Datawrite Red (V3) |
DVD-R |
4.7GB |
AN31........ |
4x |
Plays on 9 DVD Players
Plays not on 1 DVD Players
Burn Reliability is Good
DVD Reliability is Good
PC Reliability is Good
Console Reliability is Good
Read 10 comments (82472 views)
Post comment |
Complete Media
Code (DVDInfoPro/DVDIdentifier):
00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 87 0E 15 .l...@....R.....
98 9A 90 00 03 41 4E 33 31 00 00 00 04 00 00 00 .....AN31.......
00 00 00 00 05 CC C0 00 00 00 01 00 06 0B 10 11 ................
Media color and text:
Red Datawrite Red (V3) 4.7GB General Purpose 4x DVD-R UPC/EAN Code:
5060043493257
10 user comments
Showing
1 to
10 comments |
Comments posted by Ian Walker from United Kingdom, November 14, 2004:
Had mixed results with Datawrite Reds. The V3 seems a bit better than previous incarnations, but on the last batch the die used seems weak in the centre of the disc (visibly pale under a lamp). The result is that it will play on my Wharfedale 750s until it reaches the dodgy bit, and then the disc won't play any further. This has affected about 80% of discs burned from my camcorder footage - very annoying!!!
They will play back on my Sony DVD-ROM drive on the PC however, as the laser seems to be more accurate.
I shall be looking for a different brand next time.
Additional information:
Purchased from: Local Computer Fair Date purchased: August 2004 Burnt with Pioneer DVR-107 / DVR-A07 at 4x using firmware 1.13. Burning reliability is Good. PC reliability is Good. DVD reliability is Poor. Media color is Red. Media text is Datawrite Red (V3). Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Ulead DVD Movie Factory 3.5
Nero v6.6 Does not work on Wharfedale 750 |
Comments posted by mk from Belgium, November 07, 2004:
very poor media
Price: $10 Date purchased: November 2004 Burnt with Samsung TS-H552B at 2x using firmware TS04. Burning reliability is Poor. PC reliability is Poor. Media color is Red. Media text is Datawrite Red (V3). Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: NERO 6.6.0.1 |
Comments posted by komutan from Belgium, November 03, 2004:
DVD media certified 4x burned only at 2x vith samsung ts-h552b TS04!!!!
Price: $10 Date purchased: November 2004 Burnt with Samsung TS-H552B at 2x using firmware TS04. Burning reliability is Mixed. PC reliability is Mixed. Media color is Red. Media text is Datawrite Red (V3). Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: NERO 6.6 |
Media image
 Click to enlarge |
Comments posted by Red from Italy, October 18, 2004:
Media works very well at 4x. No errors. Linear (no spikes) Nero CD-DVD Speed graphic!
Price: $0.5 Purchased from: www.nierle.de Date purchased: July 2004 Burnt with NEC ND-2500A at 4x using firmware 1.07v2b5. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Red. Media text is Datawrite. Media package type is Cake Box. Number of discs 25. Media UPC/EAN code is 0404050419-455. Authoring/Burning comments: Nero 6.3.1.20 Works fine on Elta 8883 Works fine on KiSS DP-1000 |
Media image
 Click to enlarge |
Comments posted by Player from Netherlands, September 23, 2004:
1 of 25 would not playback on dvd player. Good media and very cheap
Price: $7 Purchased from: www.ddvd.info Date purchased: September 2004 Burnt with Lite-On LDW-811S/851S at 4x using firmware GS0K. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Red. Media text is Datawrite Red (V3). Media package type is Cake Box. Number of discs 25. Media made in China. Authoring/Burning comments: Nero 6 Works fine on Pioneer DV-535 |
Comments posted by juustas from Finland, September 10, 2004:
No coasters yet. Exellent and very cheap media!
Price: $0.4 Purchased from: www.nierle.de Date purchased: September 2004 Burnt with Sony DW-U14A at 4x using firmware 1.0d. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Red. Media text is Datawrite Red (V3). Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Nero 6.3.20, Veritas RecordNow DX 4.6
Works fine on LG 5193
Works fine on ps2
Works fine on xbox
Works fine on LG 5193 |
Media image
 Click to enlarge |
Comments posted by Hitme from Denmark, August 01, 2004:
Made 100+ DVD-r With these at 8x so far no problems
Burnt with Pioneer DVR-107 / DVR-A07 at 8x using firmware Patched 1,13. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Red. Media text is Datawrite Red (V3). Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Nero +DVD Decrypter Works fine on Sony DAV-SC5 |
Comments posted by Dagghe from United Kingdom, June 12, 2004:
No comments
Price: $0.6 Purchased from: www.ebay.it Date purchased: May 2004 Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.33. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Console reliability is Good. Media color is Red. Media text is Datawrite RED v3. Media package type is Cake Box. Number of discs 25. Works fine on Sony Playstation 2 |
Comments posted by macutmore from United Kingdom, June 10, 2004:
The version 3 disc is excellent value for money and seems fairly compatible with my Sony DRU-510A burner, unlike the version 2's which were AWFULL!!
Only 1/25 coasters compared with 15/25 with Version 2's. To be honest though, I'd buy the yellows because they are first rate and are only a few pounds more.
Purchased from: svp communications Burnt with Sony DRU-510A at 4x using firmware 1.0f. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Red. Media text is Datawrite Red (V3) DVD-R 4.7GB 4x. Media package type is Cake Box. Number of discs 25. Authoring/Burning comments: Nero 6.3.1.15 |
Comments posted by mike kraft from France, May 30, 2004:
No comments
Purchased from: www.cdr-by-mail.co.uk Date purchased: May 2004 Burnt with Pioneer DVR-106 / DVR-A06 at 4x using firmware 1.07. Burning reliability is Good. PC reliability is Good. DVD reliability is Good. Media color is Red. Media text is Datawrite Red (V3) 4.7GB General Purpose 4x DVD-R. Media package type is Cake Box. Number of discs 25. Media UPC/EAN code is 5060043493257. Authoring/Burning comments: nero 6 Works fine on Cyberhome CH-DVD 500 Works fine on Philips DVD625 Works fine on Pioneer DVR-5100H |
10 user comments,
Showing
1 to
10 comments |
