine on Microsoft Xbox Does not work on Samsung DVD-M205 |
12 user comments,
Showing
1 to
12 comments |
