VideoHelp
WHAT IS
Site layout:
Default
Blue
Site width:
Cookies must be enabled.
p
Printer
Friendly
©1999-2010
videohelp.com
dvdrhelp.com
vcdhelp.com
Contact Us
Privacy Policy
Sefy's DVD Backup Guide v2.6
 Updated October 3, 2004
Use the blue menu here below to navigate.
Sefy's Complete DVD Backup Guide v2.6
Troubleshooting
Here I will try to cover all the problems you may encounter, and hopefully help you fix them.
  • In Order for TMPGEnc to recognise D2V files, you MUST have the VFAPI and the DVD2AVI.VFP file located where the TMPGEnc.EXE file is! it will NOT work any other way! It is also sometimes helps to use the Forced Film option in DVD2AVI, but only if you are still unable to open the D2V files with TMPGEnc. (suggested by msfox)
  • In some DVD movies the Audio Track is located on the second track, so you might want to try in DVD2AVI to rip the secondary Audio Track, if you are not sure which Audio Track to choose, open the Chapter-X-Tractor text file and you can check in there.
  • Also in some movies the Audio Track is a DTS and DVD2AVI is incapable of handling it and converting it to WAV, I would recommand you find a diffrent track, there is usually both DTS and AC3 tracks, use the information files by either Smart Ripper or Chapter-X-Tractor to find out if your movie has an AC3 track and if does, then on which track it is, and if there isn't find the next best alternative which would be the 2ch track.
  • Make sure when you encode the movie that you use the currect Template for your movie, an incorrect Template will cause A/V sync problems and not to mention the resolution will be distorted (if you use PAL on NTSC and NTSC on PAL).
  • If you are having problems copying the Movie VOB files to your HDD, I suggest you check your ASPI Layer, the ASPI that comes with Windows9x, Millenium are not good for ripping, update them, and Windows2000/XP does not come with an ASPI Layer at all! make sure you download the latest ASPI for your system, use ONLY WinASPI v4.60 Build 1021 (work on 98/Me/2000 and XP!)
  • If Smart Ripper or any other of the DVD Copying programs are unable to access your DVD Movie, try to first play the disc using any Software DVD Player, and then try to re-run the program.
  • Because the Copying program always selects as default the longest running title of the DVD, it might select the wrong title, So make sure the VOB's that were copied are indeed the VOB that belong to the movie itself and not the Extra features (e.g. Pearl Harbor).
  • FlaskMPEG does NOT come with the Panasonic MPEG1 Plugin, you must get and install the plugin on your own, it is NOT a freeware.
  • DVDx and FlaskMPEG require the IFO file, so make sure you rip that you select "Files Mode" or "Backup Mode" in your ripper.
  • There is a bug in VirtualDub v1.4.10 which causes the Handler not to work, so use the Handler installer from v1.4.9 or switch to the latest version v1.5.1 as the bug was fixed in the later releases.
  • When having A/V Sync problems with DVD2AVI and TMPGEnc, If DVD2AVI reports the first few seconds of the video is NTSC (the lead-in) and then the rest of the video is FILM. By starting the encode using the "Force Film" option, should fix Audio/Video Sync problems. (thanks to vcddude)
  • If your DVD media is giving you problems during the copying step, use DVD Decrypter and Check the FAST ERROR SKIP box, set the HARDWARE READ ERROR RETRIES to 0, set the SOFTWARE READ/WRITE ERROR RETRIES to 0, check the IGNORE READ ERRORS box. (suggested by: 8dragon8 from VideoHelp forums)
  • If your source Audio has a Low Volume, then it would be recommanded to use a tool to boost the volume before the encoding, if you are using TMPGEnc, simply click on "Setting" button and then select the "Audio" tab and click on the "Setting" next to the "Audio Edit" option. On the Left Corner you will have "Change volume" and under it the "100% Normalize" option, use this to increase the volume level and then use the "Play" button to check if it's high enough, click on the "OK" when you are done.
