I'm converting a H.264 TS video with FFMPEG. The video always ends up choppy. This is the output from encoding the first 5 seconds, some lines removed for length:
I know dup means it's a duplicate frame and drop means it's dropping a frame. It's dropping frames it shouldn't be though, which is messing up the resulting video. Why is it dropping the wrong frames? I also tried encoding this video with MEncoder and the output is smooth, but it crashes every time it reaches a certain frame.Code:ffmpeg.exe -i "c:\videoin.ts" -f avi -an -t 5 -vcodec mpeg4 -b 12960k -v 3 "C:\videoout.avi" Input #0, mpegts, from 'C:\videoin.ts': Duration: 01:31:55.3, start: 38704.550067, bitrate: 15745 kb/s Stream #0.0[0x31]: Video: h264, yuv420p, 1920x1088, 25.00 fps(r) Stream #0.1[0x34]: Audio: ac3, 48000 Hz, stereo, 384 kb/s Output #0, avi, to 'C:\videoout.avi': Stream #0.0, 1/90000: Video: mpeg4, yuv420p, 1920x1088, 1/25, q=2-31, 12960 kb/s, 25.00 fps(c) Stream mapping: Stream #0.0 -> #0.0 Press [q] to stop encoding *** 19 dup! *** 3 dup! *** drop! *** 1 dup! *** drop! *** 1 dup! *** drop!30 q=2.0 size= 373kB time=1.2 bitrate=2545.7kbits/s dup=28 drop=2 *** 1 dup! *** drop! *** 1 dup! *** drop!39 q=2.0 size= 492kB time=1.6 bitrate=2584.4kbits/s dup=32 drop=4 *** 1 dup! *** drop! *** 1 dup! *** drop! *** 1 dup!9 q=1.6 size= 606kB time=2.0 bitrate=2534.0kbits/s dup=36 drop=7 *** drop! *** 1 dup! *** drop! *** 1 dup! *** drop!60 q=2.0 size= 623kB time=2.4 bitrate=2127.4kbits/s dup=42 drop=9 *** 1 dup! *** drop! *** 1 dup! *** drop! *** 1 dup!9 q=2.0 size= 735kB time=2.8 bitrate=2181.6kbits/s dup=46 drop=12 *** drop! *** 1 dup! *** drop! *** 1 dup! *** drop! *** 1 dup!9 q=2.0 size= 849kB time=3.2 bitrate=2200.4kbits/s dup=52 drop=15 *** drop! *** 1 dup! *** drop! *** 1 dup! *** drop!90 q=2.0 size= 964kB time=3.6 bitrate=2194.0kbits/s dup=58 drop=17 *** 1 dup! *** drop! *** 1 dup! *** drop! *** 1 dup!9 q=2.0 size= 1077kB time=4.0 bitrate=2227.8kbits/s dup=62 drop=20 *** drop! *** 1 dup! *** drop! *** 1 dup!9 q=1.6 size= 1191kB time=4.4 bitrate=2238.1kbits/s dup=66 drop=22 *** drop! *** 1 dup! *** drop! *** 1 dup! *** drop!20 q=2.0 size= 1208kB time=4.8 bitrate=2061.8kbits/s dup=72 drop=24 *** 1 dup! *** drop! *** 1 dup! frame= 126 q=2.0 Lsize= 1326kB time=5.0 bitrate=2155.5kbits/s dup=76 drop=26 video:1015kB audio:0kB global headers:0kB muxing overhead 30.612374%
Results 1 to 25 of 25
perhaps you should try uploading a sample clip that includes the problem area somewhere,
so someone might give it a try. -
Here's an alternate way to encode, see posts starting with march 5th
https://forum.videohelp.com/viewtopic.php?t=323601&postdays=0&postorder=asc&start=30
You can modify the batch files to use ffmpeg instead of HCenc - you can probably use the same syntax that you have posted above, just use the Test.AVS file as your input source and make sure your ffmpeg.exe is dated after Sept 2006 for Avisynth support.
Originally Posted by 45tripp
Originally Posted by Soopafresh
Code:MP4Box.exe -add D:\video.h264 -new d:\video.mp4 Cannot find H264 start code Error importing D:\video.h264: BitStream Not Compliant
I scanned the file with Mpeg2Repair, no errors. Scanned it wth TS Packet Editor, no errors. ProjectX only gets the audio when demuxing. DGIndex says "No video sequence header found!" when manually selecting the PIDs. Xport outputs empty files.
I am going to try to get a sample clip again... -
Originally Posted by Abond
directshowsource("video.ts",fps=25.0) -
Originally Posted by Quaraxkad
DGAVCindex only works with elementary h264 streams.
Note:
If it's PAFF don't bother.
Also I think Soopafresh includes version Alpha2 with his batch files. Version Alpha3 is now available. -
I updated the batch file to stop using MP4s. The Rev2 zip files use DGavcsource("yourfile.dga")
45tripp is absolutely right - if the file is PAFF/interlaced, you'll have to wait for technology to progress.
Yes, Alpha 3 has been released. I've hesitated including it because it is a bit more complicated for the "uninitiated" -
http://www.bestsharing.com/files/rQ1M5X248198/source.ts.html
I also have a quick generic MPEG4 encode of that so you can see that it has duplicate frames where the source does not, but it won't upload! -
Here's that MPEG4 encode... It's a little messed up at the beginning, I assume it's because the source was an incomplete file fragment from CutFile.
http://www.bestsharing.com/files/3gSnn248201/output.mp4v.avi.html -
I haven't tried it with your batch files, but I did each step manually.
A re-cap of all the problems with the video...
The video plays (slowly, thanks to my slow computer and H.264) in MPC, MPlayer and VLC.
FFMPEG produces choppy output with duplicated and missing frames (noticable while playing and frame-stepping)
MEncoder crashes at the same location every attempt, but the output is smooth
Mpeg2Repair shows no errors in audio or video
TS Packet Editor shows no errors in audio or video
ProjectX only demuxes the audio portion
Xport runs for a while, can't tell if it's actually doing anything but I end up with 0-byte files.
Code:>xport.exe "video.ts" 1 1 1 xport Transport Stream Demuxer 0.93 program = 1, video channel = 1, audio channel = 1 Program Number = 3 (0x0003), Program Map PID = 48 (0x0030) packets for pid 0 <0x0000> = 11616, first = 1, last = 57738551 packets for pid 48 <0x0030> = 11616, first = 2, last = 57738552 packets for pid 49 <0x0031> = 56275614, first = 3, last = 57741257 packets for pid 52 <0x0034> = 1442411, first = 79, last = 57741243 coded frames = 0, video fields = 0
DGAVCIndex runs through that whole .h264 file in a few minutes and then shows an error message at the end: "slice_qp_delta makes slice_qp_y out of range"
After that I try this AVS... (essentially the same as the batch file output without the extra cropping/sharpening/etc)
Code:setmemorymax(768) loadplugin("dgavcdecode.dll") avcsource("video.dga") converttoyv12()
I am going to try letting TS Packet Editor cut out the parts I don't want and try again with that file. -
The problem with Mencoder or FFmpeg on h264 transport streams is that the support is new and still fairly buggy. It isn't so much with the apps, but rather the variation in TS files out there. With Mencoder, you can try telling the encoder to stop dropping frames by adding
-Noskip
to the encoding line, but this won't stop the drops in every case. Still, I've been able to transcode a 2 hour long movie from h264 into Xvid via Mencoder and it worked perfectly. Unfortunately, this has been the exception rather than the rule.
The second problem with mencoder doing the demuxing is that it starts on the first frame, so if the data isn't perfect, you can expect A/V sync errors when muxing the file back together. That's the advantage in using Xport.exe - the app demuxes both the audio and video on the first video I frame.
Have a look at the batch procedure for some ideas. The steps are the same -
1) Automatically running Mpeg2repair and creating a "fixed" .TS file
2) Running Xport on the Fixed TS file, demuxing to .h264 and .ac3
3) Indexing the .h264 file with DGavcIndex.exe for processing in Avisynth
What you'd want to do is replace Step 3 with Muxing the raw .h264 into an .MP4 container via Mp4box.exe
Then, run ffmpeg.exe against the .Mp4 file, and process the audio separately. You can't put an AC3 file into an MP4 container, so you either need to convert it into Mp3 or AAC
Your file does work, as demonstrated.
Rem - Fix small errors in transport stream. Input file is Input.ts
mpeg2repaircli /R output.ts input.ts
Rem - Note, the mpeg2repaircli does require .Net 2.0 to work
Rem- Run Xport on fixed file
Xport.exe output.ts 1 1 1
Rem - Rename output files to proper extensions
ren bit*.mpv output.h264
ren bit*.mpa output.ac3
Rem - Mux h264 video into Mp4 container
Mp4Box -add output.h264 output.mp4
Rem - Transcode Video with ffmpeg or Mencoder
ffmpeg -i output.mp4 -croptop 32 -cropbottom 32 -vcodec xvid -b 3200 -y VIDEO.avi
Here's your file, I added -s 720x400 to make it small enough to post here. But, you can see the above works fine, and you can skip having to go through Avisynth (although there's some visual improvements that you can only get with Avisynth).
output400.avi
If you want to play HD h264 without stuttering, you need the CoreAVC decoder, with the Haali media splitter. -
Originally Posted by Soopafresh -
Mpeg2repaircli will change the PIDs inside the transport stream file, removing all but the audio and video channels. Doing this allows you to blindly run Xport with the 1 1 1 parameters, ensuring you've caught the correct channels when you demux. It is worth the processing time, seriously.
No need to use DGavcindex if you decide to mux the h264 into an mp4 via mp4box.
You can mux the XVID (or whatever output) with the AC3 via ffmpeg like this
ffmpeg -i video.avi -i output.ac3 -vcodec copy -acodec copy -y "FINAL_MOVIE.AVI"
Finally, a note regarding dropped frame with ffmpeg - the revisions vary greatly - everything from Sept 2006 to present day is different, and there is a new revision released at least once a month. Once you find a version that works, hold onto it
BTW, does your encoding always stop when the output file reaches 2GB ? -
New problem... FFMPEG and MEncoder both crash when muxing the avi and ac3. It worked in VirtualDub (Direct Stream Copy), but the video played too fast even though it was still 25fps. It also thought the AC3 file was 2 hours and 7 minutes, and it should have been 1 hour and 31 minutes.
ffmpeg output prores causes color shift
By liutszho in forum ffmpegX general discussionReplies: 1Last Post: 4th Jan 2012, 22:22 -
ffmpeg output 2gb limit? Is there one? ffmpeg stops encoding h264 @ 2gb
By BrainiakZ in forum Video ConversionReplies: 14Last Post: 30th Mar 2011, 12:04 -
FFmpeg and quality of the output video
By Vidameker in forum Video ConversionReplies: 2Last Post: 26th Jan 2010, 20:46 -
.mpg -> .mp4 using ffmpeg, Video is choppy and 2x too long
By rccollins in forum Video ConversionReplies: 3Last Post: 11th Dec 2008, 10:20 -
can FFMPEG output info from video?
By squadjot in forum Video ConversionReplies: 3Last Post: 13th Apr 2008, 18:32
