Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Generic/Unbranded DVD-R 4.7GB GSC001 1x Plays on 7 DVD Players
Plays not on 2 DVD Players
Burn Reliability is Good
DVD Reliability is Mixed
PC Reliability is Good
Console Reliability is N/A
Read 7 comments
(69394 views)
Post comment
00 42 00 00 01 40 C1 FD 9E D8 50 00 02 87 0D 13 .B...@....P.....
88 99 80 00 03 47 53 43 30 30 31 00 04 20 20 20 .....GSC001..
20 20 20 00 05 00 00 00 00 00 01 00 00 00 00 00 .............
Media color and text:
UPC/EAN Code:
No
7 user comments
Showing 1 to 7 comments
Comments posted by Leon from United States, April 19, 2005:
PCUSA brand from Ecost, I had no problems with this media
Additional information:
Burnt with NEC ND-3520A at 4x using firmware 1.04.
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Media color is Silver.
Media text is none.
Media package type is Cake Box. Number of discs 10.
Authoring/Burning comments:
nero 6.6, dvdxcopy
Works fine on Sampo DVE-662
Comments posted by motumbo from Italy, February 23, 2004:
I burned ten of them, no coasters so far
Burnt with LG GMA-4020B at 2x using firmware A109.
DVD reliability is Mixed.
Media text is none.
Nero 6.3.0.3
Works fine on SONY DVP-NS730P
Does not work on Amstrad DV-303
Comments posted by Beto from Other, October 04, 2003:
No comments
Price: $2
Burnt with Pioneer DVR-106 / DVR-A06 at 2x using firmware 1.02.
Media text is Network.
Works fine on KiSS DP-450
Comments posted by fallen_br from Other, August 09, 2003:
Almost flawless media, at 1x and 2x. Data is 100% OK.
Price: $2
Media color is Blue.
Media text is PowerDisc.
Nero 6.0
Comments posted by J.Paulo from Other, January 23, 2003:
It's the worse media in market.
Go away from it!
Price: $1.9 Purchased from: Local store in Brazil Date purchased: September 2002
Burnt with Pioneer DVR-104 / DVR-A04 at 1x
DVD Maestro and others
Comments posted by greydog from Other, October 15, 2002:
This is an update to the RapidScape DVD-R (unbranded) media report I posted here. I burned all 25 of the DVD media purchased from Preso Shopper and only had on disk that made a bad burn.
Comments posted by greydog from Other, September 29, 2002:
Bought the 25 pack on spindle for $34.00
. Burned 15 on my Pioneer 104 with no problems. The disk has no mfg information on it and Prestoshopper sells the disk as RapidScape DVD-R Media (unbranded) Disk is purple in color.
Price: $1.4 Purchased from: www.prestoshopper.com Date purchased: September 2002
at 1x
Data file burned to DVD with Nero 5.5.9.9
I create my home movies (Cannon Optura PI camera) with Premier 6.0, render them in TMPGEnc V. 2.5.44.152 using the same settings (exception being I select video+ audio as the stream type) suggested in the tutorial supplied by http://pwp.netcabo.pt/0165394101/TMPGEnc_Template.html
Have burned to disk using Ulead DVD Movie Factory and Sonic MyDVD 3.5
Works fine on Mintek DVD-1600
Works fine on Pioneer DV-440
Works fine on Sony DVP-S330
Does not work on Samsung DVD-V1000
7 user comments, Showing 1 to 7 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
