This machine has a couple of nice features, and would probably be a great addition to your stack of video equipment ... just not for the reasons you may think. I will be keeping mine.
THE BAD:
As a DVD recorder, like all other Panasonics before it, the MPEG-2 encoding quality sucks. Beyond about 2 hours, especially with an imperfect signal, expect your video to be turn into macroblock-ridden kibble. Barely better than a VCD. Anybody that wants to casually transfer VHS to DVD, or looking to use it for longer than SP mode, should probably run for the hills. Any machine but this one.
The new "DIGA" technology was a waste of R&D. They should "dig a" hole in the ground and bury their research. The 12-bit A/D processing, which is still not confirmed 100% across ALL documentation, makes no difference, if it really exists here. This is all more Panasonic smoke and mirrors to try to claim they have fixed a crap-quality encoder. They have not.
They wasted their time, again, with making a 720x480 low-bitrate signal. Why is this? Why not spend effort into making 352x480 not have macroblocks. We still have block, just now at twice the resolution! Ugh! Fix it, you morons!
The unit itself has to have black levels BOTH set to darker in order to come close to the black qualities of cable, terrestrial and VHS signals on the systems tested here. As has been discussed in more recent IRE-related articles, standards is out the window anyway. The sad part is regardless of what black level settings are made, the unit seems a bit muddy, a lack of some COLOR contrast. The actual BLACK levels are a bit too dark in DARKER, and far to light in LIGHTER. Where's the middle setting?
It still has not followed in the footsteps of the LSI encoder chips, which remove CHROMA FLAWS from the signal. Why must this be so hard? Red/blue mist on VHS tapes is a SEVERE problem! It should be dealt with.
Anybody that wants to use this as a recorder, I'd suggest against it. There are better recorders, in terms strictly of VISUAL QUALITY. Good color, good contrast, no blocks, no mosquito noise, etc.
THE GOOD:
Alright, so why am I keeping this unit? Filters. Not the DNR filters, no. Those suck. I compare Panasonic DNR to a settings of 1-1-1 in TMPGENC NR. Almost non-existant.
The ES10S has some sort of TBC-like filters, as have others before them. But this one is different. It works. It's stronger. It helps. AND IT HAS PASS-THROUGH! Though it is "claimed" as a TBC, there have been varying reports that it is a sync-related filter, which would fit in with the viewed results.
It removes skewing at the top of damaged VHS tapes. I ran this thing through the ringer. Tapes I had previously given up on were suddenly acting a bit more cooperative.
As a restoration processor, this has value. I can feed it a signal from the JVC HR-S9800 (also tried a HR-S3800U and SR-V10U), directly into the Panasonic DMR-ES10S, into an Elite BVP-4 Plus to correct the color/contrast, into a DR-1000 for detail work to improve the VHS source, and then directly into the higher quality JVC DR-M10S DVD recorder.
The output is a STABLE signal (thanks to JVC S-VHS + Panasonic ES10), EXCELLENT COLOR/CONTRAST (thanks to proc amp), HIGH DETAIL (thanks to detailer), and CLEAN DVD ENCODE (thanks to JVC recorder).
Prior to the ES10S, Panasonic recorders did not really have pass-through. The effects of it's filters were limited, often only seen after the recording was done.
I doubt I'll ever record a DVD on this unit again, but it earned itself a place in the stack of hardware. It combats one of the few errors that I ever run into and cannot always fix.
If I think of anything else, I'll be sure to add it.
PS - I will never call my machine a "Panny". That sounds so wussy.
.. edited for spelling ..
Results 1 to 30 of 35
I (and MANY others) have recorded up to 3 hrs with no macroblocks.
The Panasonics may not be the best but what you have said is totally false. You must own a defective machine. I suggest you return it. -
I have been testing Panasonic machines since the beginning. E20, E30, E50, E55, E80, E85, and now ES10. Nothing has ever changed, in terms of encoder quality. The machine is not defective, it is merely an inferior encoder chipset (homegrown Panasonic stuff, which has never been very good, even as the software version). A few may be worse than others (E50, E55), but the problem still exists across all of them.
Any time you feed it an imperfect source (which is ANY VHS tape, ANY terrestrial antenna signal, etc) it spits out blocky/mosquito-filled images. Even on a 25" tv this is super-noticeable. By the time you get to those large 30-50s" screen, people are easily raising hell about image quality.
If you feed it a super-clean satellite or perfect DV signal, it may be fine at 2 hours. But still has trails of mosquito noise from time to time (yes, newly created noise, not transposing source noise). As you leave this optmized 2-hour spec, the error compound repeatedly. At 4 hours the video is highly obnoxious.
If anything, the 2-hour mode may have gotten cleaner as models have gone by, because I can tell the noise of the E20/30/50s series was gone in the E80s series. Or at least signicantly reduced. Again, just the 2-hour SP mode. It looks a lot closer to XP now.
Panasonic has playback filters (softens) on it's recorder (which can be turned on or off, often set ON by default), so you may not notice block noise or mosquito noise on the recorder it was made on. But even then, you just soften the blocks. They become fuzzy blocks, still noticeable as an error, just harder to finger (kind of a gooey digital mess). As soon as you put it in any other player, including even the best ones, the errors are clearly visible unless you soften it. Even the most advanced DVD player filters cannot clean up these blocks.
I'll post tests image of this in time, when I have some free time. It's really quite ugly. They need to fix it. All the ES10 has done is make the blocks exist at twice the resolution.
I wish it would look good. Then I could use it as a recorder, instead of having to chain it into another recorder or capture card. As it stands, the image quality from the JVC and ATI cards are all superior. Which is a real shame, considering the nice stabilizer it has inside.Want my help? Ask here! (not via PM!)
ATTENTION!
Any additional comments in this thread need to be related solely to the topic at hand, which is the Panasonic machine being reviewed. Personal comments will be removed.
Feel free to add your own reviews, ask questions, etc ... about the machine.
Threadjacking is against the forum rules, and will not be tolerated.Want my help? Ask here! (not via PM!)
I own a Panasonic E-80 and used it for archiving old VHS. I usually do the FR mode to about 2h46min to maximize the space of a DVD-R. There are definitely "macroblocks" visible and I'm only watching it on a 21inch TV I bought 9 years ago- I shudder at the thought of watching it on a larger TV. However, this is still tolerable to me; it's not as bad as the 6 hour EP mode (which looks more like VCD quality to me). And I say this because the "quality" on the E-80 (for my archival purposes) was decent enough for me to purchase a E-85 several months ago (used the E-80 for over a year and archived hundreds of tapes). The E-85 just plain SUCKS!!!! I compared both the E-80 and E-85 on identical recordings of the same broadcast, and on the same recording mode, the E-85 looks noticeably worse (with the blocks) and even my non-discerning friends agree. Several other posters have said the same thing on the avsforum, so neither Lordsmurf nor I are making stories up. I don't understand why there's a difference between the E-80 and the E-85, but what was still acceptable on the E-80 to me is not on the E-85. That unit records SP at a quality like the LP on the E-80. I can't believe it looked so bad.
So for the ES-10...... Since it sounds like there's no real signifcant improvement over the last generation of Panasonic recorders, I'll wait for better units. -
Since you like removing comments that don't agree with your opinions, I will try to word my statements in such a way that will be acceptable to you. The Pansonic machines are not garbage and create excellent copies, most dvd recorders create substandard recordings after 2 hour recordings anyway.
If the source is good then the Panasonic will do as well and even better than some recorders on the market today. This is why most reviewers like the Pannys.
My opinion 8)Do unto others....with a vengeance! -
Originally Posted by lordsmurfDo unto others....with a vengeance!
I'm the HAPPY owner of the ES10. This is my first foray into the DVD Recorder world and for what I intend to use it for, I couldn't be more pleased.
My main interest was to be able to transfer our 8mm camcorder tapes to DVD and to retire our VCR. I have no interest in transfering any VHS.
Like others have stated in this and other forums, it all depends on the source material. The few camcorder tapes that I have transferred, so far, look just like the original to me, whereas when I have recorded a cable signal, it varies with the channel.
Most of the disagreements, in the forums, seem to be over the LP or EP settings. Having only used a VHS for the past 4 years, ( I was always a BETA person), I always used the SP. Even with the BETA, I always the best setting.
Why would someone want to use the slower settings?
Lordsmurf, who I've learned much from on his "No More Coaster Site", seams to use his recorders for different reasons that what I would, so I may not be for him but it is for me. -
Originally Posted by twosocks
The chroma issue is definately a true point raised by Lordsmurf. I've found a workaround for that issue that usually works most of time. I prefer not to use the s-video hookup because the chroma effect shows almost throughout the entire video. Instead I use the composite hookup and found the video to be very good, showing little to no chroma effect.
This is an issue that Panasonic should have addressed, but from what Lordsmurf has written it seems that this problem still exsists. Other than that I am very happy with my Panasonic recorder. I'm always looking for a better machine but I'm very leary now as to whom to believe anymore.Do unto others....with a vengeance! -
Originally Posted by ejai
We use what we can for now, floundering from machine to machine as per our needs. Which is probably the best solution and best advice for anybody anyway. Nothing perfect exists, every line has flaws. For me, the perfect machine is VERSATILE, with the ability to improve the signal (merely transferring is not good enough, harming it is unacceptable). This versatility must also extend to the time, allowing high quality recordings as little as 1-2 hours, or even up to 3-4 hours. Few machines can perform these two feats, some better than others.
My other two choices are easily the LiteOn/ILO series, and the Pioneer series. But you have to watch for the errors on those machines too (see the "fatal flaws" thread for more on those).
I managed to hack and modify the physical unit for my LiteOn, so that it has no errors (or rare to have errors). The LSI chip corrects common chroma errors on VHS/broadcast, it will ignore MV or false MV, and it has a very clean 2- and 3-hour modes, and a decent 4-hour mode (brief mosquito noise, but at scene changes only).
The Pioneer series machines work very well, has nice quality at both 2- and 3-hour settings (using FR as needed). Does not remove chroma, but it great for clean signals, transposes source very nicely. It will not fix a signal, but will not harm it either. Having been satisfied by past tests, I wanted to get one to replace my last personal use VCR, but spent my Pioneer money on the ES10. Will have to wait a while to get one now.
It seems we are on the same near-futile quest for the perfect recorder. I found the JVC is as close as it gets, though chaining it to other hardware makes it much more powerful. I have never been able to reproduce your JVC problems (thankfully!), but understand if you want to give up on JVC. Try a Pioneer. Try a LiteOn/ILO. Pioneer first.
What I can say is that the ES10 is ABSOLUTELY NOT the perfect machine (regardless of Panasonic marketing BS, or bribed magazine articles). It has added some nice features compared to earlier generation of Panasonic systems, but recording quality still is just not there. The hunt continues ....
Finally, I would not fault the average consumer for grabbing an ES10. It does decent 2-hour, and if you can put up with macroblocks on extended times (former satisfied VCD users), then go for it. The filters can help stabilize VHS pretty well. No miracles, not a full TBC, no magic ... just some nice filters to help stabilize. The $199 price is also very competitive. But the machine will add noise to your VHS recordings, or extended off-air recordings. You have to understand that.Want my help? Ask here! (not via PM!)
Thanks Lordsmurf, it gives me another option to consider. I am thinking about waiting for the HD recorders, but I am a bit let down about some of the security features that will be associated with HD recorders. I have to research this issue more closely. 8)
I think ejai is talking about the broadcast flags of the future.
(I should add that I find my Pioneer 520 a bit too dark in certain scenes as well.)
I have never tried the JVC or Pioneer but find it hard to believe they could improve on what I get from the Panasonic, as I simply don't see anywhere where there could be an improvement.
Again I don't know what you mean when you say "add noise". This would seem to be something that would be easily seen however sure cannot detect any on any of my recordings.
Here is a capture from a DVD created on the Panasonic DMRE20 transfered from a EP VHS tape.
Note I had to decrease the resolution due to the file size limits.
The DMR-E20 will never improve quality. That machine makes video grainy (mosquito noise) and blocky often even at 2-hour SP mode. It also has an IRE and gamma issue that is just off the charts. Playing those DVDs in a USA player will be super bright and very washed out. Not good at all. The DMR-E30 was almost as bad. Many of the same errors.
If you tv is bad, or eyesight is bad, you may not notice. Or if your tv is too dark, maybe. But it has to be REALLY dark.
The Panasonics, early ones at least, may SLIGHTLY stabilize a video, but not by much. This may be what you refer to as "improving" the VHS. The advantage of the ES10 is the filters are far improved, seemingly, and are also pass-through. I use my ES10 for filters alone. The recording quality sucks compared to other equipment at my disposal.
Still images are entirely worthless, in regards to DVD recorder tests, as they do not show motion. You must have video clips of at least 10-30 seconds or more to judge the quality of a recorder, and the test clip must be an average one, not a cherry-picked clip. Not to mention the little-bitty image on the webpage is not the size of ever the smallest of tv sets.
The Toshiba actually has better quality, but it's not the greatest player or recorder because it too has a bad IRE level. Though that may not be consistant (IRE levels), as reports vary (not sure why). The Toshiba does not make a blocky or grainy image.Want my help? Ask here! (not via PM!)
What I was referring to when I said improves quality was it removes some of the noice on poorer recordings or ones that are somewhat grainy.
Also if you look at a VHS tape and find a straight edge, like a door or door jamb you will notice it appears very jagged however once transferred using the Panasonic that affect is gone or at least minimized.
My TV is not bad and although my eyesight may not be what it was 20 years ago I'm not blind either.
I am far more fussy than most people I know when in comes to quality and while I can nit pick the Panasonic I sure can't find the problems you have mentioned unless I record in EP mode, which is never aside from testing. If I experienced the problems you have sighted I would have returned it immediately like I did with the Toshiba, as the quality there was definitely inferior to the Panasonic.
Again I can't knock or comment on the JVC or Pioneer as I have not tried either but can say I have not experienced the problems you have mentioned on the Panasonic. -
If you have a super-sized tv set, and it's a good one, your setup may slap a soften filter across the image by default, to lessen the "blow up" effect. This may hide mosquito noise. But you'd easily still see blacks, though more contorted when soft, not easy to see as blocks, just smudges.
But the blocks and noise are there. It's a common complaint.Want my help? Ask here! (not via PM!)
@ jackedup
I rather liked your pic. It really looked good, fwiw.
But, I agree w/ LS on pics. They help demo certain aspects of test,
but not thourgh enough. Plus, when demoing your own set of tests, they
really should be based on something that everyone has (or has access to)
for there own tests/thursts. I hate it when a user throws in a completely
original (never used in any previous tests) in a case scenario demo (like yours)
So, using that same test clip (in your pic for instance) throwing a
video sample (vob) would be ok, but however, then others won't be able
to reproduce for their own satisfaction cause of the lack in source materials.
I just wish we would all use the same script when testing new things.
I also agree w/ LS on the issue with transfering DVD to VHS (then capturing
from it) You will get washed out or bad looking video output. I have in
every test scenario I ran through it.. (using my "Fifth Element" DVD) and it
just looks so bad. But, according to your pic above, your DVD -to- VHS
and "dvd recorded" final results look pretty good to me (IMO, and TBO, to be
honest)
Can you post your specs:
* VCR
* DVD palyer
* other
Anyways.
I did like your pic though, as it was very clean, though from a DVD medium
-vhelp 3285 -
I've had the Panasonic DMR-ES10S for a couple weeks now and in my tests I've found the PQ to be great in XP mode but a bit blocky in SP mode which is unacceptable. Don't care about LP mode, I just wish my unit worked well in SP. Unfortunately I'm returning the unit which is a bummer because the price ($199) was right.
I would also say that I think I experienced the mosquito noise you were talking about. I hooked up the DMRES10 to my VCR, and then went from the DMRES10 to the DMRE55 and recorded both at the same time from the same tape. When I played the two DVDs back using picture in picture to compare the two I found what I assume you are referring to as mosquito noise from the DMRES10 but not the DMRE55, which surprised me. I then decided to record from satellite to both however as the DMRE55 was already connected to the satellite I ran it the other way and had the DMRES10 as the last item in line before outputting to the TV. Now I saw the mosquito noise on the DMRE55 but not on the DMRES10 from the same recordings so it would appear the only time I see mosquito noise is when the output is run through anther piece of electronics before going to the TV. -
Originally Posted by vhelp
@ jackedup
Your setup is interesting. Still, its hard for me to believe the
pic you posted, (but there it is) given your setup:
* DVD -to- VHS -to- dvd_recorder
(It looks to me that your DVD player seems to have its black-level
reproduction output very close to what it should be, and your VCR is
capturing/recording it very accurately)
It could be the units capabilities to handle these dvd-vhs scenarios.
In my case:
* Apex_AD-1500 -to- JVC_S-VHS_HR-S3910U
..and my colors were so washed out or too dark, or whatever.., depending
on which scenario of configuration/hardware I used.
Did you turn on any filtering on your dvd_recorder unit ??
I was wondering.., if you have the "Fifth Element" DVD disk, could
you try the same test scneario and post your results (pic) here ??
(the scene I tried this with was, where they start the scene at the
McDonold's, and the two Polices are recieving their order, and the
radio message comes on to keep a look out for.. during all this)
If its too much trouble, I applogies..
..Otherwise
Anyways, thanks for your input.
-vhelp 3288 -
Lordsmurf
I believe you mentioned in another thread that the ILO was one of the best recorders for transferring VHS to DVD. Is there a particular model or any model? I thought I might pick up a used one on EBay just to compare it to the Panasonics I have but don't want to buy one that isn't the one you were talking about.
I have seen a DVDR04 listed. Would that model me one of the ones you were referring to?
Thank you -
The two major models are:
* DVDR04 - (+R/ +RW disks) (non-hard drive)
* DVDHR04 - hard drive model
Both produce same results. And yes. Many claim it is very good
for VHS, which is dependant upon the VCR capabilities (ie, s-video;
black-level; other color space conversion hardware; etc)
I have the DVDR04 and Pioneer 220-S units
-vhelp 3290 -
Also I will get back to you in a bit on your other post, just been tied up for a bit.
Thanks again -
No rush. I look forward to more VHS sample pics like the above
-vhelp 3293 -
Ok. I re-read and re-read through this interesting topic.
This time, I cought my mistake, and missunderstood the process
and thought you used the following in your pic demo:
* VCR[EP mode] -> Sharp_dvd_player -> DMR-ES10S[ram disk]
After re-reading numerous times this topic, it seems to me, that
your process was actually:
* VCR[EP mode] -> DMR-ES10S[ram disk] -> powerdvd[copy = 16-235]
(the pic still looks good, though it explains the 16-235 look)
@ LS
Sorry for the shift in OT here (if that's what it seems)
-vhelp 3294
My review for the Panasonic DMR-EA18
By pannayar in forum DVD & Blu-ray RecordersReplies: 29Last Post: 6th May 2017, 07:22 -
best vhs playback? panasonic nv-fs200 hq / panasonic dmr-e75v
By overheat in forum Newbie / General discussionsReplies: 6Last Post: 28th May 2009, 20:57 -
Panasonic DMR-EZ28 Previously Recorded Panasonic DVDs
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Oct 2008, 20:45 -
Help to review Panasonic AG-DVX100B & AG-HSC1U
By ChristianPaprika in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 8th Aug 2007, 13:07 -
Does the Panasonic DMR-ES10S DIGA help jitter/bouncing?
By justinluck in forum RestorationReplies: 6Last Post: 5th Jul 2007, 13:15
