Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Euro Max DVD-R 4.7GB TYG02....... 8x Plays on 2 DVD Players
Plays not on 1 DVD Players
Burn Reliability is Mixed
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is Good
Read 2 comments
(38024 views)
Post comment
00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 87 0D 10 .l...@....R.....
66 78 80 00 03 54 59 47 30 32 00 00 04 00 00 00 fx...TYG02......
00 00 00 00 05 AA A2 22 22 20 02 00 06 08 0E 11 ......."" ......
Media color and text:
Gray EURO MAX 4.7 gb 120 min 8x DVD DATA M
UPC/EAN Code:
No info
2 user comments
Showing 1 to 2 comments
Comments posted by Nuwanda from United Arab Emirates, November 25, 2005:
Great so far. Burnt around 10 DVD's with no problems at all using a LiteOn SOHW-1653S.
Additional information:
Purchased from: Dubai, UAE Date purchased: August 2005
Burnt with Lite-On SOHW-1653S at 4x
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Console reliability is Good.
Media color is Silver.
Media text is Euro Max DVD-R 8X 4.7GB 120min.
Media made in Taiwan.
Authoring/Burning comments:
Burned with Nero 6
Works fine on Sony Playstation 2
Comments posted by LittleMato from United Arab Emirates, October 22, 2005:
In Nero 6 it shows that the media can be burned at 16x, but all the burns (8 disks) failed. At 12x 3 disks failed and 2 disks did burn OK. At 8x all the medias burned OK. The speed was much much slower than it had to be, for ex. 4.5 gb were burned for about 15 to 20 minutes (no matter if it was 12x or 8x).
Conclusion: very bad medias. Do not use it!!!
Purchased from: Dubai, UAE Date purchased: September 2005
Burnt with BenQ DW1620 (Pro) at 16x
Burning reliability is Poor.
PC reliability is Mixed.
DVD reliability is Mixed.
Media color is Gray.
Media text is EURO MAX 4.7 gb 120 min 8x DVD DATA M.
Works fine on LG DV-7942P
Does not work on LG DV-7942P
2 user comments, Showing 1 to 2 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
