Media size:
Burn speed:
Order by: Hits per page
Burnt with this DVD Writer:
DVD Player Media Comments:
Datawrite (Printable) DVD-R 4.7GB TTG01....... 4x Plays on 5 DVD Players
Plays not on 1 DVD Players
Burn Reliability is Mixed
DVD Reliability is Mixed
PC Reliability is Mixed
Console Reliability is Mixed
Read 4 comments
(53490 views)
Post comment
00 00 00 00 01 40 c1 fd 9e d8 52 00 02 86 0d 13 .....@....R.....
66 78 80 00 03 54 54 47 30 31 00 00 04 00 00 00 fx...TTG01......
00 00 00 00 05 88 80 00 00 00 01 00 06 08 0f 11 ................
Media color and text:
White None
UPC/EAN Code:
No info
4 user comments
Showing 1 to 4 comments
Comments posted by Mike Gibson from United Kingdom, March 08, 2005:
Having tried a number of different applications to burn DVD's using my combination of Sony DVD writer and Datawrite DVD-R I am gong to put both in the bin.
Additional information:
Burnt with Sony DW-D22A at 4x using firmware BYS1.
Burning reliability is Mixed.
PC reliability is Poor.
DVD reliability is Poor.
Media color is White.
Media text is Datawrite Printable surface 4x DVD-R DataSafe.
Authoring/Burning comments:
Nero 6 / Adobe Premiere / Pinnacle Instant CD/DVD
Does not work on Shinco SDP 1731A
Comments posted by marco from United Kingdom, February 08, 2005:
No comments
Purchased from: bigpockets
Burnt with Pioneer DVR-105 / DVR-A05 at 4x using firmware 1.30.
Burning reliability is Good.
PC reliability is Good.
DVD reliability is Good.
Console reliability is Good.
Media inkjet printable reliability is Good.
Media text is none.
I've burned about 30 of these so far (mainly for movie and PS2 backups) and all have worked perfectly - no coasters.
The only thing I don't like about them is that they are not printable all the way to the hole.
Works fine on Cyberhome CH-DVD 402
Works fine on Ronin DVD P215F
Works fine on Ronin DVD P703
Comments posted by teran doc from Italy, January 19, 2005:
Bad media!! Tested with Nec3500, Pioneer 108, Toshiba Sd-r5372, Nec2510, Liton 811s and LG4020b all with the latest firmware. All have errors, probably a manufactoring problem, about 70% of the disc. DON'T BUY IT!!!
Burnt with Toshiba SD-R5372 at 4x using firmware TU53.
Burning reliability is Poor.
PC reliability is Mixed.
Console reliability is Poor.
Media text is none.
Comments posted by David Gilbert from United Kingdom, January 01, 2005:
These must be TDK rejects sold by Datawrite as 60% of the cake had read errors after burning!
Of these you could even see damage to the dye (Spots)!!
Price: $10 Purchased from: Ebuyer.co.uk Date purchased: October 2004
Burnt with OptoRite DD0405 at 2x using firmware 1.05E.
DVD reliability is Mixed.
Media text is None.
Nero 6.6.0.1
Works fine on Acoustic Solutions TE 118A
Works fine on Alba DVD113
4 user comments, Showing 1 to 4 comments
Affiliates: free-codecs.com
©1999-2025 videohelp.com
