Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Generic/Unbranded DVD-R 4.7GB SONY........ 1x Plays on 9 DVD Players
Plays not on 1 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is Mixed
Read 11 comments
(85889 views)
Post comment
00 00 00 00 01 40 C1 FD 9E D8 50 00 02 89 0E 13 .....@....P.....
87 88 80 00 03 53 4F 4E 59 00 00 00 04 00 00 00 .....SONY.......
00 00 00 00 05 88 80 00 00 00 01 00 00 00 00 00 ................
Media color and text:
UPC/EAN Code:
A3458849
11 user comments
Showing 1 to 11 comments
Comments posted by tmaster from United States, August 01, 2005:
Sold by Tiger Direct. Must be pulls from sony since one 50 pack had no media information store on the disk. The other was not writable. Suspected factory rejects.
Additional information:
Price: $9 Purchased from: Tiger Direct Date purchased: July 2005
Burnt with AOpen DUW1608/12x at 2x
Burning reliability is Poor.
Media color is White.
Media text is blank.
Authoring/Burning comments:
nero DVDDecriptor
Comments posted by Matt from Other, August 07, 2003:
silver on top, purple on bottom. bought at walmart. 3 pack in a yellow box. appx. $2.25 each. plays ps2 backups perfectly on my v4 ps2. burns at 2x.
Price: $2 Purchased from: Walmart Date purchased: August 2003
Burnt with LG GSA-4040B at 2x using firmware A104.
Burning reliability is Good.
PC reliability is Good.
Console reliability is Good.
Media color is Silver.
Media text is DVD Recordable / DMR47 / R R4.7 / 4.7GB.
alcohol 120% for ps2 backups
Works fine on Sony Playstation 2
Comments posted by conkhi from Other, April 03, 2003:
hi everyone, I just bought a pack of 25DVD from PC club (in OK) and burned with my Sony 500A(2.0e) The first 4 dvd I either got them pausing (played on Samsung P-701) a little bit or skipping some frames. The most disturbed thing for me is Recordnow 4.56 keep rejecting my new blank DVD! it says that I need to put a blank one in ???!!!
I tried many Discs but hopeless :(
I did check the blank DVD by DVDinfo --> showing Sony 2x (generic).
I am new in DVD but experenced in PC --> I don't think I did anything wrong, I use p4 1.5Gig / 256MB with some very basic burning softwares.
thank so much, by the way I paied $29 for 25 DVDs at PC Club --> pretty expensive :)
Media text is Generic 4.7GB DVD-R 2x.
Comments posted by Dan from Other, April 03, 2003:
bought them @ allmediaoutlet.com under Lead Data and 20 were LD while the rest were Sony. Both can burn @2X w/ DRU-500AX 2.0c but not recommend it. I've burn about 10 movies already and 1 of 10 skipped @ the end of the disc cuz of 2X, others were 1X and it works fine. Even the PS2 v7 read the movies too. Would buy again but, allmediaoutler services is horrible. Sent the wrong order, contacted them but hung up on me 3 times, and try contact w/email and did not reply until 2-3 days later. I got the order about a month later.
Here's the Lead Data info:
00 6A 00 00 01 40 C1 FD 9E D8 50 00 02 89 0E 13 .J...@....P.....
87 88 80 00 03 4C 44 00 00 00 00 00 04 00 00 00 .....LD.........
HUB RING: A1 G20 01 S0005
Price: $0.9 Purchased from: www.allmediaoutlet.com Date purchased: March 2003
Burnt with Sony DRU-500AX at 1x using firmware 2.0c.
DVD reliability is Good.
Media text is None.
RNM DX 4.6 @ 1X and 2X for both the Lead Data and Sony.
Works fine on Pioneer DV-434
Comments posted by HuRtZ777 from Other, March 16, 2003:
Ok, I have done some extensive research on these Generic DVD-Rs from PC Club and have found a way to 100% positively identify whether or not it is a 1X Lead Date disc or a 2X Sony(Possibly Lead Data 2X disc found as Sony by the burner). It is a Sony 2X disc if the code on the inner ring(not the plastic hub ring with black writing)is K1-3083 10MAK. If the inner ring code starts with an A1 it is a 1X Lead Data disc. The black code written in the hub ring doesn't identify the two discs properly because I have seen Sony's and Lead Data's share the same A2VK... codes. The neat thing about this way of identifying them is the fact that you can see through the 50 pack plastic case and clearly see if you look carefully their inner ring codes(Remember inner ring is the unwritable ring on the outside of the hub ring on the top of the disc). My first 50 pack has about 40 Sony 2X discs and 10 Lead Data 1X discs in it. I have burned around 10 Sony 2X discs and 5 Lead Data 1X discs flawlessly on my Cendyne 4X(Pioneer DVR-105) and had only one coaster which might have been a buffer underun problem since I was doing extensive work during burning.(BTW the coaster was a Sony 2X disc) The physical difference I could tell between the Sony 2X and the Lead Data 1X discs is the Sony's purple die goes a mm closer to the outer edge of the disc then the Lead Data 1X disc. Other then that they look and feel exactly the same. I went down Saturday to get a second pack hoping to luck out, but they didn't have any Sony's with the K1-3083 inner ring code, so I settled for the A1 Lead Data 1X discs since they were only wanting $39.99 for a 50 pack. All 50 discs in my second 50 pack are Lead Data 1X and about 10 of them or so have very small bubble on the top of them. These bubbles are nothing be worried about since they aren't affecting the dye. All in all I haave found both the Lead Data 1X and Sony 2X DVD-R discs from PC Club to be of excellent quality and they should be very durable as time goes on and for only 80 cents a disc you can't go wrong!
Price: $0.8 Purchased from: PC Club (Local) Date purchased: March 2003
Burnt with Cendyne CDICD00209 at 2x using firmware 1.21.
Media text is K1-3083 10MAK (Sony 2X) A1....(Lead Data 1X).
Works fine on JVC XV-SA70BK
Works fine on Panasonic DVD-RP82
Comments posted by Cooly-O from Other, March 13, 2003:
There's some new questions, check out my post: http://www.dvdrhelp.com/forum/viewtopic.php?p=476626#476626
Burnt with Cendyne CDICD00209 at 2x using firmware ??.
Media color is Blue.
Media text is A2VK4309L262.
Verified with ADVDInfo. Also used Ulead's MovieFactory 2
Works fine on Apex AD-5131
Comments posted by simonko from Other, March 09, 2003:
LD - A2VK 4307 A093 13851
1x burn speed
Price: $1 Purchased from: www.pcclub.com Date purchased: March 2003
Burnt with Pioneer DVR-105 / DVR-A05 at 1x using firmware 1.00.
Media color is None.
Media text is silver top.
RecordMax Now 4.5
Comments posted by Mike from Other, February 26, 2003:
Nero indentifies this as Sony 2X media. Supposedly it is made by Lead.. something or other. Appears really solid plastic. No coasters after six or so disks. Plays in all DVD players I tried.
Price: $0.8 Purchased from: www.pcclub.com Date purchased: February 2003
Burnt with Pioneer DVR-105 / DVR-A05 at 2x using firmware 1.21.
PC reliability is Mixed.
Nero and Sonic MyDVD
Works fine on Mintek DVD-1600
Comments posted by pk from Other, February 19, 2003:
Ordered Accu(Silver/Purple) but got these.
Seems to be okay. 2x burns but not play in ps2.
Price: $0.8 Purchased from: crddvdrmedia Date purchased: February 2003
Console reliability is Poor.
Works fine on Pioneer DV-333
Does not work on Sony Playstation 2
Comments posted by Slomer from Other, February 03, 2003:
Same as above. Bought a 50 pack and they were ritekg3. Went back hoping for more and got these. Had to haggle with guy in store to get them for $42+tax because they raised price. Also have gotten That's Write ones from PCCLUB... so far everything I buy at pcclub burns perfect 2x in a04 with hacked firmware.
Price: $0.8 Purchased from: pcclub Date purchased: February 2003
Comments posted by Ed Woods from Other, February 02, 2003:
I purchased a 50 pack 2 weeks ago from pc club and the were the ritek g3. This time I purchased the 50 pack and they are Sony. These are burning 2x on my sony dru500a fw 1.g
Price: $0.8 Purchased from: http://www.pcclub.com/ Date purchased: February 2003
Burnt with Sony DRU-500A at 2x using firmware 1.0g.
Media UPC/EAN code is A3458849.
Record Now DX 4.6
Nero 5.5.10
DVD2ONE rocks
Works fine on Apex AD-1200
Works fine on Apex AD-1201
11 user comments, Showing 1 to 11 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
